| 0004301 | Draft | Bug | public | 2020-04-03 17:11 | 2020-11-05 12:33 |
| Reporter | clifcox | Assigned To | yorik | ||
| Summary | 0004301: Draft Pattern problem | ||||
| Description | Greetings, There seems to be a regression here between 0.18 (where it works) and 0.19 (where it doesn't). I was following the the draft WB tutorial in the manual when I noticed the problem. Here is the forum discussion: https://forum.freecadweb.org/viewtopic.php?f=23&t=51283 | ||||
| Steps To Reproduce | When I run the example code:
I do get the rectangle filled with the simple pattern in 0.18. If I save that file and try to view it in 0.19 I only get a solid grey filled one, no matter what pattern I try. If I then delete that one and run the python script again (in 0.19), I just get a plain empty rectangle, though the relevant properties are set correctly. | ||||
| Additional Information | The error message seems to come from Coin (pivy), as if the necessary method "removeChild" was removed in a new version of Coin. Or maybe Draft's code was changed. | ||||
| Tags | Coin3d | ||||
| FreeCAD Information | OS: Debian GNU/Linux 10 (buster) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.18. Build type: Release Python version: 2.7.16rc1 Qt version: 5.11.3 Coin version: 4.0.0a OCC version: 7.3.0 Locale: C/Default (C) AND: OS: Debian GNU/Linux 10 (buster) (MATE/lightdm-xsession) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.20325 (Git) Build type: Release Branch: master Hash: 7c9d5fe57c94eeec0289317e6be8a99bdceea11f Python version: 3.7.3 Qt version: 5.11.3 Coin version: 4.0.0a OCC version: 7.3.0 Locale: C/Default (C) | ||||
per @vocx:
Ticket was split off from older thread and is now at https://forum.freecadweb.org/viewtopic.php?f=23&t=51283 |
Fixed with https://github.com/FreeCAD/FreeCAD/commit/5609b38e9a120e20b4917e770138e6bd36cd98a0#diff-78e43e7846dd660f56ed98781e4979e8c2994f99bb2187f4438f41412ba1b254 |
FreeCAD master 5609b38e |
FreeCAD: master 5609b38e 2020-10-12 13:12:50 Details Diff |
Draft: Fixed patterns + added default pattern size pref option |
Affected Issues 0004301 |
| mod - src/Mod/Draft/Resources/ui/preferences-draftvisual.ui | Diff File | ||
| mod - src/Mod/Draft/draftutils/utils.py | Diff File | ||
| mod - src/Mod/Draft/draftviewproviders/view_base.py | Diff File | ||
| 2020-04-03 17:11 | clifcox | New Issue | |
| 2020-04-04 10:56 | Kunda1 | Tag Attached: #pending-forum | |
| 2020-10-18 11:53 | Kunda1 | Note Added: 0014906 | |
| 2020-10-18 11:54 | Kunda1 | Tag Attached: Coin3d | |
| 2020-10-18 11:54 | Kunda1 | Status | new => confirmed |
| 2020-10-18 12:04 | Kunda1 | Note Added: 0014907 | |
| 2020-10-18 12:04 | Kunda1 | Description Updated | |
| 2020-10-19 12:50 | yorik | Assigned To | => yorik |
| 2020-10-19 12:50 | yorik | Status | confirmed => closed |
| 2020-10-19 12:50 | yorik | Resolution | open => fixed |
| 2020-10-19 12:50 | yorik | Fixed in Version | => 0.19 |
| 2020-10-19 12:50 | yorik | Note Added: 0014912 | |
| 2020-11-05 12:32 | Kunda1 | Note Added: 0014963 | |
| 2020-11-05 12:32 | Kunda1 | Changeset attached | => FreeCAD master 5609b38e |
| 2020-11-05 12:33 | Kunda1 | Tag Detached: #pending-forum |
