| 0003795 | FreeCAD | Feature | public | 2019-01-25 22:02 | 2021-11-23 21:38 |
| Reporter | markus51 | Assigned To | openBrain | ||
| Status | feedback | Resolution | reopened | ||
| OS | Windows | ||||
| Summary | 0003795: Input of floating point values with point ('.') instead of comma (',') | ||||
| Description | I use FreeCad 0.17 with Win7, in Germany. The country settings uses a comma (',') for floating point values. Many peoples usees a point to input floating point valuses, but FreeCad needs sometimes a comma, or sometimes are comma and points allowed. Combo-View/Model: only comma Combo-View/Tracks/Constaints: only comma Spreadsheet: comma and points I would be nice when always both floating formats will be accepted. | ||||
| Steps To Reproduce | 1.) Create a new sketch and add some constraints with a length 2.) Double click in Combo-View/Tracks/Constraints on the new item 3.) Input "12.3" and press ENTER 4.) The new value is "123" instead of "12.3" 11.) Create a new sketch and add some constraints with a length 12.) Double click in Combo-View/Model on a Constraint 13.) Input "12.3" and press ENTER 14.) The new value is "123" instead of "12.3" | ||||
| Tags | units | ||||
|  | @markus51 Have you tested first in 0.18dev before posting (as we ask in the enormous yellow banner at the top of the page)? We also ask very clearly at the top of the page not to post bugs (especially v0.17) unless they are verified in the forum. Please download 0.18dev and verify 0003794 0003795 0003796 |
|  | The same problem exists on version 0.18dev |
|  | As a new user I stumbled over the same problem. I get this with: OS: Windows 7 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.18.15711 (Git) Build type: Release Branch: master Hash: 5caae5f430237a73cd17e283d45b3ac9ab005feb Python version: 2.7.14 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 7.2.0 Locale: German/Germany (de_DE) |
|  | CC @wmayer |
|  | When using a standard QDoubleSpinBox from the Qt library then it also changes the number to 123 when you enter 12.3. This is because a dot in German locale is the group separator and not a decimal separator and the dot is only a visual aid for the user. When the user leaves the widget then it automatically removes the dot. The QuantitySpinBox is a FreeCAD widget and follows the same logic as Qt's QDoubleSpinBox. So, there is no need to change anything with the current behaviour. |
|  | I have fixed this ugly stuf in my private version (only 30 min work) Now point and comma will be accepted. That is user-friendliness ! |
|  | > Now point and comma will be accepted. Very good. However I learned meanwhile that some German users use the dot to separate thousands. E.g. they input "18.000" and don't want to have it treated as "18,000" but as "18000". Therefore I understand @wmayer that FC should not add a workaround but let Qt do the job. |
|  | German bakers usualy use the comma and sometimes a point to separate thousands. German engineers use in the most cases the point. The geraman technical software which is writen in my company also uses the point for floating point values. Other technical software from other companies usualy to the same. If we talk about financial software, you're right. In technical software, it looks a little different. |
|  | > If we talk about financial software, you're right. In technical software, it looks a little different. I recently realized that my engineer colleagues use µm as base unit instead of mm because we build microsystems. Always entering values like "0,060" annoyed them. So now they can write simply "60" and if there is a mm length, they then write 12.000. Many engineering software offers to use the decimal separator of the UI language. That is why I did not yet noticed that - I use in most cases the English UI. Yesterday I made a test and setting the UI to German I have to use the comma. So things are changing in the software development and I think it makes sense to consistently follow the rules of the language. The same is with FC. Use the English locale and you can use the dot as decimal separator. Therefore I vote to mark this issue as already fixed since you can use FC with English UI andg get the dot as you like. |
