| 0003648 | FreeCAD | Feature | public | 2018-10-22 22:06 | 2019-06-20 15:46 |
| Reporter | vocx | Assigned To | triplus | ||
| Summary | 0003648: Allow the user to manually move the tabs in the main window | ||||
| Description | When using a workbench like TechDraw each new Page creates a tab in the bottom of the viewport. When the model file is opened, all Pages are opened as well, cluttering the bottom of the viewport. There should be a way to define which TechDraw pages to load from the beginning, including none of them. Also, it seems like all such tabs appear in the order that they were created and cannot be reordered. Reordering of tabs is a common feature of many modern programs. It is a desirable feature to logically structure the TechDraw Pages and views. In many cases the user creates pages and views, but then has to go back, delete some pages, and add others, and this produces Page tabs that aren't in order. In this thread the need for manually arranging Pages from TechDraw is explained https://forum.freecadweb.org/viewtopic.php?f=35&t=31654 In this post it is shown that a simple tabbed window uses QTabWidgets that can be reordered. https://forum.freecadweb.org/viewtopic.php?f=35&t=31654#p263268 wandererfan comments that in FreeCAD this functionality resides in src/Gui/MainWindow.cpp, and it is not exposed to the workbenches, so the workbenches cannot change the way tabs behave. The tabbed window and workspace seems to be created as QMdiArea* https://github.com/FreeCAD/FreeCAD/blob/master/src/Gui/MainWindow.cpp#L242 | ||||
| Additional Information | OS: Ubuntu 18.04.1 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.18.14995 (Git) Build type: Release Branch: master Hash: 7b866816785ac1ca9787b63d4bff12873bb3a593 Python version: 2.7.15rc1 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 7.3.0 Locale: English/UnitedStates (en_US) | ||||
I also vote for this feature since this would improve the workflow a lot when dealing with several documents at once: https://forum.freecadweb.org/viewtopic.php?f=8&t=36320 |
See FreeCAD Pull Request 2273 |
| 2018-10-22 22:06 | vocx | New Issue | |
| 2019-05-12 21:22 | uwestoehr | Note Added: 0013100 | |
| 2019-06-20 03:17 | Kunda1 | Note Added: 0013272 | |
| 2019-06-20 15:45 | wmayer | Changeset attached | => FreeCAD master 54c6537a |
| 2019-06-20 15:46 | wmayer | Assigned To | => triplus |
| 2019-06-20 15:46 | wmayer | Status | new => closed |
| 2019-06-20 15:46 | wmayer | Resolution | open => fixed |
| 2019-06-20 15:46 | wmayer | Fixed in Version | => 0.19 |
