| 0003670 | Part | Bug | public | 2018-11-05 08:02 | 2022-01-24 19:16 |
| Reporter | 0kko | Assigned To | |||
| Summary | 0003670: Thickness operation for part fails (upstream OCC bug) | ||||
| Description | Thickness operation in Part and Part Design -workbences fails with: "BRep_API: command not done." | ||||
| Steps To Reproduce | Select "face 8" in "case.fcstd". Try to do "Thickness" | ||||
| Additional Information | Binaries tested with "case.fcstd" FreeCAD-0.17.13541.9948ee4.glibc2.17-x86_64.AppImage FreeCAD-0.17.13541.9948ee4.glibc2.17-x86_64.AppImage Note: Issue is reproducible on latest v0.19 since the bug is with upstream OCCT This ticket is being tracked via OCC Bugs in the Bugtracker forum thread | ||||
| Tags | #ready-for-migration, OCC Bug, OCC NotOnRoadmap, upstream | ||||
@0kko Please check with 0.18_pre appImage to see if you can recreate. https://github.com/FreeCAD/FreeCAD/releases/tag/0.18_pre (make sure you backup you file before doing so as 0.18 is not backward compatible if you open said file in 0.17 again) BTW, your ticket does not follow our guidelines stated in the enormous banner at the top of this page. We ask for people to report their issues on the forum first, many times they don't even make it to the tracker because they either get solved, or there is an open ticket already (there are exceptions). You also tested this on 0.17 yet you labeled this 0.18. + we have no idea what OS or OS version you are running. Guidelines are there for a reason, thank you. |
It is no surprise that the Thickness operation fails - look at the corners at the joint between the wedge and the box. The fillet created a deep cavity at the four corners. While this may look like a separate and legitimate bug (a fillet causing a crease between slanted corners), fixing it does not solve the thickness issue. The thickness command is notoriously weak. It is most probably an upstream (OCC) issue over which the FreeCAD team has no control. It is indeed exasperating that some people are completely blind to the f***ing huge yellow banner at the top. IMO we should start ruthlessly closing reports that do not comply with rules. Enough with this. |
File is lost, and it was as Normand guessed most probably an OCC issue anyway. |
https://forum.freecad.org/viewtopic.php?f=8&t=53514&p=460091#p460091 |
Reopening and tracking via OCC Bugs in the Bugtracker forum thread |
Re-uploaded attachment since previous one was broken. Thanks wmayer ;) |
I can't find face8 in the attached file ??? @chrisb care to check? |
This ticket has been migrated to GitHub as issue 5829. |
| 2018-11-05 08:03 | 0kko | New Issue | |
| 2018-11-05 08:04 | 0kko | File Added: case.fcstd | |
| 2018-11-05 18:37 | Kunda1 | Note Added: 0012137 | |
| 2018-11-05 18:38 | Kunda1 | Status | new => feedback |
| 2018-11-05 18:38 | Kunda1 | Product Version | 0.18 => 0.17 |
| 2018-11-05 18:38 | Kunda1 | Steps to Reproduce Updated | |
| 2018-11-05 18:38 | Kunda1 | Additional Information Updated | |
| 2018-11-11 05:58 | normandc | Note Added: 0012171 | |
| 2018-11-11 06:00 | normandc | Note Edited: 0012171 | |
| 2018-11-11 06:01 | normandc | Note Edited: 0012171 | |
| 2018-11-14 11:56 | wmayer | Status | feedback => confirmed |
| 2020-12-22 00:33 | chrisb | Assigned To | => chrisb |
| 2020-12-22 00:33 | chrisb | Status | confirmed => closed |
| 2020-12-22 00:33 | chrisb | Resolution | open => unable to reproduce |
| 2020-12-22 00:33 | chrisb | Note Added: 0015166 | |
| 2020-12-22 11:53 | wmayer | Note Added: 0015173 | |
| 2020-12-22 12:13 | Kunda1 | Assigned To | chrisb => |
| 2020-12-22 12:13 | Kunda1 | Status | closed => confirmed |
| 2020-12-22 12:13 | Kunda1 | Note Added: 0015174 | |
| 2020-12-22 12:14 | Kunda1 | Summary | Thickness operation for part fails => Thickness operation for part fails (upstream OCC bug) |
| 2020-12-22 12:14 | Kunda1 | Description Updated | |
| 2020-12-22 12:14 | Kunda1 | File Deleted: case.fcstd | |
| 2020-12-22 12:15 | Kunda1 | Note Added: 0015175 | |
| 2020-12-22 12:15 | Kunda1 | File Added: case.fcstd | |
| 2020-12-22 12:15 | Kunda1 | Tag Attached: OCC Bug | |
| 2020-12-22 12:15 | Kunda1 | Tag Attached: OCC NotOnRoadmap | |
| 2020-12-22 12:15 | Kunda1 | Tag Attached: upstream | |
| 2020-12-22 12:18 | Kunda1 | Resolution | unable to reproduce => open |
| 2020-12-22 12:18 | Kunda1 | Additional Information Updated | |
| 2020-12-22 12:19 | Kunda1 | Severity | major => minor |
| 2022-01-23 00:34 | Kunda1 | Note Added: 0016253 | |
