| 0004352 | FreeCAD | Bug | public | 2020-05-29 02:31 | 2021-03-21 11:17 |
| Reporter | hobbes1069 | Assigned To | |||
| Platform | ALL | ||||
| Summary | 0004352: CMake Install process needs revamping | ||||
| Description | I've posted about this some time ago (i.e. 2011) either to the bug tracker or the forums but that's irrelevant now. It looks like there have been some changes in 0.19 prerelease that seem to move in the right direction but the work is incomplete. My current spec file for Fedora no longer installs files to the correct location and my old method of dumping almost everything into /usr/lib{,64}/freecad no long functions. Having a fully compliant FHS install is long overdue and while I can't find the specific messages anymore, it was promised some time ago. I am submitting this to the issue tracker in hopes of getting the attention it deserves, and part of that is offering my time to help fix it ONLY if there is sufficient interest from the developers. To be honest, I don't have time for this. I'm working on cutting back on my Fedora packaging duties due to $LIFE and $DAYJOB, but I really don't like the way things are right now and am willing to make the short term sacrifice, but again, only if it is taken seriously. 1. For the love of god, please use CMake's GNUInstallDirs module. This will take care of all *Nix systems and maybe others. 2. Unless the libraries produced by FreeCAD are intended for TRULY shared (ie.e. public) consumption, they belong in a private subdir, i.e., /usr/lib{,64}/freecad on RPM (FHS compliant systems), but really all you have to do is append /freecad to CMAKE_INSTALL_LIBDIR if you use GNUInstallDirs, it takes care of the odd Debian tuple location for libraries. Certainly the libraries not prefixed with "lib" can't go into /usr/lib{,64}. There are 93 instances of CMAKE_INSTALL_LIBDIR being used directly based on current master: $ grep -ro CMAKE_INSTALL_LIBDIR | wc -l 93 My recommendation would be instead of sed'ing these all to "CMAKE_INSTALL_LINDIR/freecad" is to replace them with "FREECAD_INSTALL_LIBDIR" and default them to the correct location in one of the helper macros. 3. If you do this, CMake is smart enough to know if the RPATH needs to be set or not, negating the need for all the manual RPAH handling. 4. All no-arch data does belong in /usr/share, but it ALSO needs to be in a "freecad" subdirectory. Currently if I don't override it a lot of stuff is dumped directly into /usr/share, like some of the Mod python files. It can be handled similarly to 0000002. Also, I haven't dug into it enough to know it's not being done correctly but stuff in /usr/share REALLY needs to be noarch. Meaning it's EXACTLY the same if its i686, x86_64, ppc64le, s390x, arm, etc. Now that I actually cut out the install portion of the build log and sorted it. It's not quite as bad as I thought, but my premis still stands. I'll attach the install portion so you can see where things are being installed when no override is being specified on the command line. | ||||
| Additional Information | Side topic: Maybe it matters for other platforms but I don't understand the overriding the output location of binaries and libraries in cMake/FreeCadMacros.cmake. By default they are created in the same directory they are configured in and CMake can track this just fine. | ||||
| Tags | cmake | ||||
| FreeCAD Information | Master as of 2020-05-28 | ||||
freecad-install.txt (175,253 bytes)
-- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/bin/FreeCAD -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/bin/FreeCADCmd -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Ext/freecad/gui/RemoteDebugger.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Ext/freecad/gui/RemoteDebugger.ui -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Ext/freecad/__init__.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Ext/lazy_loader/__init__.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Ext/lazy_loader/lazy_loader.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Ext/PySide -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Ext/PySide/__init__.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Ext/PySide/QtCore.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Ext/PySide/QtGui.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Ext/PySide/QtSvg.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Ext/PySide/QtUiTools.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/lib64/area.so -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/lib64/DraftUtils.so -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/lib64/DrawingGui.so -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/lib64/Drawing.so -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/lib64/FemGui.so -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/lib64/Fem.so -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/lib64/FreeCADGui.so -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/lib64/FreeCAD.so -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/lib64/ImageGui.so -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/lib64/Image.so -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/lib64/ImportGui.so -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/lib64/Import.so -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/lib64/InspectionGui.so -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/lib64/Inspection.so -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/lib64/libarea-native.so -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/lib64/libDriverDAT.so -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/lib64/libDriver.so -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/lib64/libDriverSTL.so -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/lib64/libDriverUNV.so -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/lib64/libFreeCADApp.so -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/lib64/libFreeCADBase.so -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/lib64/libFreeCADGui.so -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/lib64/libMEFISTO2.so -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/lib64/libSMDS.so -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/lib64/libSMESHDS.so -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/lib64/libSMESH.so -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/lib64/libStdMeshers.so -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/lib64/Measure.so -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/lib64/MeshGui.so -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/lib64/MeshPartGui.so -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/lib64/MeshPart.so -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/lib64/Mesh.so -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/lib64/PartDesignGui.so -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/lib64/_PartDesign.so -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/lib64/PartGui.so -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/lib64/Part.so -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/lib64/PathGui.so -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/lib64/PathSimulator.so -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/lib64/Path.so -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/lib64/PointsGui.so -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/lib64/Points.so -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/lib64/QtUnitGui.so -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/lib64/RaytracingGui.so -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/lib64/Raytracing.so -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/lib64/ReverseEngineeringGui.so -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/lib64/ReverseEngineering.so -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/lib64/RobotGui.so -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/lib64/Robot.so -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/lib64/SketcherGui.so -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/lib64/Sketcher.so -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/lib64/SpreadsheetGui.so -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/lib64/Spreadsheet.so -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/lib64/StartGui.so -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/lib64/Start.so -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/lib64/SurfaceGui.so -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/lib64/Surface.so -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/lib64/TechDrawGui.so -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/lib64/TechDraw.so -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/lib64/WebGui.so -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/lib64/Web.so -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/AddonManager/addonmanager_macro.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/AddonManager/AddonManagerOptions.ui -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/AddonManager/AddonManager.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/AddonManager/AddonManager_rc.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/AddonManager/AddonManager.ui -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/AddonManager/addonmanager_utilities.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/AddonManager/addonmanager_workers.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/AddonManager/InitGui.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/AddonManager/Init.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Arch/ArchAxis.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Arch/ArchBuildingPart.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Arch/ArchBuilding.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Arch/ArchCommands.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Arch/ArchComponent.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Arch/ArchCurtainWall.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Arch/ArchCutPlane.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Arch/ArchEquipment.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Arch/ArchFence.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Arch/ArchFloor.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Arch/ArchFrame.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Arch/ArchIFC.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Arch/ArchIFCSchema.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Arch/ArchIFCView.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Arch/ArchMaterial.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Arch/ArchNesting.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Arch/ArchPanel.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Arch/ArchPipe.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Arch/ArchPrecast.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Arch/ArchProfile.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Arch/ArchProject.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Arch/Arch.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Arch/Arch_rc.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Arch/ArchRebar.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Arch/ArchReference.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Arch/ArchRoof.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Arch/ArchSchedule.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Arch/ArchSectionPlane.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Arch/ArchSite.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Arch/ArchSpace.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Arch/ArchStairs.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Arch/ArchStructure.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Arch/ArchTruss.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Arch/ArchVRM.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Arch/ArchWall.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Arch/ArchWindow.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Arch/Dice3DS/dom3ds.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Arch/Dice3DS/__init__.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Arch/Dice3DS/util.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Arch/exportIFCHelper.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Arch/exportIFC.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Arch/import3DS.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Arch/importDAE.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Arch/importIFCHelper.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Arch/importIFClegacy.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Arch/importIFC.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Arch/importJSON.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Arch/importOBJ.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Arch/importSH3D.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Arch/importSHP.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Arch/importWebGL.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Arch/InitGui.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Arch/Init.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Arch/OfflineRenderingUtils.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Arch/TestArch.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Complete/InitGui.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Complete/Init.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/DraftFillet.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftfunctions/array.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftfunctions/cut.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftfunctions/downgrade.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftfunctions/draftify.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftfunctions/extrude.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftfunctions/fuse.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftfunctions/heal.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftfunctions/__init__.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftfunctions/join.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftfunctions/mirror.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftfunctions/move.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftfunctions/offset.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftfunctions/README.md -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftfunctions/rotate.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftfunctions/scale.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftfunctions/split.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftfunctions/upgrade.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/DraftGeomUtils.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftgeoutils/edges.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftgeoutils/faces.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftgeoutils/general.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftgeoutils/geometry.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftgeoutils/__init__.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftgeoutils/intersections.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftgeoutils/sort_edges.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/DraftGui.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftguitools/gui_annotationstyleeditor.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftguitools/gui_arcs.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftguitools/gui_array_simple.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftguitools/gui_arrays.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftguitools/gui_base_original.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftguitools/gui_base.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftguitools/gui_beziers.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftguitools/gui_circles.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftguitools/gui_circulararray.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftguitools/gui_clone.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftguitools/gui_dimension_ops.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftguitools/gui_dimensions.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftguitools/gui_downgrade.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftguitools/gui_draft2sketch.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftguitools/gui_drawing.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftguitools/gui_edit_arch_objects.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftguitools/gui_edit_draft_objects.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftguitools/gui_edit_part_objects.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftguitools/gui_edit.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftguitools/gui_edit_sketcher_objects.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftguitools/gui_ellipses.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftguitools/gui_facebinders.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftguitools/gui_fillets.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftguitools/gui_grid.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftguitools/gui_groups.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftguitools/gui_heal.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftguitools/gui_join.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftguitools/gui_labels.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftguitools/gui_lineops.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftguitools/gui_lineslope.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftguitools/gui_lines.