| 0003581 | Draft | Bug | public | 2018-09-04 07:03 | 2019-01-24 12:30 |
| Reporter | flim | Assigned To | wandererfan | ||
| OS | Windows | OS Version | 10 1803 | ||
| Summary | 0003581: Draft PathArray Align=True not work on custom sketch path | ||||
| Description | It is OK to create an array of objects on a custom sketch using Draft PathArray, but cannot change the objects alignment to path when changed the PathArray->Align to True. Forum thread | ||||
| Steps To Reproduce | In Sketch WB, create a custom Sketch as the path for object array Switch to PartDesign WB, create a rectangle body. Switch to Draft WB, select the body and the path sketch, select PathArray, change the Count, then change the Align=True. | ||||
| Additional Information | FreeCAD Version: 0.18 14555 (Git) 64-bit Report view
Python console | ||||
| Tags | Draft | ||||
| related to | 0003389 | closed | wandererfan | Using Draft-PathArray on a Sketcher Arc with Align=True results in "Value out of range" |
Fixed broken markup in summary |
@yorik is this a dupe of 0003389 ? |
I believe this has been fixed with https://github.com/FreeCAD/FreeCAD/commit/41102edf674bbcdc7c5f9397b0a6df4b6c3f1b9e |
No, not exactly. You can try this drawing and change the PathArray -> Draft -> Align to True but no effect. I am testing version 14928 (Git) |
This is very strange. Align = true does have an effect, it causes an exception in the report view, but that's not the strange part. You can temporarily change the rotation of Sketch from 120 degrees to 119 degrees, and it works (except you also need to rotate Sketch001 90 degrees about the Z axis to get the alignment you're looking for). Then you can put Sketch back to 120 degrees and it works. |
There is a configuration where the alignment calculation produces infinite solutions. See "Gimbal Lock" in Euler angles. You need to change the Path (rotate around X/Y/Z) and/or the orientation of the Base shape. Changing Align has no effect because the recompute fails. |
git commit bf3a1fdaa8 improves the handling of the infinite solutions issue. |
Marking this one as resolved. |
@wandererfan can we close this issue as well ? |
closed |
| 2018-09-04 07:03 | flim | New Issue | |
| 2018-09-04 07:03 | flim | Tag Attached: Draft | |
| 2018-09-04 07:03 | flim | File Added: ArrayOnCustomSketch.FCStd | |
| 2018-09-04 14:17 | Kunda1 | Additional Information Updated | |
| 2018-09-04 14:18 | Kunda1 | Description Updated | |
| 2018-09-04 14:18 | Kunda1 | Note Added: 0011697 | |
| 2018-09-04 14:20 | Kunda1 | Relationship added | related to 0003389 |
| 2018-09-04 14:20 | Kunda1 | Note Added: 0011698 | |
| 2018-10-06 02:29 | TheMarkster | Note Added: 0011938 | |
| 2018-10-06 06:33 | flim | File Added: tank.FCStd | |
| 2018-10-06 06:33 | flim | Note Added: 0011942 | |
| 2018-10-06 18:00 | TheMarkster | Note Added: 0011948 | |
| 2018-12-08 01:59 | wandererfan | File Added: tankNewAngles.FCStd | |
| 2018-12-08 01:59 | wandererfan | File Added: tankNewAngles.png | |
| 2018-12-08 01:59 | wandererfan | Note Added: 0012243 | |
| 2018-12-08 18:09 | wandererfan | Note Added: 0012246 | |
| 2018-12-08 18:10 | wandererfan | Assigned To | => wandererfan |
| 2018-12-08 18:10 | wandererfan | Status | new => resolved |
| 2018-12-08 18:10 | wandererfan | Fixed in Version | => 0.18 |
| 2018-12-08 18:10 | wandererfan | Target Version | => 0.18 |
| 2018-12-08 18:10 | wandererfan | Note Added: 0012247 | |
| 2019-01-22 23:47 | Kunda1 | Note Added: 0012496 | |
| 2019-01-24 12:30 | wandererfan | Status | resolved => closed |
| 2019-01-24 12:30 | wandererfan | Resolution | open => fixed |
| 2019-01-24 12:30 | wandererfan | Note Added: 0012504 |
