| 0004229 | FreeCAD | Bug | public | 2019-12-19 16:49 | 2020-08-26 12:00 |
| Reporter | lonaowna | Assigned To | |||
| Summary | 0004229: Compilation fails with PySide2 5.14: PYSIDE2RCCBINARY missing | ||||
| Description | PySide2 5.14 has removed the pyside2-rcc binary. Similar function is now provided by the rcc binary. See upstream patch. The cMake/FindPySide2Tools.cmake script should be updated to accept the new rcc as replacement for pyside2-rcc. Currently it fails with the following message: [ 4%] Generating Material_rc.py /bin/sh: PYSIDE2RCCBINARY-NOTFOUND: command not found | ||||
| Tags | upstream | ||||
| FreeCAD Information | -- Build type: Release -- Compiler: /usr/bin/c++ (9.2.0) -- Flags: -Wall -Wextra -Wno-write-strings -march=x86-64 -mtune=generic -O2 -pipe -fno-plt -- Python: [/usr/bin/python3] [.cpython-38-x86_64-linux-gnu] -- PCL: not enabled -- pybind11: not enabled -- Boost: 1.71.0 -- XercesC: [/usr/lib/libxerces-c.so] [/usr/include] -- ZLIB: 1.2.11 -- PyCXX: [/home/sebas/abs/freecad-git/src/freecad-git/src] -- OCC: 7.4.0 [TKFillet;TKMesh;TKernel;TKG2d;TKG3d;TKMath;TKIGES;TKSTL;TKShHealing;TKXSBase;TKBin;TKBool;TKBO;TKCDF;TKBRep;TKTopAlgo;TKGeomAlgo;TKGeomBase;TKOffset;TKPrim;TKSTEP;TKSTEPBase;TKSTEPAttr;TKHLR;TKFeat] -- SMESH: build internal -- MEDFile: [/usr/lib/libmedC.so;/usr/lib/libmed.so] [/usr/include] -- HDF5: 1.10.5 -- VTK: 8.2.0 -- NETGEN: not enabled -- SWIG: 4.0.1 -- Eigen3 3.3.7 -- Qt5Core: 5.14.0 -- Qt5Network: 5.14.0 -- Qt5Xml: 5.14.0 -- Qt5XmlPatterns: 5.14.0 -- Qt5Widgets: 5.14.0 -- Qt5PrintSupport: 5.14.0 -- Qt5OpenGL: 5.14.0 -- Qt5Svg: 5.14.0 -- Qt5UiTools: 5.14.0 -- Qt5Concurrent: 5.14.0 -- Qt5WebKitWidgets: 5.212.0 -- Shiboken2: 5.14.0 [/usr/lib64/cmake/Shiboken2-5.14.0] [/usr/include/shiboken2;/usr/include/python3.8] -- PySide2: 5.14.0 [/usr/include/PySide2] -- PySide2Tools: not found -- Freetype: 2.10.1 -- OpenGLU: /usr/lib/libGLU.so [/usr/lib/libGLU.so][/usr/include] -- Coin3D: [Coin] [] -- SPNAV: [/usr/lib/libspnav.so] [/usr/include] -- Matplotlib: 3.1.1 -- Rift: not enabled (BUILD_VR) -- Doxygen: not found | ||||
I submitted a patch (PR FreeCAD Pull Request 2846), hope it will work... |
Once this PR is merged, please test 0004195 as well? Thanks |
@lonaowna can u test the fix please? |
@Kunda1 everything is working great! Thanks @howetuft |
I've come across this report while trying to build from the latest source. When trying to build I get to [ 44%] Generating Material_rc.py /bin/sh: 1: PYSIDE2RCCBINARY-NOTFOUND: not found make[2]: *** [src/Mod/Material/CMakeFiles/Material.dir/build.make:90: src/Mod/Material/Material_rc.py] Error 127 make[1]: *** [CMakeFiles/Makefile2:3203: src/Mod/Material/CMakeFiles/Material.dir/all] Error 2 make: *** [Makefile:130: all] Error 2 I'm running Ubuntu 20.04 After reading some issues with changes to PySide-tools from Ubuntu 19.10 to 20.04 I decided to compile PySide-tools from the source. I got past this issue by compiling updated pyside-tools and installing, configure and build freecad source. |
I see the same issue on Ubuntu 20.04 /bin/sh: 1: PYSIDE2RCCBINARY-NOTFOUND: not found make[2]: *** [src/Mod/Draft/CMakeFiles/Draft.dir/build.make:970: src/Mod/Draft/Draft_rc.py] Error 127 make[2]: *** Waiting for unfinished jobs.... downloading, compiling and installing from source resolved it for me as well. https://github.com/pyside/pyside2-tools |
Marking this as fixed upstream |
FreeCAD: master 17ed2b19 2019-12-24 15:06:18 Committer: yorik Details Diff |
[Cmake] Update FindPySide2Tools for PySide2 5.14 - issue 0004229 Since PySide2 5.14, 'pyside2-rcc' and 'pyside2-uic' have been renamed into plain 'rcc' and 'uic'. This leads FindPySide2Tools.cmake to no longer find rcc/uic, as reported in bug 0004229 (https://www.freecadweb.org/tracker/view.php?id=4229) and prevents compilation. FindPySide2Tools has been updated accordingly. |
Affected Issues 0004229 |
| mod - cMake/FindPySide2Tools.cmake | Diff File | ||
| 2019-12-19 16:49 | lonaowna | New Issue | |
| 2019-12-28 16:31 | howetuft | Note Added: 0013949 | |
| 2019-12-28 16:32 | howetuft | Note Edited: 0013949 | |
| 2019-12-28 16:35 | howetuft | Note Edited: 0013949 | |
| 2019-12-28 16:38 | howetuft | Note Edited: 0013949 | |
| 2020-01-07 17:08 | Kunda1 | Relationship added | related to 0004195 |
| 2020-01-07 17:12 | Kunda1 | Note Added: 0014011 | |
| 2020-01-07 17:14 | Kunda1 | Status | new => assigned |
| 2020-01-07 17:14 | Kunda1 | Target Version | => 0.19 |
| 2020-01-08 14:20 | yorik | Changeset attached | => FreeCAD master 17ed2b19 |
| 2020-01-10 20:48 | Kunda1 | Note Added: 0014038 | |
| 2020-01-10 21:26 | lonaowna | Note Added: 0014042 | |
| 2020-05-19 14:54 | Aurawin | Note Added: 0014422 | |
| 2020-05-19 18:39 | Aurawin | Note Edited: 0014422 | |
| 2020-07-07 20:59 | maiden | Note Added: 0014632 | |
| 2020-07-07 22:06 | maiden | Note Edited: 0014632 | |
| 2020-07-08 00:46 | Kunda1 | Tag Attached: upstream | |
| 2020-07-08 00:47 | Kunda1 | Status | assigned => resolved |
| 2020-07-08 00:47 | Kunda1 | Resolution | open => fixed |
| 2020-07-08 00:47 | Kunda1 | Note Added: 0014634 | |
| 2020-08-26 12:00 | Kunda1 | Status | resolved => closed |
| 2020-08-26 12:00 | Kunda1 | Fixed in Version | => 0.19 |
