| 0003425 | PartDesign | Bug | public | 2018-04-09 22:07 | 2022-01-24 19:16 |
| Reporter | nikisteen | Assigned To | |||
| OS | Windows | OS Version | 10 | ||
| Summary | 0003425: Boolean operation in PDN fails depending on placement of one of the parts | ||||
| Description | When creating a boolean fuse between a cylinder and sphere (as shown in the attached project), the sphere disappear when its placement is adjusted to certain values, although the sphere still intersects the cylinder. | ||||
| Steps To Reproduce | In the attached project, adjust the Y-axis placement of the sphere to 8mm. The sphere will be offset as expected. Now adjust the Y-axis placement to 9mm and the sphere disappears. | ||||
| Additional Information | Refer to forum thread Freecad version information: OS: Windows 10 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.13488 (Git) Build type: Release Branch: master Hash: 2891173923bcecaace64e0544f5773facbdef436 Python version: 2.7.14 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 7.1.0 Locale: English/SouthAfrica (en_ZA) It was also confirmed to occur on the newest stable release (0.17.13509) - see forum thread. | ||||
| Tags | #ready-for-migration, boolean, OCC 7.4, OCC Bug, OCC NotOnRoadmap, Part Design NEXT, upstream | ||||
@wmayer @DeepSOIC thinks this is a OCC bug. Please weigh in. Thanks! |
Seems to be related to a different behaviour between OCC 7.2 and older versions. With 7.2 I can confirm the behaviour but with 7.0 it works as expected. |
@wmayer what about OCC 7.3? |
There is a different behaviour in 7.2. For some reason the fusion of the sphere with the fused cylinder and box creates a compound with two solids.
If the y value of the placement of the sphere is <= 8 then the second fusion correctly creates a single solid. |
Same issue with OCC 7.3. OS: Ubuntu 18.04.2 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.18.15972 (Git) Build type: Release Branch: master Hash: 4e973324ae03c6db9188c08483232fa059c1c9ae Python version: 3.6.7 Qt version: 5.9.5 Coin version: 4.0.0a OCC version: 7.3.0 Locale: French/Canada (fr_CA) |
Added to "OCC Bugs in the Bugtracker" thread |
@user1234 writes in https://forum.freecad.org/viewtopic.php?p=534379#p534379
See responses: https://forum.freecad.org/viewtopic.php?p=561983#p561983 https://forum.freecad.org/viewtopic.php?p=562493#p562493 |
This ticket has been migrated to GitHub as issue 5782. |
| 2018-04-09 22:07 | nikisteen | New Issue | |
| 2018-04-09 22:07 | nikisteen | File Added: BoolTest.FCStd | |
| 2018-04-09 22:07 | nikisteen | File Added: 8mm_offset.PNG | |
| 2018-04-09 22:07 | nikisteen | File Added: 9mm_offset.PNG | |
| 2018-04-09 22:07 | nikisteen | Tag Attached: boolean | |
| 2018-04-09 22:07 | nikisteen | Tag Attached: Part Design NEXT | |
| 2018-06-07 16:57 | Kunda1 | Note Added: 0011362 | |
| 2018-06-07 16:57 | Kunda1 | Status | new => confirmed |
| 2018-09-26 09:35 | wmayer | Note Added: 0011849 | |
| 2018-09-26 13:23 | Kunda1 | Tag Attached: OCC Bug | |
| 2018-09-26 13:23 | Kunda1 | Tag Attached: upstream | |
| 2018-09-26 13:24 | Kunda1 | Note Added: 0011852 | |
| 2019-02-20 15:44 | wmayer | Note Added: 0012705 | |
| 2019-02-24 15:45 | normandc | Note Added: 0012743 | |
| 2019-02-25 12:44 | Kunda1 | Tag Attached: OCC NotOnRoadmap | |
| 2019-06-17 07:51 | Kunda1 | Tag Attached: OCC 7.4 | |
| 2019-06-17 07:54 | Kunda1 | Note Added: 0013236 | |
| 2022-01-15 13:17 | Kunda1 | Note Added: 0016209 | |
| 2022-01-15 13:18 | Kunda1 | Note Edited: 0016209 | |
| 2022-01-23 00:21 | Kunda1 | Note Added: 0016252 | |
