0003425PartDesignBugpublic2022-01-24 19:16
Reporternikisteen Assigned To
Status confirmedResolutionopen
OSWindowsOS Version10
Product Version0.17
Target Version0.20
Summary0003425: Boolean operation in PDN fails depending on placement of one of the parts
DescriptionWhen creating a boolean fuse between a cylinder and sphere (as shown in the attached project), the sphere disappear when its placement is adjusted to certain values, although the sphere still intersects the cylinder.
Steps To ReproduceIn the attached project, adjust the Y-axis placement of the sphere to 8mm. The sphere will be offset as expected. Now adjust the Y-axis placement to 9mm and the sphere disappears.
Additional InformationRefer to forum thread
Freecad version information:
OS: Windows 10
Version: 0.17.13488 (Git)
Hash: 2891173923bcecaace64e0544f5773facbdef436
Python version: 2.7.14
Qt version: 4.8.7
OCC version: 7.1.0
Locale: English/SouthAfrica (en_ZA)
It was also confirmed to occur on the newest stable release (0.17.13509) - see forum thread.
Tags#ready-for-migration, boolean, OCC 7.4, OCC Bug, OCC NotOnRoadmap, Part Design NEXT, upstream
nikisteen
2018-04-09 22:07
reporter
BoolTest.FCStd (16,453 bytes)
2018-06-07 16:57
administrator   ~0011362
@wmayer
@DeepSOIC thinks this is a OCC bug. Please weigh in. Thanks!
2018-09-26 09:35
administrator   ~0011849
Seems to be related to a different behaviour between OCC 7.2 and older versions. With 7.2 I can confirm the behaviour but with 7.0 it works as expected.
2018-09-26 13:24
administrator   ~0011852
@wmayer what about OCC 7.3?
2019-02-20 15:44
administrator   ~0012705
There is a different behaviour in 7.2. For some reason the fusion of the sphere with the fused cylinder and box creates a compound with two solids.
cyl=App.ActiveDocument.Cylinder.Shape
sphere=App.ActiveDocument.Body002.Shape
cube=App.ActiveDocument.Body001.Shape
fuse=cyl.fuse(cube)
fuse.Solids
# shows one solid
fuse=fuse.fuse(sphere)
fuse.Solids
# shows two solids => error
If the y value of the placement of the sphere is <= 8 then the second fusion correctly creates a single solid.
normandc
2019-02-24 15:45
manager   ~0012743
Same issue with OCC 7.3.
OS: Ubuntu 18.04.2 LTS
Version: 0.18.15972 (Git)
Hash: 4e973324ae03c6db9188c08483232fa059c1c9ae
Python version: 3.6.7
Qt version: 5.9.5
Locale: French/Canada (fr_CA)
2019-06-17 07:54
administrator   ~0013236
Added to "OCC Bugs in the Bugtracker" thread
2022-01-15 13:17
administrator   ~0016209
@user1234 writes in https://forum.freecad.org/viewtopic.php?p=534379#p534379
I think this bug is solved (and was not OCCT related). When i switch the visibility to Tools and then to Result back, the file is fine. Also when i delete the boolean operation and redo it, it works fine.
user1234
2022-01-23 00:21
administrator   ~0016252
See responses:
https://forum.freecad.org/viewtopic.php?p=561983#p561983
https://forum.freecad.org/viewtopic.php?p=562493#p562493
yorik
2022-03-03 13:55
administrator   ~0016617
This ticket has been migrated to GitHub as issue 5782.
2018-04-09 22:07 nikisteen New Issue
2018-04-09 22:07 nikisteen File Added: BoolTest.FCStd
2018-04-09 22:07 nikisteen File Added: 8mm_offset.PNG
2018-04-09 22:07 nikisteen File Added: 9mm_offset.PNG
2018-04-09 22:07 nikisteen Tag Attached: boolean
2018-04-09 22:07 nikisteen Tag Attached: Part Design NEXT
2018-06-07 16:57 Kunda1 Note Added: 0011362
2018-06-07 16:57 Kunda1 Status new => confirmed
2018-09-26 09:35 wmayer Note Added: 0011849
2018-09-26 13:23 Kunda1 Tag Attached: OCC Bug
2018-09-26 13:23 Kunda1 Tag Attached: upstream
2018-09-26 13:24 Kunda1 Note Added: 0011852
2019-02-20 15:44 wmayer Note Added: 0012705
2019-02-24 15:45 normandc Note Added: 0012743
2019-02-25 12:44 Kunda1 Tag Attached: OCC NotOnRoadmap
2019-06-17 07:51 Kunda1 Tag Attached: OCC 7.4
2019-06-17 07:54 Kunda1 Note Added: 0013236
2021-02-06 06:43 abdullah Target Version => 0.20
2022-01-15 13:17 Kunda1 Note Added: 0016209
2022-01-15 13:18 Kunda1 Note Edited: 0016209
2022-01-23 00:21 Kunda1 Note Added: 0016252
2022-01-24 19:16 Kunda1 Tag Attached: #ready-for-migration
