| 0002706 | FreeCAD | Bug | public | 2016-09-23 13:20 | 2019-01-18 13:47 |
| Reporter | chk | Assigned To | wmayer | ||
| Platform | Linux | OS | Debian | OS Version | testing |
| Summary | 0002706: Box selection does not select dimension or text | ||||
| Description | Hi! Box selection (Edit->Box Selection) does not select dimension or text objects. | ||||
| Steps To Reproduce | - create new document - create new line - create dimension - create annotation - Edit -> Box Selection - draw the selection rectangle | ||||
| Additional Information | Expected result: line, dimension and annotation should be selected Actual result: only the line is selected | ||||
| Tags | Coin3d, upstream | ||||
| 2016-09-23 13:20 | chk | New Issue | |
| 2016-09-24 15:56 | wmayer | Note Added: 0007325 | |
| 2016-09-24 15:56 | wmayer | Assigned To | => wmayer |
| 2016-09-24 15:56 | wmayer | Status | new => assigned |
| 2016-09-24 15:57 | wmayer | Project | Draft => FreeCAD |
| 2017-09-15 10:32 | Kunda1 | Tag Attached: Coin3d | |
| 2017-12-15 20:49 | Kunda1 | Tag Attached: upstream | |
| 2018-01-25 21:45 | Kunda1 | Note Added: 0010856 | |
| 2018-03-12 09:38 | wmayer | Relationship added | has duplicate 0003365 |
| 2018-06-07 19:12 | Kunda1 | Target Version | => 0.18 |
| 2019-01-18 13:47 | wmayer | Status | assigned => closed |
| 2019-01-18 13:47 | wmayer | Resolution | open => fixed |
| 2019-01-18 13:47 | wmayer | Fixed in Version | => 0.18 |
| 2019-01-18 13:47 | wmayer | Note Added: 0012458 |
