| 0004001 | Sketcher | Bug | public | 2019-06-05 23:02 | 2020-10-25 15:13 |
| Reporter | uwestoehr | Assigned To | uwestoehr | ||
| Summary | 0004001: Sketcher trimming issue with arcs | ||||
| Description | When trimming 2 intersecting arcs the trimming fails when the endpoint of one arc is coincident with the second arc. Moreover the trimming cannot be undone. To reproduce open the attached file and trim the upper ends of the arcs so that only one arc segment would be left. The interesting thing is that the result cannot be foreseen and that in all cases the trimming cannot be undone. Here is one try: but sometimes I end up with 2 arc segments not intersecting each other but being connected in one point. | ||||
| Additional Information | Forum thread: https://forum.freecadweb.org/viewtopic.php?p=311853 Confirmed by @abdullah OS: Windows 7 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.18.16117 (Git) Build type: Release Branch: releases/FreeCAD-0-18 Hash: dbb4cc6415bac848a294f03b80f65e888d531742 Python version: 3.6.6 Qt version: 5.6.2 Coin version: 4.0.0a OCC version: 7.3.0 Locale: German/Germany (de_DE) | ||||
| Tags | OCC 7.4, sketcher, undo, upstream | ||||
As stated in the forum thread the missing undo is a FreeCAD bug independent of OCCT and should be fixed in any case. |
@abdullah, should I open a separate bug for the undo issue? |
@uwestoehr did you ever get a response from abdullah on this ? When you do please link said ticket to this one. Thanks! |
PR for the undo part: https://github.com/FreeCAD/FreeCAD/pull/3514 The special handling I leave it for when OCCT fixes their routine, as the work-around code is already convoluted enough. |
Many thanks. I can confirm that undo works now fine. |
With current FC 0.19 and OCC 7.4.0 I can no longer reproduce the bug. |
Obviously this OCC issue has been fixed in OCC 7.4 |
Also FreeCAD master 6f3160db |
Closing ticket |
FreeCAD: master 6f3160db 2020-05-26 15:18:33 Committer: abdullahtahiriyo Details Diff |
Sketcher: Enable undo when trimming =================================== Reported here: https://forum.freecadweb.org/viewtopic.php?p=311853#p312647 |
Affected Issues 0004001 |
| 2019-06-05 23:02 | uwestoehr | New Issue | |
| 2019-06-05 23:02 | uwestoehr | Tag Attached: sketcher | |
| 2019-06-05 23:02 | uwestoehr | File Added: Sketch-cut-problem.FCStd | |
| 2019-06-05 23:03 | uwestoehr | File Added: Trimming-Bug1.gif | |
| 2019-06-05 23:04 | uwestoehr | Description Updated | |
| 2019-06-06 22:53 | uwestoehr | Note Added: 0013154 | |
| 2019-06-06 22:54 | uwestoehr | Tag Attached: undo | |
| 2019-06-17 10:06 | uwestoehr | Additional Information Updated | |
| 2019-06-25 23:24 | uwestoehr | Note Added: 0013312 | |
| 2019-08-23 02:50 | Kunda1 | Note Added: 0013460 | |
| 2019-08-23 02:51 | Kunda1 | Target Version | => 0.19 |
| 2020-05-26 15:30 | abdullah | Note Added: 0014427 | |
| 2020-05-31 01:42 | uwestoehr | Note Added: 0014449 | |
| 2020-10-24 22:09 | uwestoehr | Note Added: 0014946 | |
| 2020-10-24 22:10 | uwestoehr | Assigned To | => uwestoehr |
| 2020-10-24 22:10 | uwestoehr | Status | new => resolved |
| 2020-10-24 22:10 | uwestoehr | Resolution | open => fixed |
| 2020-10-24 22:10 | uwestoehr | Note Added: 0014947 | |
| 2020-10-25 15:11 | Kunda1 | Tag Attached: upstream | |
| 2020-10-25 15:11 | Kunda1 | Tag Attached: OCC 7.4 | |
| 2020-10-25 15:12 | Kunda1 | Note Added: 0014951 | |
| 2020-10-25 15:12 | Kunda1 | Changeset attached | => FreeCAD master 6f3160db |
| 2020-10-25 15:13 | Kunda1 | Status | resolved => closed |
| 2020-10-25 15:13 | Kunda1 | Note Added: 0014952 |
