| 0003982 | Path | Bug | public | 2019-05-19 11:42 | 2019-06-19 01:39 |
| Reporter | scholli | Assigned To | russ4262 | ||
| Summary | 0003982: base object jumps out of position while trying to create a pocket operation | ||||
| Description | https://forum.freecadweb.org/viewtopic.php?f=15&t=36507 | ||||
| Steps To Reproduce | choose bottom of pocket in object create pocket operation apply --> object changes position in space | ||||
| Tags | Path | ||||
Proposed PR 2231 addresses this issue. Upon merging of the PR, this issue will be resolved. |
Lets see if the source integration plugin for the bugtracker is working again. FreeCAD Pull Request 2231 |
@russ4262 FYI, you can use https://freecadweb.org/wiki/tracker#GitHub_and_MantisBT to remotely reference of close tickets in the bugtracker from github. Cheers! |
Ticket status set to 'assigned' |
@Kunda1 In my account, I do not see any way to mark this as resolved or fixed. This issue is now fixed. PR 2231 has been committed. Thank you, Sir. |
Thanks to the FC community for your reporting, testing, feedback, and patience to correct this issue. Fixed as of pre_0.19.17065 release. |
FreeCAD: master f57f3d73 2019-06-17 16:10:28 Committer: GitHub Details Diff |
Merge pull request 0002231 from Russ4262/pathpocketshape_fix Path: PocketShape - Fix repositioning of Job model; ProfileFaces - add 4th-axis feature |
Affected Issues 0003982 |
| mod - src/Mod/Path/PathScripts/PathAreaOp.py | Diff File | ||
| mod - src/Mod/Path/PathScripts/PathPocketShape.py | Diff File | ||
| mod - src/Mod/Path/PathScripts/PathProfileFaces.py | Diff File | ||
| 2019-05-19 11:42 | scholli | New Issue | |
| 2019-05-19 11:42 | scholli | Tag Attached: Path | |
| 2019-06-13 21:25 | russ4262 | Note Added: 0013205 | |
| 2019-06-13 21:28 | russ4262 | Note Edited: 0013205 | |
| 2019-06-13 22:43 | Kunda1 | Note Added: 0013207 | |
| 2019-06-13 22:45 | Kunda1 | Note Added: 0013208 | |
| 2019-06-13 22:46 | Kunda1 | Status | new => assigned |
| 2019-06-13 22:46 | Kunda1 | Note Added: 0013209 | |
| 2019-06-13 22:46 | Kunda1 | Target Version | => 0.19 |
| 2019-06-18 04:28 | russ4262 | Note Added: 0013245 | |
| 2019-06-18 07:31 | Kunda1 | Assigned To | => russ4262 |
| 2019-06-18 07:32 | Kunda1 | Changeset attached | => FreeCAD master f57f3d73 |
| 2019-06-19 01:39 | russ4262 | Status | assigned => closed |
| 2019-06-19 01:39 | russ4262 | Resolution | open => fixed |
| 2019-06-19 01:39 | russ4262 | Fixed in Version | => 0.19 |
| 2019-06-19 01:39 | russ4262 | Note Added: 0013259 |