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftguitools/gui_mirror.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftguitools/gui_move.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftguitools/gui_offset.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftguitools/gui_orthoarray.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftguitools/gui_patharray.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftguitools/gui_planeproxy.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftguitools/gui_pointarray.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftguitools/gui_points.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftguitools/gui_polararray.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftguitools/gui_polygons.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftguitools/gui_rectangles.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftguitools/gui_rotate.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftguitools/gui_scale.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftguitools/gui_selectplane.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftguitools/gui_shape2dview.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftguitools/gui_shapestrings.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftguitools/gui_snapper.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftguitools/gui_snaps.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftguitools/gui_splines.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftguitools/gui_split.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftguitools/gui_stretch.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftguitools/gui_styles.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftguitools/gui_subelements.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftguitools/gui_texts.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftguitools/gui_togglemodes.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftguitools/gui_tool_utils.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftguitools/gui_trackers.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftguitools/gui_trimex.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftguitools/gui_upgrade.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftguitools/gui_wire2spline.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftguitools/__init__.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftguitools/README.md -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/DraftLayer.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftmake/__init__.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftmake/make_arc_3points.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftmake/make_array.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftmake/make_bezcurve.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftmake/make_block.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftmake/make_bspline.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftmake/make_circle.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftmake/make_circulararray.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftmake/make_clone.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftmake/make_copy.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftmake/make_drawingview.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftmake/make_ellipse.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftmake/make_facebinder.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftmake/make_fillet.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftmake/make_line.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftmake/make_orthoarray.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftmake/make_patharray.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftmake/make_pointarray.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftmake/make_point.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftmake/make_polararray.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftmake/make_polygon.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftmake/make_rectangle.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftmake/make_shape2dview.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftmake/make_shapestring.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftmake/make_sketch.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftmake/make_wire.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftmake/make_wpproxy.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftmake/README.md -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftobjects/array.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftobjects/base.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftobjects/bezcurve.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftobjects/block.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftobjects/bspline.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftobjects/circle.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftobjects/clone.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftobjects/dimension.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftobjects/draft_annotation.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftobjects/draftlink.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftobjects/drawingview.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftobjects/ellipse.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftobjects/facebinder.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftobjects/fillet.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftobjects/__init__.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftobjects/label.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftobjects/patharray.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftobjects/pointarray.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftobjects/point.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftobjects/polygon.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftobjects/README.md -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftobjects/rectangle.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftobjects/shape2dview.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftobjects/shapestring.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftobjects/text.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftobjects/wire.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftobjects/wpproxy.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/Draft.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/Draft_rc.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/drafttaskpanels/__init__.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/drafttaskpanels/README.md -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/drafttaskpanels/task_circulararray.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/drafttaskpanels/task_orthoarray.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/drafttaskpanels/task_polararray.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/drafttaskpanels/task_scale.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/drafttaskpanels/task_selectplane.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/drafttaskpanels/task_shapestring.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/drafttests/auxiliary.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/drafttests/draft_test_objects.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/drafttests/__init__.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/drafttests/README.md -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/drafttests/test_airfoildat.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/drafttests/test_creation.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/drafttests/test_dwg.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/drafttests/test_dxf.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/drafttests/test_import_gui.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/drafttests/test_import.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/drafttests/test_import_tools.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/drafttests/test_modification.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/drafttests/test_oca.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/drafttests/test_pivy.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/drafttests/test_svg.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/DraftTools.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftutils/gui_utils.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftutils/init_draft_statusbar.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftutils/__init__.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftutils/init_tools.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftutils/messages.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftutils/README.md -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftutils/todo.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftutils/translate.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftutils/utils.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/DraftVecUtils.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftviewproviders/__init__.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftviewproviders/README.md -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftviewproviders/view_array.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftviewproviders/view_base.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftviewproviders/view_bezcurve.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftviewproviders/view_bspline.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftviewproviders/view_circulararray.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftviewproviders/view_clone.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftviewproviders/view_dimension.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftviewproviders/view_draft_annotation.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftviewproviders/view_draftlink.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftviewproviders/view_facebinder.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftviewproviders/view_fillet.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftviewproviders/view_label.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftviewproviders/view_orthoarray.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftviewproviders/view_point.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftviewproviders/view_polararray.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftviewproviders/view_rectangle.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftviewproviders/view_text.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftviewproviders/view_wire.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/draftviewproviders/view_wpproxy.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/getSVG.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/importAirfoilDAT.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/importDWG.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/importDXF.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/importOCA.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/importSVG.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/InitGui.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/Init.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/TestDraftGui.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/TestDraft.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Draft/WorkingPlane.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Drawing/DrawingExample.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Drawing/DrawingPatterns.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Drawing/DrawingTests.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Drawing/InitGui.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Drawing/Init.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Drawing/README.md -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/coding_conventions.md -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femcommands/commands.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femcommands/__init__.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femcommands/manager.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femexamples/boxanalysis.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femexamples/ccx_cantilever_std.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femexamples/constraint_contact_shell_shell.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femexamples/constraint_contact_solid_solid.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femexamples/constraint_tie.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femexamples/__init__.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femexamples/manager.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femexamples/material_multiple_twoboxes.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femexamples/material_nl_platewithhole.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femexamples/meshes/__init__.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femexamples/meshes/mesh_boxanalysis_tetra10.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femexamples/meshes/mesh_boxes_2_vertikal_tetra10.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femexamples/meshes/mesh_canticcx_hexa20.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femexamples/meshes/mesh_canticcx_tetra10.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femexamples/meshes/mesh_constraint_tie_tetra10.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femexamples/meshes/mesh_contact_box_halfcylinder_tetra10.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femexamples/meshes/mesh_contact_tube_tube_tria3.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femexamples/meshes/mesh_platewithhole_tetra10.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femexamples/meshes/mesh_rc_wall_2d_tria6.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femexamples/meshes/mesh_thermomech_bimetall_tetra10.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femexamples/meshes/mesh_thermomech_flow1d_seg3.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femexamples/meshes/mesh_thermomech_spine_tetra10.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femexamples/rc_wall_2d.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femexamples/thermomech_bimetall.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femexamples/thermomech_flow1d.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femexamples/thermomech_spine.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femguiobjects/__init__.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femguiobjects/readme.md -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femguiutils/selection_widgets.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/feminout/convert2TetGen.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/feminout/importCcxDatResults.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/feminout/importCcxFrdResults.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/feminout/importFenicsMesh.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/feminout/importInpMesh.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/feminout/importPyMesh.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/feminout/importToolsFem.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/feminout/importVTKResults.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/feminout/importYamlJsonMesh.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/feminout/importZ88Mesh.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/feminout/importZ88O2Results.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/feminout/__init__.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/feminout/readFenicsXDMF.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/feminout/readFenicsXML.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/feminout/writeFenicsXDMF.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/feminout/writeFenicsXML.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femmesh/femmesh2mesh.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femmesh/gmshtools.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femmesh/__init__.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femmesh/meshtools.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femobjects/base_fempythonobject.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femobjects/constraint_bodyheatsource.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femobjects/constraint_electrostaticpotential.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femobjects/constraint_flowvelocity.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femobjects/constraint_initialflowvelocity.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femobjects/constraint_selfweight.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femobjects/constraint_tie.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femobjects/element_fluid1D.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femobjects/element_geometry1D.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femobjects/element_geometry2D.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femobjects/element_rotation1D.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femobjects/__init__.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femobjects/material_common.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femobjects/material_mechanicalnonlinear.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femobjects/material_reinforced.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femobjects/mesh_boundarylayer.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femobjects/mesh_gmsh.