| 0003803 | Sketcher | Feature | public | 2019-01-27 11:17 | 2022-01-24 20:57 |
| Reporter | markus51 | Assigned To | |||
| Priority | low | Severity | tweak | Reproducibility | always |
| OS | Win7 | ||||
| Summary | 0003803: Improvement of "Constraints" list in the Sketch task of the "Combo view" | ||||
| Description | Some features to improve the "Constraints" list. 1.) Add a "Hide all constraints" to the "Constraints" listbox 2.) Add a "Show all constraints" to the "Constraints" listbox 3.) Add a shortcut Cltr+A to select all item in the "Constraints" listbox 4.) Add a shortcut Cltr+A to select all item in the "Elements" listbox | ||||
| Steps To Reproduce | 1.) Create a new sketch 2.) Draw some elemnts 3.) Goto the "Combo view" (in "Sketcher") 4.) Open the task tab | ||||
| Tags | #post-to-forum, UI | ||||
Where is the forum thread? JFYI, tickets like this will get lost if they aren't discussed in the forum. The community decides if a ticket should be opened. Thank you for your comprehension. |
@abdullah Can I move this to 'Sketcher' ? |
@kunda1 Sure. It is sketcher. I have just moved it. |
@kunda1 @markus51 There are a couple of aspects that would benefit from community discussion: 1) Selection of all elements via language dependent shortcut (e.g. ctrl+A) normal list shortcuts are disabled, as the lists are intended to interact with the keyboard commands of the sketcher. The checkbox in the constraints is specific to visibility, not selection. This has to be taken into account. However, it may be possible to add a button to select all items. Maybe a context menu entry. Here I think UI experts, which I am not, could have interesting ideas/alternatives. 2)If by "constraints listbox" the context menu of the constraints is intended, it is very easy to add. Again, maybe UI experts come with a better usability solution. It would not be the first time I propose a UI and people come with great enriching ideas. I have learnt to leverage the knowledge of the community in this cases. I think it is important it gets discussed. |
This ticket has been migrated to GitHub as issue 5877. |
| 2019-01-27 11:17 | markus51 | New Issue | |
| 2019-01-29 18:30 | Kunda1 | Status | new => feedback |
| 2019-01-29 18:30 | Kunda1 | Note Added: 0012558 | |
| 2019-01-29 18:30 | Kunda1 | Note Edited: 0012558 | |
| 2019-04-06 19:05 | Kunda1 | Note Added: 0013004 | |
| 2019-04-12 17:15 | abdullah | Product Version | => 0.19 |
| 2019-04-12 17:15 | abdullah | Target Version | => 0.19 |
| 2019-04-12 17:15 | abdullah | Project | FreeCAD => Sketcher |
| 2019-04-12 17:16 | abdullah | Note Added: 0013024 | |
| 2019-06-20 06:38 | Kunda1 | Summary | Improvement of "Contraints" list in the Sketch task of the "Combo view" => Improvement of "Constraints" list in the Sketch task of the "Combo view" |
| 2019-06-20 06:38 | Kunda1 | Description Updated | |
| 2019-06-20 06:39 | Kunda1 | Tag Attached: UI | |
| 2019-06-22 05:58 | abdullah | Note Added: 0013290 | |
| 2020-11-12 13:26 | Kunda1 | Description Updated | |
| 2022-01-24 20:57 | Kunda1 | Tag Attached: #post-to-forum |
