| 0003557 | FreeCAD | Bug | public | 2018-08-13 20:25 | 2021-01-04 21:06 |
| Reporter | plunax | Assigned To | normandc | ||
| Summary | 0003557: Every time that I try to import a svg plane file, freecad crashes | ||||
| Description | When I try to open a svg plane file (from inkscape) freecad crashes | ||||
| Steps To Reproduce | 1. Open FreeCAD 2. Press the "create new document" button 3. Press "ctrl+I" 4. Select a svg file 5. Select in the new windows "SVG as geometry" 6. FreeCAD crashes | ||||
| Additional Information | OS: Ubuntu 17.10 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.13528 (Git) Build type: None Branch: releases/FreeCAD-0-17 Hash: 5c3f7bf8ec51e2c7187789f7edba71a7aa82a88b Python version: 2.7.14 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 7.3.0 Locale: Spanish/Spain (es_ES) | ||||
| Tags | crash, import, SVG | ||||
@plunax can you recreate this with 0.18dev ? https://github.com/FreeCAD/FreeCAD/releases/tag/0.18_pre |
I have done it and I have the same problem, freecad crashe. OS: Ubuntu 17.10 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.18.14220 (Git) AppImage Build type: None Branch: master Hash: 1d81fd66b84af9ef8330ba1f1f6d1c5d6443f0c4 Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 7.3.0 Locale: Spanish/Spain (es_ES) |
@wmayer care to take a look at this ? |
This issue is well-known and relates to a conflicting internal version of expat in the libcoin package for Ubuntu 17.10 and later. The problem is with packaging of libcoin external library, not with FreeCAD. Therefore this report should be closed as it can only be fixed by packagers on Debian/Ubuntu. Workaround: https://forum.freecad.org/viewtopic.php?f=3&t=26291&start=10#p228605 BTW Ubuntu 17.10 reached end of life in July. We should not support this version if Canonical (its publisher) no longer supports it. |
Once more, this proves reporters should follow the guidelines shown in the big fucking yellow banner at the top!!!!!!!!!!!!!!! |
Original issue was closed as non-fixable. |
| 2018-08-13 20:25 | plunax | New Issue | |
| 2018-08-13 20:25 | plunax | Tag Attached: crash | |
| 2018-08-13 20:25 | plunax | Tag Attached: import | |
| 2018-08-13 20:25 | plunax | Tag Attached: SVG | |
| 2018-08-14 12:09 | Kunda1 | Status | new => feedback |
| 2018-08-14 12:09 | Kunda1 | Note Added: 0011620 | |
| 2018-08-14 16:00 | plunax | Note Added: 0011623 | |
| 2018-08-14 16:00 | plunax | Status | feedback => new |
| 2018-08-23 16:44 | Kunda1 | Note Added: 0011638 | |
| 2018-08-25 18:48 | normandc | Note Added: 0011652 | |
| 2018-08-25 18:49 | normandc | Note Added: 0011653 | |
| 2018-08-25 18:51 | normandc | Relationship added | duplicate of 0003307 |
| 2018-08-25 18:52 | normandc | Assigned To | => normandc |
| 2018-08-25 18:52 | normandc | Status | new => closed |
| 2018-08-25 18:52 | normandc | Resolution | open => duplicate |
| 2018-08-25 18:52 | normandc | Note Added: 0011654 | |
| 2021-01-04 21:06 | StefanBruens | Relationship added | related to 0004528 |