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femobjects/mesh_group.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femobjects/mesh_region.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femobjects/mesh_result.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femobjects/result_mechanical.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femobjects/solver_ccxtools.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femresult/__init__.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femresult/resulttools.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femsolver/calculix/__init__.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femsolver/calculix/solver.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femsolver/calculix/tasks.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femsolver/calculix/writer.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femsolver/elmer/equations/elasticity.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femsolver/elmer/equations/electricforce.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femsolver/elmer/equations/electrostatic.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femsolver/elmer/equations/equation.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femsolver/elmer/equations/flow.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femsolver/elmer/equations/fluxsolver.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femsolver/elmer/equations/heat.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femsolver/elmer/equations/__init__.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femsolver/elmer/equations/linear.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femsolver/elmer/equations/nonlinear.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femsolver/elmer/__init__.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femsolver/elmer/sifio.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femsolver/elmer/solver.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femsolver/elmer/tasks.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femsolver/elmer/writer.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femsolver/equationbase.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femsolver/fenics/fenics_tools.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femsolver/fenics/__init__.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femsolver/__init__.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femsolver/reportdialog.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femsolver/report.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femsolver/run.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femsolver/settings.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femsolver/signal.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femsolver/solverbase.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femsolver/solver_taskpanel.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femsolver/task.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femsolver/writerbase.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femsolver/z88/__init__.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femsolver/z88/solver.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femsolver/z88/tasks.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femsolver/z88/writer.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femtest/app/__init__.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femtest/app/support_utils.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femtest/app/test_ccxtools.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femtest/app/test_common.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femtest/app/test_femimport.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femtest/app/test_material.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femtest/app/test_mesh.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femtest/app/test_object.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femtest/app/test_open.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femtest/app/test_result.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femtest/app/test_solverframework.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femtest/data/ccx/canti_ccx_faceload_hexa20.inp -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femtest/data/ccx/constraint_contact_shell_shell.FCStd -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femtest/data/ccx/constraint_contact_shell_shell.inp -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femtest/data/ccx/constraint_contact_solid_solid.FCStd -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femtest/data/ccx/constraint_contact_solid_solid.inp -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femtest/data/ccx/constraint_tie.inp -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femtest/data/ccx/cube.FCStd -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femtest/data/ccx/cube_frequency.dat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femtest/data/ccx/cube_frequency_expected_values -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femtest/data/ccx/cube_frequency.FCStd -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femtest/data/ccx/cube_frequency.frd -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femtest/data/ccx/cube_frequency.inp -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femtest/data/ccx/cube_static.dat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femtest/data/ccx/cube_static_expected_values -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femtest/data/ccx/cube_static.FCStd -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femtest/data/ccx/cube_static.frd -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femtest/data/ccx/cube_static.inp -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femtest/data/ccx/Flow1D_thermomech.dat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femtest/data/ccx/Flow1D_thermomech_expected_values -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femtest/data/ccx/Flow1D_thermomech.FCStd -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femtest/data/ccx/Flow1D_thermomech.frd -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femtest/data/ccx/Flow1D_thermomech_inout_nodes.txt -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femtest/data/ccx/Flow1D_thermomech.inp -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femtest/data/ccx/__init__.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femtest/data/ccx/mat_multiple.inp -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femtest/data/ccx/mat_nonlinear.inp -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femtest/data/ccx/spine_thermomech.dat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femtest/data/ccx/spine_thermomech_expected_values -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femtest/data/ccx/spine_thermomech.FCStd -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femtest/data/ccx/spine_thermomech.frd -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femtest/data/ccx/spine_thermomech.inp -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femtest/data/ccx/thermomech_bimetall.inp -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femtest/data/elmer/case.sif -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femtest/data/elmer/ELMERSOLVER_STARTINFO -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femtest/data/elmer/group_mesh.geo -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femtest/data/elmer/__init__.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femtest/data/__init__.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femtest/data/mesh/__init__.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femtest/data/mesh/tetra10_mesh.inp -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femtest/data/mesh/tetra10_mesh.unv -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femtest/data/mesh/tetra10_mesh.vtk -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femtest/data/mesh/tetra10_mesh.yml -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femtest/data/mesh/tetra10_mesh.z88 -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femtest/data/open/all_objects_de9b3fb438.FCStd -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femtest/data/open/__init__.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femtest/gui/__init__.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femtest/gui/test_open.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femtest/__init__.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femtest/test_commands.sh -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femtest/test_information.md -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femtools/ccxtools.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femtools/checksanalysis.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femtools/constants.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femtools/errors.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femtools/femutils.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femtools/geomtools.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femtools/__init__.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femtools/membertools.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femtools/migrate_app.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femtools/migrate_gui.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femtools/tokrules.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femviewprovider/__init__.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femviewprovider/view_base_femconstraint.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femviewprovider/view_base_femobject.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femviewprovider/view_constraint_bodyheatsource.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femviewprovider/view_constraint_electrostaticpotential.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femviewprovider/view_constraint_flowvelocity.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femviewprovider/view_constraint_initialflowvelocity.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femviewprovider/view_constraint_selfweight.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femviewprovider/view_constraint_tie.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femviewprovider/view_element_fluid1D.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femviewprovider/view_element_geometry1D.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femviewprovider/view_element_geometry2D.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femviewprovider/view_element_rotation1D.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femviewprovider/view_material_common.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femviewprovider/view_material_mechanicalnonlinear.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femviewprovider/view_material_reinforced.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femviewprovider/view_mesh_boundarylayer.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femviewprovider/view_mesh_gmsh.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femviewprovider/view_mesh_group.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femviewprovider/view_mesh_region.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femviewprovider/view_mesh_result.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femviewprovider/view_result_mechanical.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/femviewprovider/view_solver_ccxtools.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/InitGui.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/Init.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/ObjectsFem.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/Resources/ui/ConstraintTie.ui -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/Resources/ui/ElectrostaticPotential.ui -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/Resources/ui/ElementFluid1D.ui -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/Resources/ui/ElementGeometry1D.ui -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/Resources/ui/ElementGeometry2D.ui -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/Resources/ui/ElementRotation1D.ui -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/Resources/ui/FlowVelocity.ui -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/Resources/ui/InitialFlowVelocity.ui -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/Resources/ui/MaterialReinforcement.ui -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/Resources/ui/Material.ui -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/Resources/ui/MeshBoundaryLayer.ui -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/Resources/ui/MeshGmsh.ui -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/Resources/ui/MeshGroup.ui -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/Resources/ui/MeshGroupXDMFExport.ui -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/Resources/ui/MeshRegion.ui -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/Resources/ui/ResultHints.ui -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/Resources/ui/ResultShow.ui -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/Resources/ui/SolverCalculix.ui -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/TestFemApp.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Fem/TestFemGui.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Idf/Idflibs/0603_SMD.stp -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Idf/Idflibs/0805_SMD.stp -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Idf/Idflibs/1206_SMD.stp -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Idf/Idflibs/1210_SMD.stp -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Idf/Idflibs/1812_SMD.stp -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Idf/Idflibs/2225_SMD.stp -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Idf/Idflibs/2512_SMD.stp -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Idf/Idflibs/CAP_50SGV_8_10.stp -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Idf/Idflibs/EPL22_6_16.stp -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Idf/Idflibs/footprints_models.csv -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Idf/Idflibs/I22_2_5_16.stp -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Idf/Idflibs/I22_2_5_16withEPL22_6_16.stp -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Idf/Idflibs/License.txt -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Idf/Idflibs/MSOP_10.stp -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Idf/Idflibs/RLF_12545.igs -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Idf/Idflibs/RLF_12545.stp -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Idf/Idflibs/RLF_7030.stp -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Idf/Idflibs/SMB_DO_214AA.stp -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Idf/Idflibs/SMC_DO_214AB.stp -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Idf/Idflibs/SOD_323.igs -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Idf/Idflibs/SOD_323.stp -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Idf/Idflibs/SOD_523.stp -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Idf/Idflibs/SOT23.igs -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Idf/Idflibs/SOT23.stp -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Idf/Idflibs/SOT_323_3.stp -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Idf/Idflibs/SOT404.igs -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Idf/Idflibs/SOT404.stp -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Idf/Idflibs/SOT428_DPAK.stp -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Idf/Idflibs/SOT_96.stp -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Idf/Idflibs/TCMT1107_4.stp -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Idf/Idflibs/TSM_103_01_L_DV_A.stp -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Idf/Idflibs/TSM_104_01_L_DV_A.stp -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Idf/Idflibs/TSS0P_8.stp -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Idf/Idflibs/VC0603_SMD.stp -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Idf/Idf.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Idf/Init.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Image/ImageTools/_CommandImageScaling.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Image/ImageTools/__init__.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Image/InitGui.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Image/Init.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Import/gzip_utf8.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Import/InitGui.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Import/Init.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Import/stepZ.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Inspection/InitGui.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Inspection/Init.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Material/importFCMat.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Material/InitGui.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Material/Init.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Material/MaterialEditor.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Material/Material.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Material/Material_rc.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Material/materials-editor.ui -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Material/materialtools/cardutils.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Material/materialtools/__init__.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Material/Templatematerial.yml -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Measure/Init.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Mesh/BuildRegularGeoms.