| 0003717 | FreeCAD | Bug | public | 2018-12-06 21:52 | 2020-01-06 15:55 |
| Reporter | Witold Baryluk | Assigned To | Kunda1 | ||
| Summary | 0003717: FreeCAD AppImage fails to start: failed to create drawable | ||||
| Description | Download recent AppImage for FreeCad from https://www.freecadweb.org/downloads.php make it executable, and run: user@debian:~/Downloads$ ./FreeCAD-0.17.13541.9948ee4.glibc2.17-x86_64.AppImage FreeCAD 0.17, Libs: 0.17R13541 (Git) © Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2018 ##### #### ### #### # # # # # # # ## #### #### # # # # # #### # # # # # # # ##### # # # # #### #### # # # # # # # # # # # # # # ## ## ## # # #### #### ### # # #### ## ## ## failed to create drawable [xcb] Unknown sequence number while processing queue [xcb] Most likely this is a multi-threaded client and XInitThreads has not been called [xcb] Aborting, sorry about that. freecad: ../../src/xcb_io.c:263: poll_for_event: Assertion `!xcb_xlib_threads_sequence_lost' failed. Aborted $ | ||||
| Steps To Reproduce | In the description. | ||||
| Additional Information | n/a | ||||
| Tags | appimage, Assertion, linux | ||||
| related to | 0003737 | closed | neue Installation startet nicht |
After doing extensive research it turns out it's a known issue: https://forum.freecadweb.org/viewtopic.php?style=4&f=4&t=28054&start=10 Please read the enormous yellow banner at the top of the page. Thanks. |
I did search in a tracker. There are no open issues about this. Is it fixed? Because if not, then why you would close the issue? |
OP please read the threads and utilize the workaround. Does it work ? |
Are you talking about `LIBGL_DRI3_DISABLE=true`? I am able to start up the ./FreeCAD-0.17.13541.9948ee4.glibc2.17-x86_64.AppImage with this environment variable set now, and it appears to be working (only tested 3 workspaces). The style of windows, menus and some fonts, looks rather wrong to me, but I have no idea if this is related to appimage or to this flag. I have also freecad from Debian installed, and it works perfectly. No flags. Correct window and menu styles, font sizes, etc. So, workaround kind of works indeed. Still, would be good to understand the actual problem. Why is the Debian package working fine? Testing the debian package, I see it is using DRI3:
Regards, Witold |
BTW. I do not use wayland. It is just a MATE Desktop with standard Xorg server and marco window manager. |
Yea, best to continue this discussion on the forum. Choose a thread (not older than a year) and post to it or create a whole new thread. We prefer to discuss such things in the forum. |
Looks like there is a duplicate 0003737 |
OP please have a look at the @wmayers (core-developer) response: 0003737:0012302 |
@wmayer is this the same issue as 0003737 and can this be closed ? |
Yes, it's the same issue. |
I am happy to discuss things on forum if you stop closing the issue report about a bug that is still not fixed or resolved. |
Tested 0.18dev release, with same effect.
We did follow your "rules" too: We are observing many reporters do not: (1) First post to forum to verify their issue; - DONE. It is verified. (2) Link said thread to ticket and vice-a-versa; - DONE. We have a link to this thread and vice a versa. (3) Use the most updated stable or development versions of FreeCAD; - DONE. Still there. (4) Post their Help>About FreeCAD>Copy to clipboard version info; - Not possible. (5) Post a Step-By-Step explanation on how to recreate the issue; - DONE. (6) Neglect to upload an example file to demonstrate problem. - DONE. Not applicable. |
OP did you read the workaround mentioned in 0003737:0012302 ? type this in your terminal before starting FC: |
ping |
Ugly workaround:
| 2018-12-06 21:52 | Witold Baryluk | New Issue | |
| 2018-12-06 21:52 | Witold Baryluk | Tag Attached: appimage | |
| 2018-12-06 21:52 | Witold Baryluk | Tag Attached: Assertion | |
| 2018-12-06 21:52 | Witold Baryluk | Tag Attached: linux | |
| 2018-12-07 23:46 | Kunda1 | Assigned To | => Kunda1 |
| 2018-12-07 23:46 | Kunda1 | Status | new => resolved |
| 2018-12-07 23:46 | Kunda1 | Resolution | open => no change required |
| 2018-12-07 23:46 | Kunda1 | Note Added: 0012241 | |
| 2018-12-08 00:33 | Witold Baryluk | Status | resolved => feedback |
| 2018-12-08 00:33 | Witold Baryluk | Resolution | no change required => reopened |
| 2018-12-08 00:33 | Witold Baryluk | Note Added: 0012242 | |
| 2018-12-10 13:34 | Kunda1 | Note Added: 0012256 | |
| 2018-12-12 15:14 | Witold Baryluk | Note Added: 0012264 | |
| 2018-12-12 15:14 | Witold Baryluk | Status | feedback => assigned |
| 2018-12-12 15:15 | Witold Baryluk | Note Added: 0012265 | |
| 2018-12-12 23:51 | Kunda1 | Note Added: 0012267 | |
| 2018-12-18 11:41 | Kunda1 | Relationship added | related to 0003737 |
| 2018-12-18 11:42 | Kunda1 | Note Added: 0012301 | |
| 2018-12-19 09:21 | Kunda1 | Note Added: 0012308 | |
| 2018-12-19 09:23 | Kunda1 | Assigned To | Kunda1 => |
| 2018-12-19 09:23 | Kunda1 | Status | assigned => resolved |
| 2018-12-19 09:23 | Kunda1 | Resolution | reopened => no change required |
| 2019-01-05 11:57 | Kunda1 | Note Added: 0012385 | |
| 2019-01-09 10:13 | wmayer | Note Added: 0012401 | |
| 2019-01-09 10:26 | Witold Baryluk | Status | resolved => feedback |
| 2019-01-09 10:26 | Witold Baryluk | Resolution | no change required => reopened |
| 2019-01-09 10:26 | Witold Baryluk | Note Added: 0012402 | |
| 2019-01-09 10:33 | Witold Baryluk | Note Added: 0012403 | |
| 2019-01-09 10:33 | Witold Baryluk | Status | feedback => new |
| 2019-01-25 21:28 | Kunda1 | Summary | FreeCAD AppImage fils to start: failed to create drawable => FreeCAD AppImage fails to start: failed to create drawable |
| 2019-01-25 23:09 | Kunda1 | Note Added: 0012515 | |
| 2019-01-25 23:09 | Kunda1 | Status | new => feedback |
| 2019-02-27 21:28 | Kunda1 | Severity | block => major |
| 2019-02-27 21:28 | Kunda1 | Note Added: 0012791 | |
| 2019-03-22 11:05 | Kunda1 | Note Added: 0012941 | |
| 2019-03-22 11:08 | Kunda1 | Target Version | => 0.19 |
| 2020-01-06 15:54 | Kunda1 | Assigned To | => Kunda1 |
| 2020-01-06 15:54 | Kunda1 | Status | feedback => closed |
| 2020-01-06 15:55 | Kunda1 | Target Version | 0.19 => |
