| 0004054 | Sketcher | Bug | public | 2019-07-12 22:48 | 2020-06-05 17:23 |
| Reporter | uwestoehr | Assigned To | abdullah | ||
| Summary | 0004054: lengths in reference mode length are treated redundant | ||||
| Description | - open this file: https://forum.freecadweb.org/download/file.php?id=87537 - open Sketch002 - assure that you use the option "Auto update" - constrain the circle with a reference mode diameter or radius result: the reference mode radius is reported as redundant. Here is the screencast: https://forum.freecadweb.org/download/file.php?id=87538 The reference mode does not set that the circle should have a certain radius, but measures its current radius. Therefore is is not a redundant diameter. The bug only occurs when the option "Auto update" is used. To get rid of the wrong redundancy message one must press the "Update" button. But the option "Auto update" should do exactly this automatically. | ||||
| Additional Information | I think this bug is different than the existing bug 0003529. Forum thread: https://forum.freecadweb.org/viewtopic.php?f=3&t=37669 Bug is in 0.18 and 0.19: OS: Windows 7 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.17331 (Git) Build type: Release Branch: master Hash: cf18161dc26267c259ac21675cb9637263bf4152 Python version: 3.6.6 Qt version: 5.6.2 Coin version: 4.0.0a OCC version: 7.3.0 Locale: German/Germany (de_DE) | ||||
| Tags | sketcher | ||||
Set 0.19 target |
https://github.com/FreeCAD/FreeCAD/pull/3520 |
git commit 0c5fc74e352cde5633d50bfb1c8c43dd1a507696 |
FreeCAD: master 0c5fc74e 2020-05-28 15:07:30 Committer: abdullahtahiriyo Details Diff |
Sketcher: Fixing Driving constraint apparent redundancy ======================================================= When adding a reference constraint of type radius or diameter to an external geometry using the method of select the continuous mode method (select tool first, click geometry afterwards), with ActiveUpdate checked, there was a missing solving to bring the solver information in line with the Driven constraint. fixes 0004054 |
Affected Issues 0004054 |
| mod - src/Mod/Sketcher/Gui/CommandConstraints.cpp | Diff File | ||
| 2019-07-12 22:48 | uwestoehr | New Issue | |
| 2019-07-12 22:48 | uwestoehr | Tag Attached: sketcher | |
| 2019-08-23 02:56 | Kunda1 | Relationship added | related to 0003529 |
| 2019-08-23 03:00 | Kunda1 | Target Version | => 0.19 |
| 2019-08-23 03:00 | Kunda1 | Note Added: 0013462 | |
| 2020-05-28 16:45 | abdullah | Note Added: 0014433 | |
| 2020-05-29 12:25 | abdullah | Assigned To | => abdullah |
| 2020-05-29 12:25 | abdullah | Status | new => closed |
| 2020-05-29 12:25 | abdullah | Resolution | open => fixed |
| 2020-05-29 12:25 | abdullah | Fixed in Version | => 0.19 |
| 2020-05-29 12:25 | abdullah | Note Added: 0014436 | |
| 2020-06-05 17:23 | abdullah | Changeset attached | => FreeCAD master 0c5fc74e |
| 2020-06-05 17:23 | abdullah | Note Added: 0014483 |