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Mesh/InitGui.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Mesh/Init.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Mesh/MeshTestsApp.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/MeshPart/InitGui.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/MeshPart/Init.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/MeshPart/MeshFlatteningCommand.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/OpenSCAD/colorcodeshapes.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/OpenSCAD/expandplacements.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/OpenSCAD/exportCSG.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/OpenSCAD/importCSG.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/OpenSCAD/InitGui.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/OpenSCAD/Init.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/OpenSCAD/OpenSCAD2Dgeom.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/OpenSCAD/OpenSCADCommands.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/OpenSCAD/OpenSCADFeatures.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/OpenSCAD/OpenSCAD_rc.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/OpenSCAD/OpenSCADUtils.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/OpenSCAD/replaceobj.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/OpenSCAD/tokrules.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Part/AttachmentEditor/Commands.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Part/AttachmentEditor/FrozenClass.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Part/AttachmentEditor/__init__.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Part/AttachmentEditor/TaskAttachmentEditor.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Part/AttachmentEditor/TaskAttachmentEditor.ui -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Part/BasicShapes/__init__.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Part/BasicShapes/Shapes.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Part/BOPTools/GeneralFuseResult.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Part/BOPTools/__init__.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Part/BOPTools/JoinAPI.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Part/BOPTools/JoinFeatures.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Part/BOPTools/ShapeMerge.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Part/BOPTools/SplitAPI.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Part/BOPTools/SplitFeatures.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Part/BOPTools/Utils.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Part/CompoundTools/_CommandCompoundFilter.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Part/CompoundTools/_CommandExplodeCompound.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Part/CompoundTools/CompoundFilter.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Part/CompoundTools/Explode.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Part/CompoundTools/__init__.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/PartDesign/fcgear/fcgeardialog.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/PartDesign/fcgear/fcgear.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/PartDesign/fcgear/__init__.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/PartDesign/fcgear/involute.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/PartDesign/fcgear/svggear.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/PartDesign/fcsprocket/fcsprocketdialog.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/PartDesign/fcsprocket/fcsprocket.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/PartDesign/fcsprocket/__init__.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/PartDesign/fcsprocket/sprocket.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/PartDesign/InitGui.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/PartDesign/__init__.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/PartDesign/Init.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/PartDesign/InvoluteGearFeature.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/PartDesign/InvoluteGearFeature.ui -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/PartDesign/PartDesignTests/__init__.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/PartDesign/PartDesignTests/TestBoolean.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/PartDesign/PartDesignTests/TestChamfer.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/PartDesign/PartDesignTests/TestDatum.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/PartDesign/PartDesignTests/TestDraft.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/PartDesign/PartDesignTests/TestFillet.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/PartDesign/PartDesignTests/TestHole.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/PartDesign/PartDesignTests/TestLinearPattern.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/PartDesign/PartDesignTests/TestLoft.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/PartDesign/PartDesignTests/TestMirrored.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/PartDesign/PartDesignTests/TestMultiTransform.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/PartDesign/PartDesignTests/TestPad.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/PartDesign/PartDesignTests/TestPipe.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/PartDesign/PartDesignTests/TestPocket.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/PartDesign/PartDesignTests/TestPolarPattern.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/PartDesign/PartDesignTests/TestPrimitive.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/PartDesign/PartDesignTests/TestRevolve.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/PartDesign/PartDesignTests/TestShapeBinder.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/PartDesign/PartDesignTests/TestThickness.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/PartDesign/Scripts/DistanceBolt.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/PartDesign/Scripts/Epitrochoid.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/PartDesign/Scripts/FilletArc.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/PartDesign/Scripts/Gear.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/PartDesign/Scripts/__init__.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/PartDesign/Scripts/Parallelepiped.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/PartDesign/Scripts/RadialCopy.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/PartDesign/Scripts/Spring.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/PartDesign/SprocketFeature.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/PartDesign/SprocketFeature.ui -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/PartDesign/TestPartDesignApp.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/PartDesign/TestPartDesignGui.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/PartDesign/WizardShaft/__init__.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/PartDesign/WizardShaft/SegmentFunction.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/PartDesign/WizardShaft/ShaftDiagram.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/PartDesign/WizardShaft/ShaftFeature.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/PartDesign/WizardShaft/Shaft.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/PartDesign/WizardShaft/WizardShaft.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/PartDesign/WizardShaft/WizardShaft.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/PartDesign/WizardShaft/WizardShaftTable.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Part/InitGui.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Part/Init.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Part/JoinFeatures.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Part/MakeBottle.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Part/parttests/__init__.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Part/parttests/part_test_objects.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Part/TestPartApp.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Part/TestPartGui.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/Images/Ops/chamfer.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/Images/Tools/drill.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/Images/Tools/endmill.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/Images/Tools/v-bit.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/InitGui.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/Init.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathCommands.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/__init__.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathAdaptiveGui.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathAdaptive.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathAreaOp.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathArray.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathCircularHoleBaseGui.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathCircularHoleBase.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathCommands.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathComment.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathCopy.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathCustom.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathDeburrGui.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathDeburr.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathDressupAxisMap.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathDressupDogbone.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathDressupDragknife.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathDressupHoldingTags.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathDressupLeadInOut.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathDressupPathBoundaryGui.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathDressupPathBoundary.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathDressup.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathDressupRampEntry.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathDressupTagGui.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathDressupTagPreferences.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathDressupTag.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathDressupZCorrect.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathDrillingGui.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathDrilling.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathEngraveBase.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathEngraveGui.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathEngrave.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathFixture.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathGeom.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathGetPoint.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathGuiInit.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathGui.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathHelixGui.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathHelix.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathHop.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathIconViewProvider.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathInspect.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathJobCmd.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathJobDlg.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathJobGui.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathJob.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathLog.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathMillFaceGui.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathMillFace.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathOpGui.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathOp.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathOpTools.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathPocketBaseGui.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathPocketBase.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathPocketGui.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathPocket.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathPocketShapeGui.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathPocketShape.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathPostProcessor.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathPost.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathPreferencesPathDressup.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathPreferencesPathJob.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathPreferences.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathProbeGui.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathProbe.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathProfileContourGui.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathProfileContour.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathProfileEdgesGui.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathProfileEdges.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathProfileFacesGui.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathProfileFaces.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathProfileGui.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathProfile.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathSanity.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathSelection.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathSetupSheetGui.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathSetupSheetOpPrototypeGui.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathSetupSheetOpPrototype.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathSetupSheet.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathSimpleCopy.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathSimulatorGui.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathStock.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathStop.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathSurfaceGui.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathSurface.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathSurfaceSupport.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathToolBitCmd.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathToolBitEdit.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathToolBitGui.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathToolBitLibraryCmd.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathToolBitLibraryGui.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathToolBit.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathToolControllerGui.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathToolController.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathToolEdit.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathToolLibraryEditor.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathToolLibraryManager.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathUtil.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathUtilsGui.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathUtils.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathWaterlineGui.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PathWaterline.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/post/centroid_post.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/post/comparams_post.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/post/dynapath_post.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/post/example_pre.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/post/gcode_pre.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/post/grbl_post.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/post/__init__.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/post/jtech_post.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/post/linuxcnc_post.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/post/mach3_mach4_post.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/post/opensbp_post.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/post/opensbp_pre.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/post/philips_post.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/post/rml_post.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/post/slic3r_pre.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/post/smoothie_post.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathScripts/PostUtils.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathTests/boxtest.fcstd -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathTests/__init__.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathTests/PathTestUtils.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathTests/test_centroid_00.ngc -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathTests/test_geomop.fcstd -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathTests/test_holes00.fcstd -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathTests/test_linuxcnc_00.ngc -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathTests/TestPathCore.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathTests/TestPathDeburr.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathTests/TestPathDepthParams.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathTests/TestPathDressupDogbone.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathTests/TestPathDressupHoldingTags.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathTests/TestPathGeom.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathTests/TestPathHelix.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathTests/TestPathLog.