| 0003737 | FreeCAD | General | public | 2018-12-18 04:21 | 2018-12-19 09:24 |
| Reporter | terrysbestfriend | Assigned To | |||
| Summary | 0003737: neue Installation startet nicht | ||||
| Description | Guten Tag, habe gerade FreeCAD auf einer Linux Maschine unter KUbuntu 18.04.LTS aus dem pps über die Konsole installiert. (sudo add-apt-repository ppa:freecad-maintainers/freecad-stable) und (sudo apt-get install freecad freecad-doc && sudo apt-get upgrade) Nach Aufruf (freecad) erscheint folgendes: FreeCAD 0.17, Libs: 0.17R13541 (Git) © Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2018 ##### #### ### #### # # # # # # # ## #### #### # # # # # #### # # # # # # # ##### # # # # #### #### # # # # # # # # # # # # # # ## ## ## # # #### #### ### # # #### ## ## ## failed to create drawable [xcb] Unknown sequence number while processing queue [xcb] Most likely this is a multi-threaded client and XInitThreads has not been called [xcb] Aborting, sorry about that. freecad: ../../src/xcb_io.c:259: poll_for_event: Zusicherung »!xcb_xlib_threads_sequence_lost« nicht erfüllt. Abgebrochen (Speicherabzug geschrieben) Mir als Laie sagt das nichts. Kann mir da jemand helfen ? | ||||
@terrysbestfriend please read https://freecadweb.org/wiki/Tracker We ask that you first open a forum thread https://forum.freecadweb.org/viewforum.php?f=13 Also please do not create a bug report in any language but english. |
Looks related to 0003717 |
It's hard to say what exactly causes the problem. Maybe it's related to the graphic driver because when searching for the environment variable LIBGL_DRI3_DISABLE then the mesa project uses it: https://www.mesa3d.org/envvars.html A workaround to make FreeCAD working again is to set this variable: export LIBGL_DRI3_DISABLE=true in a terminal and then start FreeCAD from there. To avoid to do this all the time I recommend to create a FreeCAD.desktop file and set the variable inside there [1]. I do not know if this will be fixed any time soon but what I know for sure is that it's not a FreeCAD bug. [1] https://askubuntu.com/questions/144968/set-variable-in-desktop-file |
Closing ticket |
| 2018-12-18 04:21 | terrysbestfriend | New Issue | |
| 2018-12-18 11:39 | Kunda1 | Note Added: 0012299 | |
| 2018-12-18 11:41 | Kunda1 | Relationship added | related to 0003717 |
| 2018-12-18 11:41 | Kunda1 | Note Added: 0012300 | |
| 2018-12-18 13:47 | wmayer | Note Added: 0012302 | |
| 2018-12-19 09:23 | Kunda1 | Status | new => closed |
| 2018-12-19 09:23 | Kunda1 | Resolution | open => no change required |
| 2018-12-19 09:23 | Kunda1 | Note Added: 0012309 | |
| 2018-12-19 09:24 | Kunda1 | Note Edited: 0012309 |
