| 0003805 | FreeCAD | Bug | public | 2019-01-27 21:25 | 2019-02-21 17:50 |
| Reporter | markus51 | Assigned To | wmayer | ||
| OS | Win7 | ||||
| Summary | 0003805: After "Create a hole with the selected sketch" the model disapers | ||||
| Description | Sometimes when i use "Create a hole with the selected sketch" in the "Part Design" the model disapers after the call. *) The sketch is on the correct plane *) In a previously state the same setting of "Create a hole with the selected sketch" working fine. *) When i remove the current hole item, and create a hole item with the same settings, all works fine. | ||||
| Steps To Reproduce | 1.) Open "Error-BaseHoles002.FCStd" with FreeCAD 0.17 (Revisionnamber 13541) 2.) Goto PartDesign 3.) Open the "Combo-View" at "Model" 4.) Do a double click on the sketch "BaseHoles002S" 5.) You see the sketch is on correct plane 6.) Close the sketch 7.) Do a double click on the hole item "BaseHoles002" and press "OK" 8.) The model disapears 9.) Goto "Combo-View / Model" 10.) Select the hole item "BaseHoles002" 11.) Press DEL and remove "BaseHoles002" 12.) Select the the sketch "BaseHoles002S" 13.) Press in the toolbar "Create a hole with the selected sketch" 14.) Input the same hole parameters - Diameter=8 - Type=CounterSink - Type/Diameter=Settings.SinkDiameter 15.) Press OK above the "Hole Parameters" 16.) The new hole item works fine, but it has the same parameters as the old one which didn't worked. (see Info.png) | ||||
The same problem exists on version 0.18dev |
Where is the forum post discussing this with the community? Please follow the tracker guidelines. Thanks you for your comprehension CC @wmayer care to weigh in? |
This is not a bug at all. In the model tree you have made visible the object ProfilLands002 instead of BaseHoles002. |
The only issue is that when double-clicking BaseHoles002 and pressing OK that it doesn't show the model. This is only very minor issue. |
https://github.com/FreeCAD/FreeCAD/commit/2fcb7cb644a866a01532c82065a7a2433239b60e |
| 2019-01-27 21:25 | markus51 | New Issue | |
| 2019-01-27 21:25 | markus51 | File Added: Error-BaseHoles002.FCStd | |
| 2019-01-27 21:25 | markus51 | File Added: Info.png | |
| 2019-01-28 12:49 | markus51 | Note Added: 0012541 | |
| 2019-01-29 18:16 | Kunda1 | Note Added: 0012552 | |
| 2019-01-29 18:16 | Kunda1 | Status | new => feedback |
| 2019-02-21 17:00 | wmayer | Note Added: 0012715 | |
| 2019-02-21 17:03 | wmayer | Severity | major => tweak |
| 2019-02-21 17:03 | wmayer | Note Added: 0012716 | |
| 2019-02-21 17:50 | wmayer | Assigned To | => wmayer |
| 2019-02-21 17:50 | wmayer | Status | feedback => closed |
| 2019-02-21 17:50 | wmayer | Resolution | open => fixed |
| 2019-02-21 17:50 | wmayer | Fixed in Version | => 0.18 |
| 2019-02-21 17:50 | wmayer | Note Added: 0012717 |