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathTests/TestPathOpTools.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathTests/TestPathPost.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathTests/TestPathPreferences.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathTests/TestPathSetupSheet.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathTests/TestPathStock.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathTests/TestPathToolBit.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathTests/TestPathToolController.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathTests/TestPathTool.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathTests/TestPathTooltable.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/PathTests/TestPathUtil.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/TestPathApp.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/Tools/Bit/t1.fctb -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/Tools/Bit/t2.fctb -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/Tools/Bit/t3.fctb -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/Tools/Bit/t4.fctb -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/Tools/Bit/t5.fctb -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/Tools/Bit/t6.fctb -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/Tools/Bit/t7.fctb -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/Tools/Bit/t8.fctb -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/Tools/Bit/t9.fctb -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/Tools/Library/endmills.fctl -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/Tools/Shape/ballend.fcstd -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/Tools/Shape/bullnose.fcstd -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/Tools/Shape/drill.fcstd -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/Tools/Shape/endmill.fcstd -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Path/Tools/Shape/v-bit.fcstd -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Points/InitGui.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Points/Init.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Raytracing/InitGui.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Raytracing/Init.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Raytracing/RaytracingExample.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/ReverseEngineering/InitGui.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/ReverseEngineering/Init.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Robot/InitGui.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Robot/Init.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Robot/KukaExporter.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Robot/MovieTool.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Robot/RobotExample.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Robot/RobotExampleTrajectoryOutOfShapes.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Show/Containers.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Show/DepGraphTools.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Show/__init__.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Show/mTempoVis.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Show/SceneDetail.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Show/SceneDetails/Camera.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Show/SceneDetails/ClipPlane.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Show/SceneDetails/__init__.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Show/SceneDetails/ObjectClipPlane.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Show/SceneDetails/Pickability.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Show/SceneDetails/VProperty.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Show/SceneDetails/Workbench.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Show/ShowUtils.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Show/TVObserver.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Show/TVStack.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Sketcher/InitGui.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Sketcher/Init.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Sketcher/ProfileLib/Hexagon.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Sketcher/ProfileLib/__init__.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Sketcher/ProfileLib/RegularPolygon.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Sketcher/Profiles.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Sketcher/SketcherExample.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Sketcher/TestSketcherApp.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Sketcher/TestSketcherGui.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Spreadsheet/importXLSX.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Spreadsheet/InitGui.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Spreadsheet/Init.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Spreadsheet/TestSpreadsheet.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Start/InitGui.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Start/Init.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Start/StartPage/__init__.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Start/StartPage/StartPage.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Start/StartPage/TranslationTexts.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Surface/InitGui.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Surface/Init.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/TechDraw/InitGui.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/TechDraw/Init.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/TechDraw/TDTest/DHatchTest.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/TechDraw/TDTest/DProjGroupTest.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/TechDraw/TDTest/DVAnnoSymImageTest.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/TechDraw/TDTest/DVBalloonTest.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/TechDraw/TDTest/DVDimensionTest.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/TechDraw/TDTest/DVPartTest.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/TechDraw/TDTest/DVSectionTest.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/TechDraw/TDTest/__init__.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/TechDraw/TDTest/TestHatch.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/TechDraw/TDTest/TestImage.png -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/TechDraw/TDTest/TestSymbol.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/TechDraw/TDTest/TestTemplate.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/TechDraw/TestTechDrawApp.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Test/BaseTests.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Test/Document.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Test/InitGui.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Test/__init__.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Test/Init.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Test/Menu.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Test/qtunittest.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Test/TestApp.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Test/TestGui.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Test/testmakeWireString.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Test/TestPythonSyntax.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Test/UnicodeTests.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Test/unittestgui.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Test/UnitTests.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Test/Workbench.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Tux/InitGui.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Tux/NavigationIndicatorGui.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Tux/PersistentToolbarsGui.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Tux/PersistentToolbars.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Tux/Tux_rc.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Web/InitGui.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Web/Init.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/Mod/Web/TestWebGui.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/applications/org.freecadweb.FreeCAD.desktop -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/doc/freecad/freecad.qch -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/doc/freecad/freecad.qhc -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/doc/freecad/ThirdPartyLibraries.html -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/3Dconnexion/3DConnexion.xml -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/examples/ArchDetail.FCStd -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/examples/draft_test_objects.FCStd -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/examples/EngineBlock.FCStd -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/examples/FemCalculixCantilever2D.FCStd -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/examples/FemCalculixCantilever3D.FCStd -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/examples/FemCalculixCantilever3D_newSolver.FCStd -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/examples/PartDesignExample.FCStd -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/examples/RobotExample.FCStd -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/examples/Schenkel.stp -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Gui/Stylesheets/Dark-blue.qss -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Gui/Stylesheets/Darker-blue.qss -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Gui/Stylesheets/Darker-green.qss -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Gui/Stylesheets/Darker-orange.qss -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Gui/Stylesheets/Dark-green.qss -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Gui/Stylesheets/Dark-orange.qss -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Gui/Stylesheets/images_dark-light/background_freecad_dark.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Gui/Stylesheets/images_dark-light/background_freecad_light.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Gui/Stylesheets/images_dark-light/background_freecad.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Gui/Stylesheets/images_dark-light/branch_end_closed_dark.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Gui/Stylesheets/images_dark-light/branch_end_closed_light.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Gui/Stylesheets/images_dark-light/branch_end_dark.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Gui/Stylesheets/images_dark-light/branch_end_light.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Gui/Stylesheets/images_dark-light/branch_end_open_dark.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Gui/Stylesheets/images_dark-light/branch_end_open_light.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Gui/Stylesheets/images_dark-light/branch_more_closed_dark.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Gui/Stylesheets/images_dark-light/branch_more_closed_light.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Gui/Stylesheets/images_dark-light/branch_more_dark.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Gui/Stylesheets/images_dark-light/branch_more_light.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Gui/Stylesheets/images_dark-light/branch_more_open_dark.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Gui/Stylesheets/images_dark-light/branch_more_open_light.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Gui/Stylesheets/images_dark-light/branch_vline_dark.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Gui/Stylesheets/images_dark-light/branch_vline_light.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Gui/Stylesheets/images_dark-light/checkbox_indeterminate_light.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Gui/Stylesheets/images_dark-light/checkbox_light.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Gui/Stylesheets/images_dark-light/close_dark.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Gui/Stylesheets/images_dark-light/close_light.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Gui/Stylesheets/images_dark-light/down_arrow_darker.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Gui/Stylesheets/images_dark-light/down_arrow_dark.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Gui/Stylesheets/images_dark-light/down_arrow_disabled_dark.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Gui/Stylesheets/images_dark-light/down_arrow_disabled_light.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Gui/Stylesheets/images_dark-light/down_arrow_lighter.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Gui/Stylesheets/images_dark-light/down_arrow_light.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Gui/Stylesheets/images_dark-light/Hmovetoolbar_dark.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Gui/Stylesheets/images_dark-light/Hmovetoolbar_light.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Gui/Stylesheets/images_dark-light/Hsepartoolbar_dark.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Gui/Stylesheets/images_dark-light/Hsepartoolbar_light.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Gui/Stylesheets/images_dark-light/left_arrow_darker.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Gui/Stylesheets/images_dark-light/left_arrow_dark.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Gui/Stylesheets/images_dark-light/left_arrow_disabled_dark.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Gui/Stylesheets/images_dark-light/left_arrow_disabled_light.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Gui/Stylesheets/images_dark-light/left_arrow_lighter.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Gui/Stylesheets/images_dark-light/left_arrow_light.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Gui/Stylesheets/images_dark-light/more_dark.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Gui/Stylesheets/images_dark-light/more_light.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Gui/Stylesheets/images_dark-light/radiobutton_dark.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Gui/Stylesheets/images_dark-light/radiobutton_light.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Gui/Stylesheets/images_dark-light/right_arrow_darker.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Gui/Stylesheets/images_dark-light/right_arrow_dark.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Gui/Stylesheets/images_dark-light/right_arrow_disabled_dark.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Gui/Stylesheets/images_dark-light/right_arrow_disabled_light.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Gui/Stylesheets/images_dark-light/right_arrow_lighter.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Gui/Stylesheets/images_dark-light/right_arrow_light.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Gui/Stylesheets/images_dark-light/sizegrip_dark.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Gui/Stylesheets/images_dark-light/sizegrip_light.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Gui/Stylesheets/images_dark-light/splitter_horizontal_dark.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Gui/Stylesheets/images_dark-light/splitter_horizontal_light.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Gui/Stylesheets/images_dark-light/splitter_vertical_dark.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Gui/Stylesheets/images_dark-light/splitter_vertical_light.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Gui/Stylesheets/images_dark-light/transparent.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Gui/Stylesheets/images_dark-light/undock_dark.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Gui/Stylesheets/images_dark-light/undock_light.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Gui/Stylesheets/images_dark-light/up_arrow_darker.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Gui/Stylesheets/images_dark-light/up_arrow_dark.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Gui/Stylesheets/images_dark-light/up_arrow_disabled_dark.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Gui/Stylesheets/images_dark-light/up_arrow_disabled_light.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Gui/Stylesheets/images_dark-light/up_arrow_lighter.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Gui/Stylesheets/images_dark-light/up_arrow_light.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Gui/Stylesheets/images_dark-light/up-down_arrow_darker.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Gui/Stylesheets/images_dark-light/up-down_arrow_dark.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Gui/Stylesheets/images_dark-light/up-down_arrow_disabled_dark.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Gui/Stylesheets/images_dark-light/up-down_arrow_disabled_light.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Gui/Stylesheets/images_dark-light/up-down_arrow_lighter.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Gui/Stylesheets/images_dark-light/up-down_arrow_light.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Gui/Stylesheets/images_dark-light/Vmovetoolbar_dark.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Gui/Stylesheets/images_dark-light/Vmovetoolbar_light.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Gui/Stylesheets/images_dark-light/Vsepartoolbar_dark.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Gui/Stylesheets/images_dark-light/Vsepartoolbar_light.