|  | It's user-friendly for you personally but this does not mean that's user-friendly for everybody and it's at the cost of consistency. Then in FreeCAD in dozens of places Qt's QDoubleSpinBox is used which strictly follows the locale settings of the OS. How do you deal with this, then? |
|  | @wmayer I notice that there is an inconsistency because in tables FC automatically changes inputs like "2,3" to "2.3". Should I open a new tracker issue for that? |
|  | > Should I open a new tracker issue for that? I did it: 0003875 Since the spreadsheet issue is now covered I think this bug report could be closed. |
|  | Closing ticket |
|  | The discussion about this popped up again: https://forum.freecadweb.org/viewtopic.php?f=3&t=35927 thus reopen the ticket for now. |
|  | Was there any decision made for this? @openBrain, do you maybe know something since you are assigned to a related bug? |
|  | @uwestoehr : yes, the PR that was pending has been integrated and I required for testing here : https://forum.freecadweb.org/viewtopic.php?f=8&t=62546 AFAIK there is no regression declared ATM, but the fix may still be a bit incomplete. From the feedback, it works well for QSpinBox-like widgets, but not for example for Gui::InputField type. I have to investigate to be sure this latter type can only hold "formulas" but no "expressions" before I extend the fix. |
|  | Thanks for your work! > it works well for QSpinBox-like widgets Not for me, I reported this now in the forum thread to be discussed further. |
|  | @uwestoehr : new version has been integrated in daily that should work well in all situations. You can test again and report if needed. ;) |
|  | How can I test this? I added the Boolean "SubstituteDecimalSeparator" under General in the parameters, then restarted FC but cannot see any difference. So e.g. an input of "3,0" results in 3 mm, but "3.0" results in 30 mm. (By the way, reading my own statements from years ago, it is interesting how I changed my mind.) |
|  | This ticket has been migrated to GitHub as issue 5871. |
| 2019-01-25 22:02 | markus51 | New Issue | |
| 2019-01-25 23:16 | Kunda1 | Status | new => feedback |
| 2019-01-25 23:16 | Kunda1 | Note Added: 0012517 | |
| 2019-01-25 23:16 | Kunda1 | Note Added: 0012518 | |
| 2019-01-28 12:38 | markus51 | Note Added: 0012540 | |
| 2019-01-28 12:38 | markus51 | Status | feedback => new |
| 2019-01-28 13:04 | uwestoehr | Note Added: 0012542 | |
| 2019-01-29 18:13 | Kunda1 | Tag Attached: units | |
| 2019-01-29 18:17 | Kunda1 | Note Added: 0012553 | |
| 2019-02-21 16:48 | wmayer | Note Added: 0012714 | |
| 2019-02-21 19:01 | markus51 | Note Added: 0012718 | |
| 2019-02-22 00:20 | uwestoehr | Note Added: 0012722 | |
| 2019-02-23 12:30 | markus51 | Note Added: 0012729 | |
| 2019-02-24 00:23 | uwestoehr | Note Added: 0012735 | |
| 2019-02-24 17:48 | wmayer | Note Added: 0012753 | |
| 2019-02-24 18:15 | uwestoehr | Note Added: 0012758 | |
| 2019-03-01 15:02 | uwestoehr | Note Added: 0012815 | |
| 2019-03-02 02:01 | Kunda1 | Relationship added | related to 0003875 |
| 2019-03-12 02:30 | Kunda1 | Status | new => closed |
| 2019-03-12 02:30 | Kunda1 | Resolution | open => fixed |
| 2019-03-12 02:30 | Kunda1 | Note Added: 0012892 | |
| 2020-03-24 13:23 | uwestoehr | Assigned To | => uwestoehr |
| 2020-03-24 13:23 | uwestoehr | Status | closed => feedback |
| 2020-03-24 13:23 | uwestoehr | Resolution | fixed => reopened |
| 2020-03-24 13:23 | uwestoehr | Note Added: 0014278 | |
| 2020-03-24 13:26 | uwestoehr | Relationship added | has duplicate 0003963 |
| 2020-03-24 13:57 | openBrain | Relationship deleted | has duplicate 0003963 |
| 2020-03-24 13:57 | openBrain | Relationship added | related to 0003963 |
| 2021-11-02 14:57 | uwestoehr | Note Added: 0016006 | |
| 2021-11-02 17:35 | openBrain | Note Added: 0016008 | |
| 2021-11-02 18:30 | uwestoehr | Note Added: 0016009 | |
| 2021-11-02 18:30 | uwestoehr | Note Edited: 0016009 | |
| 2021-11-02 19:14 | uwestoehr | Assigned To | uwestoehr => openBrain |
| 2021-11-16 17:54 | openBrain | Note Added: 0016033 | |
| 2021-11-23 21:38 | uwestoehr | Note Added: 0016051 |
