| 0003389 | Draft | Bug | public | 2018-03-22 14:59 | 2018-12-28 02:19 |
| Reporter | randall | Assigned To | wandererfan | ||
| Priority | normal | Severity | minor | Reproducibility | random |
| Summary | 0003389: Using Draft-PathArray on a Sketcher Arc with Align=True results in "Value out of range" | ||||
| Description | When using the Draft PathArray to align on object on a Sketch Arc the Object is aligned correctly initially but when the Arc Radius is changed or the Arc Angle is changed a Value out of Range error is produced. However the error does not happen for every resize. I have reported this on Forum at: https://forum.freecadweb.org/viewtopic.php?f=10&t=27428 I made a screen cap at: https://youtu.be/MVLm1e3z5vI | ||||
| Steps To Reproduce | 1.) In Part Design WB create an Additive Cube. ( or any object ) 2.) Create a second body with a Sketch and an Arc. 3.) Switch to Draft WB 4.) Select Cube and Arc, click PathArray Tool 5.) In resulting array change the Align property to true 6.) edit the arc sketch and increase/decrease it's size until you get error It seems larger changes produce the error more reliably. It also seems like the closer to the object the path is the less likely to get an error. | ||||
| Additional Information | My FreeCAD Info: OS: Linux Mint 17.3 Rosa Word size of OS: 32-bit Word size of FreeCAD: 32-bit Version: 0.17.13424 (Git) Build type: None Branch: master Hash: 597dbf60947067852268033c32d6b78ac9ef280c Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 7.1.0 Locale: English/UnitedStates (en_US) Report View:
Console:
| related to | 0003581 | closed | wandererfan | Draft PathArray Align=True not work on custom sketch path |
@yorik please weigh in at your convenience, thanks! |
@yorik what release should this be assigned to ? |
I can't reproduce this on v0.18. Also the test file is not fully constrained and has redundant constraints. The only error in v0.18 is "link go out of allowed scope". |
marking this one "Resolved" |
I also did some testing and cannot reproduce the problem, I suppose it doesn't apply anymore... |
| 2018-03-22 14:59 | randall | New Issue | |
| 2018-03-29 19:48 | Kunda1 | Note Added: 0011082 | |
| 2018-04-02 13:38 | yorik | Assigned To | => yorik |
| 2018-04-02 13:38 | yorik | Status | new => assigned |
| 2018-09-04 14:20 | Kunda1 | Relationship added | related to 0003581 |
| 2018-11-19 10:32 | Kunda1 | Note Added: 0012219 | |
| 2018-12-08 02:06 | wandererfan | File Added: PathArrayAlignedBugConstrained.fcstd | |
| 2018-12-08 02:06 | wandererfan | Note Added: 0012244 | |
| 2018-12-08 18:05 | wandererfan | Assigned To | yorik => wandererfan |
| 2018-12-08 18:05 | wandererfan | Status | assigned => resolved |
| 2018-12-08 18:05 | wandererfan | Fixed in Version | => 0.18 |
| 2018-12-08 18:05 | wandererfan | Target Version | => 0.18 |
| 2018-12-08 18:05 | wandererfan | Note Added: 0012245 | |
| 2018-12-28 02:18 | yorik | Note Added: 0012343 | |
| 2018-12-28 02:18 | yorik | Status | resolved => closed |
| 2018-12-28 02:18 | yorik | Resolution | open => fixed |
| 2018-12-28 02:19 | yorik | Resolution | fixed => no change required |