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Gui/Stylesheets/Light-blue.qss -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Gui/Stylesheets/Light-green.qss -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Gui/Stylesheets/Light-orange.qss -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/License.txt -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Arch/Presets -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Arch/Presets/ifc_contexts_IFC2X3.json -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Arch/Presets/ifc_contexts_IFC4.json -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Arch/Presets/ifc_products_IFC2X3.json -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Arch/Presets/ifc_products_IFC4.json -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Arch/Presets/ifc_types_IFC2X3.json -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Arch/Presets/ifc_types_IFC4.json -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Arch/Presets/profiles.csv -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Arch/Presets/pset_definitions.csv -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Arch/Resources/icons/ArchWorkbench.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Complete/Resources/icons/CompleteWorkbench.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Draft/Resources/icons/DraftWorkbench.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Drawing/Resources/icons/DrawingWorkbench.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Drawing/Templates -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Drawing/Templates/A0_Landscape_ISO7200.dxf -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Drawing/Templates/A0_Landscape_ISO7200.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Drawing/Templates/A0_Landscape_plain.dxf -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Drawing/Templates/A0_Landscape_plain.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Drawing/Templates/A0_Portrait_plain.dxf -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Drawing/Templates/A0_Portrait_plain.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Drawing/Templates/A1_Landscape_ISO7200.dxf -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Drawing/Templates/A1_Landscape_ISO7200.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Drawing/Templates/A1_Landscape_plain.dxf -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Drawing/Templates/A1_Landscape_plain.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Drawing/Templates/A1_Portrait_plain.dxf -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Drawing/Templates/A1_Portrait_plain.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Drawing/Templates/A2_Landscape_ISO7200.dxf -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Drawing/Templates/A2_Landscape_ISO7200.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Drawing/Templates/A2_Landscape_plain.dxf -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Drawing/Templates/A2_Landscape_plain.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Drawing/Templates/A2_Portrait_plain.dxf -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Drawing/Templates/A2_Portrait_plain.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Drawing/Templates/A3_Landscape.dxf -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Drawing/Templates/A3_Landscape_ISO7200.dxf -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Drawing/Templates/A3_Landscape_ISO7200.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Drawing/Templates/A3_Landscape_plain.dxf -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Drawing/Templates/A3_Landscape_plain.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Drawing/Templates/A3_Landscape.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Drawing/Templates/A3_Portrait_plain.dxf -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Drawing/Templates/A3_Portrait_plain.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Drawing/Templates/A4_Landscape.dxf -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Drawing/Templates/A4_Landscape_ISO7200.dxf -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Drawing/Templates/A4_Landscape_ISO7200.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Drawing/Templates/A4_Landscape_plain.dxf -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Drawing/Templates/A4_Landscape_plain.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Drawing/Templates/A4_Landscape.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Drawing/Templates/A4_Portrait_ISO7200.dxf -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Drawing/Templates/A4_Portrait_ISO7200.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Drawing/Templates/A4_Portrait_plain.dxf -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Drawing/Templates/A4_Portrait_plain.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Fem/Resources/icons/FemWorkbench.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Image/Resources/icons/ImageWorkbench.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Import/DxfPlate -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Import/DxfPlate/blocks10.rub -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Import/DxfPlate/blocks112.rub -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Import/DxfPlate/blocks114.rub -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Import/DxfPlate/classes14.rub -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Import/DxfPlate/entities0.rub -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Import/DxfPlate/entities12.rub -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Import/DxfPlate/entities14.rub -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Import/DxfPlate/header0.rub -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Import/DxfPlate/header12.rub -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Import/DxfPlate/header14.rub -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Import/DxfPlate/objects14.rub -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Import/DxfPlate/tables10.rub -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Import/DxfPlate/tables112.rub -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Import/DxfPlate/tables114.rub -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Import/DxfPlate/tables20.rub -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Import/DxfPlate/tables212.rub -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Import/DxfPlate/tables214.rub -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Inspection/Resources/icons/InspectionWorkbench.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/FluidMaterial -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/FluidMaterial/Air.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/FluidMaterial/None.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/FluidMaterial/Water.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/ABS-Generic.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Acrylic-Glass-Generic.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/AlMg3F24.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/AlMgSi1F31.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Aluminum-6061-T6.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/AlZn4-5Mg1F35.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/CalculiX-Steel.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Concrete-EN-C35_45.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Concrete-Generic.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Glass-E-GlassFibre.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Glass-Generic.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Glass-S2-GlassFibre.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/None.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/PA6-Generic.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/PET-Generic.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/PLA-Generic.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/PP-Generic.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/PTFE-Generic.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/PVC-Generic.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Reinforcement-FIB-B500.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-15CrNi6.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-17CrNiMo6.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-1C22.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-1C35.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-1C45.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-1C60.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-20NiCrMo2.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-28Mn6.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-2C10.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-30CrNiMo8.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-34CrNiMo6.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-36CrNiMo4.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-36NiCrMo16.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-3C15.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-3C22.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-3C35.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-3V45.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-C10.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-C15.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-C22E.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-C25E.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-C30E.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-C40E.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-C50E.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-C55E.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-C60E.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-E295.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-E295-GC.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-E335.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-E335-GC.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-E360.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-E360-GC.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-EN-GJL-100.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-EN-GJL-150.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-EN-GJL-200.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-EN-GJL-250.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-EN-GJL-300.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-EN-GJL-350.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-EN-GJMB-350-10.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-EN-GJMB-550-4.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-EN-GJMB-650-2.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-EN-GJMW-350-4.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-EN-GJMW-360-12.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-EN-GJMW-400-5.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-EN-GJMW-450-7.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-EN-GJS-400-15.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-EN-GJS-500-7.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-EN-GJS-600-3.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-EN-GJS-700-2.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-EN-GJS-800-1.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-G16Mn5.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-G200.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-G20Mn5.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-G230.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-G260.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-G300.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-G30Mn5.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-Generic.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-S185.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-S235JO.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-S235JR.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-S235JRG1.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-S260NC.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-S275JO.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-S275JR.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-S275N.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-S335JO.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-S335JR.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-S335N.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-S340MC.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-S355J2G3.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-S380MC.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-S420MC.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-S420N.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-S460MC.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-S460N.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-S500MC.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-S550MC.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-S690MC.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-St-37-2K.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-St-E-255.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-St-E-315.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-St-E-380.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-St-E-460.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-St-E-500.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-X2CrNiMoN17-13-3.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-X2CrNiN24-4.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-X39CrMo17-1.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-X3CrNiMo13-14.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-X5CrNi18-10.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-X5CrNiMo17-12-2.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Steel-X6CrNiTi18-10.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/TEMPLATE.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Tools -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Material/StandardMaterial/Wood-Generic.FCMat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Mesh/Resources/icons/MeshWorkbench.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/OpenSCAD/Resources/icons/OpenSCADWorkbench.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/PartDesign/Resources/icons/PartDesignWorkbench.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Part/Resources/icons/PartWorkbench.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Path/Resources/icons/PathWorkbench.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Points/Resources/icons/PointsWorkbench.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Raytracing/Resources/icons/RaytracingWorkbench.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Raytracing/Templates/LuxClassic.lxs -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Raytracing/Templates/LuxOutdoor.lxs -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Raytracing/Templates/ProjectStd.pov -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Raytracing/Templates/RadiosityNormal.pov -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Raytracing/Templates/RadiosityOutdoorHQ.pov -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/ReverseEngineering/Resources/icons/ReverseEngineeringWorkbench.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Robot/Lib -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Robot/Lib/Kuka -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Robot/Lib/Kuka/kr125_3.wrl -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Robot/Lib/Kuka/kr_125.csv -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Robot/Lib/Kuka/kr_16.csv -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Robot/Lib/Kuka/kr16.wrl -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Robot/Lib/Kuka/kr_210_2.csv -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Robot/Lib/Kuka/kr210.WRL -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Robot/Lib/Kuka/kr500_1.csv -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Robot/Lib/Kuka/kr500_1.wrl -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Robot/Lib/Kuka/testprog.dat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Robot/Lib/Kuka/testprog.src -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Robot/Resources/icons/RobotWorkbench.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Sketcher/Resources/icons/SketcherWorkbench.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Spreadsheet/Resources/icons/SpreadsheetWorkbench.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Start/Resources/icons/StartWorkbench.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Start/StartPage/EnableDownload.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Start/StartPage/images/developerhub.png -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Start/StartPage/images/freecad.png -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Start/StartPage/images/installed.png -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Start/StartPage/images/manual.png -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Start/StartPage/images/new_file_thumbnail.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Start/StartPage/images/poweruserhub.png -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Start/StartPage/images/settings.png -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Start/StartPage/images/userhub.png -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Start/StartPage/LoadCustom.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Start/StartPage/LoadExample.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Start/StartPage/LoadMRU.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Start/StartPage/LoadNew.