0003307File formatsGeneralpublic2021-01-04 21:05
Reporterjalar Assigned ToKunda1
Summary0003307: Freecad segfault on SVG import
DescriptionFreecad crashes on SVG import
Downgrading to libexpat-2.1.0-7ubuntu0.16.04.3 (from libexpat-2.2.3-1 fixes the problem).
All info in https://forum.freecad.org/viewtopic.php?f=3&t=26291&p=208742#p208742
openat(AT_FDCWD, "/path-to-file.svg", O_RDONLY) = 27
fstat(27, {st_mode=S_IFREG|0644, st_size=2234752, ...}) = 0
--- SIGSEGV {si_signo=SIGSEGV, si_code=SEGV_MAPERR, si_addr=0x3a9} ---
write(2, "\33[1;31m", 7) = 7
write(2, "Program received signal SIGSEGV,"..., 53Program received signal SIGSEGV, Segmentation fault.
) = 53
#0 /lib/x86_64-linux-gnu/libc.so.6(+0x37140) [0x7fd97f382140]
#1 /lib/x86_64-linux-gnu/libexpat.so.1(XML_SetHashSalt+0x1b) [0x7fd976c411cb]
0000002 /usr/lib/python2.7/lib-dynload/pyexpat.x86_64-linux-gnu.so(+0x6968) [0x7fd90487a968]
Steps To Reproduce1) Command-line start `freecad Svg_example4.svg` (any SVG, I guess)
2) Segfault
Additional InformationOS: Ubuntu 17.10
Version: 0.17.12920 (Git)
Build type: None
Hash: 8faa9f38bb70a598afc2bc39ea1645d416ab057e
Python version: 2.7.14
Qt version: 4.8.7
OCC version: 7.1.0
Locale: Swedish/Sweden (sv_SE)
Tagsupstream
Relationships
has duplicate 0003557 closednormandc FreeCAD Every time that I try to import a svg plane file, freecad crashes
related to 0003355 closed File formats SVG importer: regression from 0.16 to 0.17
related to 0004528 closed File formats Crash in SVG import
jalar
2018-01-12 09:24
reporter   ~0010742
wmayer says:
Dependency problem, Coin3d and Python use different versions of the libexpat library, cannot be fixed by freecad devel.
Close the issue, not fixable.
2018-01-11 10:00 jalar New Issue
2018-01-11 11:32 Kunda1 Description Updated
2018-01-12 09:24 jalar Note Added: 0010742
2018-02-13 00:15 Kunda1 Tag Attached: upstream
2018-02-13 00:15 Kunda1 Assigned To => Kunda1
2018-02-13 00:15 Kunda1 Status new => closed
2018-02-13 00:15 Kunda1 Resolution open => not fixable
2018-08-23 17:12 Kunda1 Relationship added related to 0003355
2018-08-25 18:51 normandc Relationship added has duplicate 0003557
2021-01-04 21:05 StefanBruens Relationship added related to 0004528
