| 0003798 | FreeCAD | Feature | public | 2019-01-26 11:19 | 2021-02-06 06:50 |
| Reporter | markus51 | Assigned To | |||
| Priority | low | Severity | tweak | Reproducibility | always |
| Summary | 0003798: Improve the "Sketch select" dialog of the "Map a sketch to a face" commando | ||||
| Description | When you have a lot of sketches, then it isn't easy to find the wanted sketch in the "Sketch select" dialog of the "Map a sketch to a face" commando. 1.) Increase the size of the dropdown list of the combobox to see more sketches (a double size will be goot) 2.) Add a check box "Alphabetical sort", when this box is selected then the entries in the dropdown list of the combobox will be sorted. 3.) Add an edit field "Filter", when this field isn't empty only entries those contains the filter text are shown in the list of the combobox. 4.) It will be good when the "Sketch select" dialog remembers the last settings (Filter+Sort) of the last call. | ||||
| Steps To Reproduce | 1.) Goti "Pard Desingn" 2.) Select a plane on your model 3.) Press "Map a sketch to a face" in the toolbar | ||||
Where is the forum post discussing this with the community? Please follow the tracker guidelines. Thanks you for your comprehension |
I have implemened this feature in my private version. It is faster to do such improvements by my own, than discuss it on this forum ! |
> I have implemented this feature in my private version. It would be nice if FC and user like me could benefit from this. Could you therefore open a forum thread and make a pull request so that your improvement could go in? |
@markus51 "Alone you go faster. Together we go farther" |
This ticket has been migrated to GitHub as issue 5874. |
| 2019-01-26 11:19 | markus51 | New Issue | |
| 2019-01-29 18:11 | Kunda1 | Status | new => feedback |
| 2019-01-29 18:11 | Kunda1 | Note Added: 0012549 | |
| 2019-02-21 19:04 | markus51 | Note Added: 0012719 | |
| 2019-02-21 19:04 | markus51 | Status | feedback => new |
| 2019-02-22 00:16 | uwestoehr | Note Added: 0012721 | |
| 2019-02-22 12:03 | Kunda1 | Note Added: 0012725 | |
