| 0003796 | FreeCAD | Bug | public | 2019-01-25 22:10 | 2021-12-16 21:35 |
| Reporter | markus51 | Assigned To | abdullah | ||
| OS | Win7 | ||||
| Summary | 0003796: Shortcuts "V1" .. "V7" to change the "Draw-Style" didn't work in sketch view | ||||
| Description | The shortcuts "V1" .. "V7" to change the "Draw-Style" didn't work in the sketch view. When i change to "Part Design" the shortcuts "V1" .. "V7" working correctly. | ||||
| Steps To Reproduce | 1.) Open a sketch. 2.) Press "V"+"1" --> the "Draw-Style" din't change 3.) Press "V"+"4" --> the "Draw-Style" din't change 4.) Change in the toolbar to "Part Design" 5.) Press "V"+"1" --> the "Draw-Style" changes correctly 6.) Press "V"+"4" --> the "Draw-Style" changes correctly | ||||
| Tags | shortcuts | ||||
|  | @markus51 Have you tested first in 0.18dev before posting (as we ask in the enormous yellow banner at the top of the page)? We also ask very clearly at the top of the page not to post bugs (especially v0.17) unless they are verified in the forum. Please download 0.18dev and verify 0003794 0003795 0003796 |
|  | The same problem exists on version 0.18dev |
|  | Making an 0.18 target. Devs please review (and decide if it should be in the 0.18 or 0.19 roadmap) Thanks. |
|  | This is because the shortuct key "V" is used by the vertical constraint. So V1, V2... never happens. I don't see any obvious solution here, either remap V1-->V7 to something else or remap V to something else... |
|  | Because the "V" shortcut is a subset of the "V + n" (with n = 1, 2, 3, ...) shortcut, I am thinking that we might need to have a look at the activatedAmbiguously QT signal. Maybe this will give more insight. Perhaps it is triggered, but no SLOT is attached? I'd like to test this out myself, but after having tried to compile + debug run the current FreeCAD 0.18 version multiple times today (Windows 10 + VS 2013 + libpack), I am done for today :) |
|  | These no longer map to the vertical constraints, but are now being used for the view orientation. This is still not the "draw style", however. |
|  | This ticket has been migrated to GitHub as issue 5872. |
| 2019-01-25 22:10 | markus51 | New Issue | |
| 2019-01-25 23:22 | Kunda1 | Status | new => feedback |
| 2019-01-25 23:22 | Kunda1 | Note Added: 0012519 | |
| 2019-01-28 12:00 | markus51 | Note Added: 0012538 | |
| 2019-01-28 12:00 | markus51 | Status | feedback => new |
| 2019-01-29 18:19 | Kunda1 | Target Version | => 0.18 |
| 2019-01-29 18:19 | Kunda1 | Note Added: 0012554 | |
| 2019-02-20 13:18 | yorik | Note Added: 0012704 | |
| 2019-02-22 23:10 | Dargazo | Note Added: 0012728 | |
| 2019-02-23 23:52 | wmayer | Target Version | 0.18 => 0.19 |
| 2020-01-16 17:32 | Kunda1 | Tag Attached: shortcuts | |
| 2021-08-27 13:36 | chennes | Relationship added | related to 0004220 |
| 2021-08-27 13:36 | chennes | Assigned To | => chennes |
| 2021-08-27 13:36 | chennes | Status | new => assigned |
| 2021-08-27 13:36 | chennes | Status | assigned => confirmed |
| 2021-12-16 21:33 | chennes | Note Added: 0016104 | |
| 2021-12-16 21:34 | chennes | Assigned To | chennes => abdullah |
| 2021-12-16 21:35 | chennes | Relationship added | has duplicate 0004644 |