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Start/StartPage/OpenSettings.py -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Start/StartPage/StartPage.css -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Start/StartPage/StartPage.html -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Start/StartPage/StartPage.js -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/LineGroup -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/LineGroup/LineGroup.csv -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/PAT -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/PAT/FCPAT.pat -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Patterns -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Patterns/aluminium.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Patterns/brick01.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Patterns/concrete.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Patterns/cross.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Patterns/cuprous.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Patterns/diagonal1.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Patterns/diagonal2.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Patterns/earth.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Patterns/general_steel.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Patterns/glass.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Patterns/hatch45L.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Patterns/hatch45R.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Patterns/hbone.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Patterns/line.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Patterns/plastic.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Patterns/plus.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Patterns/simple.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Patterns/solid.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Patterns/square.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Patterns/steel.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Patterns/titanium.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Patterns/woodgrain.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Patterns/wood.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Patterns/zinc.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Resources/fonts/osifont-lgpl3fe.ttf -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Resources/fonts/osifont.license -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Resources/icons/preferences-techdraw.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Symbols -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Symbols/gd-and-t -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Symbols/gd-and-t/angularity-left.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Symbols/gd-and-t/angularity-right.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Symbols/gd-and-t/ConcentricityFrame.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Symbols/gd-and-t/concentricity.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Symbols/gd-and-t/CylindricityFrame.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Symbols/gd-and-t/cylindricity.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Symbols/gd-and-t/FlatnessFrame.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Symbols/gd-and-t/flatness.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Symbols/gd-and-t/ParallelismFrame.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Symbols/gd-and-t/parallelism.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Symbols/gd-and-t/perpendicularity.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Symbols/gd-and-t/position.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Symbols/gd-and-t/profile-tolerance-of-line.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Symbols/gd-and-t/profile-tolerance-of-plane.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Symbols/gd-and-t/ReferenceSurface.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Symbols/gd-and-t/RoundnessFrame.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Symbols/gd-and-t/roundness.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Symbols/gd-and-t/SquarenessFrame.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Symbols/gd-and-t/symmetry.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Symbols/gd-and-t/totalrunout.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Symbols/other -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Symbols/other/CutLine.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Symbols/other/Diameter.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Symbols/other/Envelope.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Symbols/other/FilletInside.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Symbols/other/FilletOutside.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Symbols/other/IndexCircle.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Symbols/other/IndexTriangle.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Symbols/other/InsideEdgeBroken.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Symbols/other/OutsideEdgeBroken.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Symbols/other/Rectangle.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Symbols/other/SectionLine.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Symbols/other/Square.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Symbols/surface-roughness-symbols -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Symbols/surface-roughness-symbols/RoughnessGeneral.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Symbols/surface-roughness-symbols/Roughness.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Symbols/surface-roughness-symbols/surface-roughness-contour.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Symbols/surface-roughness-symbols/surface-roughness-layer-removing.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Symbols/surface-roughness-symbols/surface-roughness-no-layer-removing.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Symbols/surface-roughness-symbols/surface-roughness.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Symbols/Welding -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Symbols/Welding/AWS -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Symbols/Welding/AWS/beadDown.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Symbols/Welding/AWS/beadUp.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Symbols/Welding/AWS/filletDown.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Symbols/Welding/AWS/filletUp.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Symbols/Welding/AWS/plug.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Symbols/Welding/AWS/SquareDown.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Symbols/Welding/AWS/SquareUp.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Symbols/Welding/AWS/VDown.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Symbols/Welding/AWS/VUp.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Symbols/Welding/blankTile.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Symbols/Welding/GOST -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Symbols/Welding/GOST/edge-weld.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Symbols/Welding/GOST/flanging.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Symbols/Welding/GOST/flare-bevel-groove.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Symbols/Welding/GOST/flare-v-groove.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Symbols/Welding/GOST/gost-2_312 -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Symbols/Welding/GOST/gost-2_312/cathetus.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Symbols/Welding/GOST/gost-2_312/gost-2_312-intermittent.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Symbols/Welding/GOST/gost-2_312/gost-2_312-non-closed.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Symbols/Welding/GOST/gost-2_312/gost-2_312-site-weld.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Symbols/Welding/GOST/gost-2_312/gost-2_312-smooth-processing.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Symbols/Welding/GOST/gost-2_312/gost-2_312-usilenie-remove.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Symbols/Welding/GOST/seam-weld.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Symbols/Welding/GOST/single-bevel-cjp-groove-weld.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Symbols/Welding/GOST/single-bevel-groove-weld.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Symbols/Welding/GOST/single-bevel-groove-weld-with-broad-root-face.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Symbols/Welding/GOST/single-j-groove-weld.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Symbols/Welding/GOST/single-u-groove-weld.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Symbols/Welding/GOST/single-v-cjp-groove-weld.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Symbols/Welding/GOST/single-v-groove-weld.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Symbols/Welding/GOST/single-v-groove-weld-with-broad-root-face.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Symbols/Welding/GOST/spile-weld.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Symbols/Welding/GOST/square-groove-weld.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Symbols/Welding/GOST/surfacing.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Templates -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Templates/A0_Landscape_blank.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Templates/A0_Landscape_ISO7200_Pep.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Templates/A0_Landscape_ISO7200TD.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Templates/A1_Landscape_blank.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Templates/A1_Landscape_ISO7200_Pep.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Templates/A1_Landscape_ISO7200TD.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Templates/A2_Landscape_blank.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Templates/A2_Landscape_ISO7200_Pep.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Templates/A2_Landscape_ISO7200TD.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Templates/A3_Landscape_blank.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Templates/A3_Landscape_EN_m52.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Templates/A3_Landscape_FR_m52.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Templates/A3_Landscape_ISO7200_Pep.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Templates/A3_Landscape_ISO7200TD.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Templates/A3_Landscape_IT_m52.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Templates/A3_LandscapeTD.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Templates/A4_Landscape_blank.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Templates/A4_Landscape_ISO7200_Pep.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Templates/A4_Landscape_ISO7200TD.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Templates/A4_LandscapeTD.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Templates/A4_Portrait_blank.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Templates/A4_Portrait_ISO7200Pep.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Templates/A4_Portrait_ISO7200TD.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Templates/ANSIB_Portrait.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Templates/ANSIB.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Templates/HowToExample.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Templates/RU_GOST -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Templates/RU_GOST/Leading -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Templates/RU_GOST/Leading/Landscape_A0.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Templates/RU_GOST/Leading/Landscape_A1.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Templates/RU_GOST/Leading/Landscape_A2.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Templates/RU_GOST/Leading/Landscape_A3.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Templates/RU_GOST/Leading/Landscape_A4_NotInGOST.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Templates/RU_GOST/Leading/Portrait_A0.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Templates/RU_GOST/Leading/Portrait_A1.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Templates/RU_GOST/Leading/Portrait_A2.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Templates/RU_GOST/Leading/Portrait_A3.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Templates/RU_GOST/Leading/Portrait_A4.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Templates/RU_GOST/Leading_text -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Templates/RU_GOST/Leading_text/Portrait_A3.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Templates/RU_GOST/Leading_text/Portrait_A4.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Templates/RU_GOST/Subsequent -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Templates/RU_GOST/Subsequent/Landscape_A0.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Templates/RU_GOST/Subsequent/Landscape_A1.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Templates/RU_GOST/Subsequent/Landscape_A2.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Templates/RU_GOST/Subsequent/Landscape_A3.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Templates/RU_GOST/Subsequent/Landscape_A4.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Templates/RU_GOST/Subsequent/Portrait_A0.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Templates/RU_GOST/Subsequent/Portrait_A1.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Templates/RU_GOST/Subsequent/Portrait_A2.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Templates/RU_GOST/Subsequent/Portrait_A3.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Templates/RU_GOST/Subsequent/Portrait_A4.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Templates/USLetter_Landscape_blank.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Templates/USLetter_Landscape.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Templates/zh_CN -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Templates/zh_CN/landscape -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Templates/zh_CN/landscape/A0_Landscape_CN.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Templates/zh_CN/landscape/A1_Landscape_CN.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Templates/zh_CN/landscape/A2_Landscape_CN.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Templates/zh_CN/landscape/A3_Landscape_CN.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/TechDraw/Templates/zh_CN/landscape/A4_Landscape_CN.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Test/Resources/icons/TestWorkbench.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/freecad/Mod/Web/Resources/icons/WebWorkbench.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/icons/hicolor/16x16/apps/freecad.png -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/icons/hicolor/32x32/apps/freecad.png -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/icons/hicolor/48x48/apps/freecad.png -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/icons/hicolor/64x64/apps/freecad.png -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/icons/hicolor/scalable/apps/freecad.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/icons/hicolor/scalable/apps/org.freecadweb.FreeCAD.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/icons/hicolor/scalable/mimetypes/application-x-extension-fcstd.svg -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/metainfo/org.freecadweb.FreeCAD.appdata.xml -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/mime/packages/org.freecadweb.FreeCAD.xml -- Installing: /builddir/build/BUILDROOT/freecad-0.19-1.fc33.x86_64/usr/share/pixmaps/freecad.xpm |
Ok, after several build attempts yesterday trying to beat the package back into submission I got more than a little frustrated. With fresh eyes I found GNUInstallDirs buried in "cMake/FreeCAD_Helpers/ConfigureCMakeVariables.cmake". It's also in "src/XDGData/CMakeLists.txt" which I would say would be inappropriate to include two different places but my guess this is an attempt to override the PREFIX in the former location: set(CMAKE_INSTALL_PREFIX "/usr/lib${LIB_SUFFIX}/freecad" CACHE PATH "Installation root directory") I believe this is only necessary because all of the Mod/ installs use the relative install path "Mod/<module>" which will only be installed relative to the PREFIX. Also, I misspoke in the original post, noarch data if it's executable code still belongs in /usr/lib, not /usr/share, which IS for noarch data, just not noarch code such as pure python. Evaluating the install location portion of
1. In this case creating all the cache variables for WIN32 is superfluous as GNUInstallDirs would set cache variables to the exact same values in all cases except the _PREFIX which could be easily modified. 2. Referenced above, the old issue of dumping everything into /usr/lib{,64}. Please correct me if I'm wrong, but again, the only reason I can find for this is all the stuff in src/Mod not using a proper install location ${CMAKE_INSTALL_LIBDIR}. By default GNUInstallDirs marks all the variables as advanced but it's trivial to expose the locations that FreeCAD actually uses. |
Ok, so even though I wasn't going to do it I did anyway. I have a patch ready for master but I still have a few things to tweak. I've got everything installing correctly except:
I fixed the icon stuff so it's really just the top stuff. 1. Why are the translations (I assume that's what the qch and qhc files are) installing to /usr/doc? That doesn't make any sense. 2. The Ext stuff is still not installing to a freecad subdir even though the helper macro that adds it is added before src/Ext is executed in the main CMakeLists.txt. in src/Ext/freecad/CMakeLists.txt, FREECAD_LIBRARY_INSTALL_DIR is set to CMAKE_INSTALL_LIBDIR, which should already be /usr/lib{,64}/freecad but it's not working...
Almost there! |
Well I mentioned this bug in the pull request but it doesn't look like it's been picked up yet... https://github.com/FreeCAD/FreeCAD/pull/3525 There's still some non-script stuff being installed to /usr/lib{,64}/freecad/Mod I'll work on that when I have a little more time. |
These files are not translation files, they are compiled HTML files. They comprise the offline documentation that can be opened with FreeCAD, and need Qt assistant to be installed, I think. |
I figured that out later, I still question if they should get installed into /usr/doc, which is typically for plain text, markdown, rtf, files. Since they are compiled I would consider them to be a Qt resource file and should go somewhere in /usr/share/freecad. |
Default file locations on fedora linux. FreeCAD_installation_locations.txt (87,345 bytes)
ccache cmake \
-DCMAKE_VERBOSE_MAKEFILE:BOOL=ON \
-DCMAKE_INSTALL_PREFIX:PATH=/home/przemo/TF \
-DBUILD_QT5=ON \
-DMEDFILE_INCLUDE_DIRS=/usr/include/med/ \
-DFREECAD_USE_EXTERNAL_PIVY=TRUE \
-DUSE_OCC=TRUE \
-DSHIBOKEN_INCLUDE_DIR=/usr/include/shiboken2 \
-DSHIBOKEN_LIBRARY=-lshiboken2.cpython-38-x86_64-linux-gnu \
-DPYSIDE_INCLUDE_DIR=/usr/include/PySide2 \
-DPYSIDE_LIBRARY=-lpyside2.cpython-38-x86_64-linux-gnu \
-DPYTHON_EXECUTABLE:FILEPATH=/usr/bin/python3 \
-DPYTHON_SUFFIX=.cpython-38m-x86_64-linux-gnu \
../FreeCAD
produced:
├── bin
│ ├── FreeCAD
│ └── FreeCADCmd
├── Ext
│ ├── freecad
│ │ ├── gui
│ │ │ ├── RemoteDebugger.py
│ │ │ └── RemoteDebugger.ui
│ │ └── __init__.py
│ ├── lazy_loader
│ │ ├── __init__.py
│ │ └── lazy_loader.py
│ └── PySide
│ ├── __init__.py
│ ├── QtCore.py
│ ├── QtGui.py
│ ├── QtSvg.py
│ └── QtUiTools.py
├── lib64
│ ├── area.so
│ ├── DraftUtils.so
│ ├── DrawingGui.so
│ ├── Drawing.so
│ ├── FemGui.so
│ ├── Fem.so
│ ├── FreeCADGui.so
│ ├── FreeCAD.so
│ ├── ImageGui.so
│ ├── Image.so
│ ├── ImportGui.so
│ ├── Import.so
│ ├── InspectionGui.so
│ ├── Inspection.so
│ ├── libarea-native.so
│ ├── libDriverDAT.so
│ ├── libDriver.so
│ ├── libDriverSTL.so
│ ├── libDriverUNV.so
│ ├── libFreeCADApp.so
│ ├── libFreeCADBase.so
│ ├── libFreeCADGui.so
│ ├── libMEFISTO2.so
│ ├── libSMDS.so
│ ├── libSMESHDS.so
│ ├── libSMESH.so
│ ├── libStdMeshers.so
│ ├── Measure.so
│ ├── MeshGui.so
│ ├── MeshPartGui.so
│ ├── MeshPart.so
│ ├── Mesh.so
│ ├── PartDesignGui.so
│ ├── _PartDesign.so
│ ├── PartGui.so
│ ├── Part.so
│ ├── PathGui.so
│ ├── PathSimulator.so
│ ├── Path.so
│ ├── PointsGui.so
│ ├── Points.so
│ ├── QtUnitGui.so
│ ├── RaytracingGui.so
│ ├── Raytracing.so
│ ├── ReverseEngineeringGui.so
│ ├── ReverseEngineering.so
│ ├── RobotGui.so
│ ├── Robot.so
│ ├── SketcherGui.so
│ ├── Sketcher.so
│ ├── SpreadsheetGui.so
│ ├── Spreadsheet.so
│ ├── StartGui.so
│ ├── Start.so
│ ├── SurfaceGui.so
│ ├── Surface.so
│ ├── TechDrawGui.so
│ ├── TechDraw.so
│ ├── WebGui.so
│ └── Web.so
├── Mod
│ ├── AddonManager
│ │ ├── addonmanager_macro.py
│ │ ├── AddonManagerOptions.ui
│ │ ├── AddonManager.py
│ │ ├── AddonManager_rc.py
│ │ ├── AddonManager.ui
│ │ ├── addonmanager_utilities.py
│ │ ├── addonmanager_workers.py
│ │ ├── InitGui.py
│ │ └── Init.py
│ ├── Arch
│ │ ├── ArchAxis.py
│ │ ├── ArchBuildingPart.py
│ │ ├── ArchBuilding.py
│ │ ├── ArchCommands.py
│ │ ├── ArchComponent.py
│ │ ├── ArchCurtainWall.py
│ │ ├── ArchCutPlane.py
│ │ ├── ArchEquipment.py
│ │ ├── ArchFence.py
│ │ ├── ArchFloor.py
│ │ ├── ArchFrame.py
│ │ ├── ArchIFC.py
│ │ ├── ArchIFCSchema.py
│ │ ├── ArchIFCView.py
│ │ ├── ArchMaterial.py
│ │ ├── ArchNesting.py
│ │ ├── ArchPanel.py
│ │ ├── ArchPipe.py
│ │ ├── ArchPrecast.py
│ │ ├── ArchProfile.py
│ │ ├── ArchProject.py
│ │ ├── Arch.py
│ │ ├── Arch_rc.py
│ │ ├── ArchRebar.py
│ │ ├── ArchReference.py
│ │ ├── ArchRoof.py
│ │ ├── ArchSchedule.py
│ │ ├── ArchSectionPlane.py
│ │ ├── ArchSite.py
│ │ ├── ArchSpace.py
│ │ ├── ArchStairs.py
│ │ ├── ArchStructure.py
│ │ ├── ArchTruss.py
│ │ ├── ArchVRM.py
│ │ ├── ArchWall.py
│ │ ├── ArchWindowPresets.py
│ │ ├── ArchWindow.py
│ │ ├── Dice3DS
│ │ │ ├── dom3ds.py
│ │ │ ├── __init__.py
│ │ │ └── util.py
│ │ ├── exportIFCHelper.py
│ │ ├── exportIFC.py
│ │ ├── exportIFCStructuralTools.py
│ │ ├── import3DS.py
│ │ ├── importDAE.py
│ │ ├── importIFCHelper.py
│ │ ├── importIFClegacy.py
│ │ ├── importIFC.py
│ │ ├── importJSON.py
│ │ ├── importOBJ.py
│ │ ├── importSH3D.py
│ │ ├── importSHP.py
│ │ ├── importWebGL.py
│ │ ├── InitGui.py
│ │ ├── Init.py
│ │ ├── OfflineRenderingUtils.py
│ │ └── TestArch.py
│ ├── Complete
│ │ ├── InitGui.py
│ │ └── Init.py
│ ├── Draft
│ │ ├── DraftFillet.py
│ │ ├── draftfunctions
│ │ │ ├── array.py
│ │ │ ├── cut.py
│ │ │ ├── downgrade.py
│ │ │ ├── draftify.py
│ │ │ ├── extrude.py
│ │ │ ├── fuse.py
│ │ │ ├── heal.py
│ │ │ ├── join.py
│ │ │ ├── mirror.py
│ │ │ ├── move.py
│ │ │ ├── offset.py
│ │ │ ├── README.md
│ │ │ ├── rotate.py
│ │ │ ├── scale.py
│ │ │ ├── split.py
│ │ │ └── upgrade.py
│ │ ├── DraftGeomUtils.py
│ │ ├── draftgeoutils
│ │ │ ├── arcs.py
│ │ │ ├── circle_inversion.py
│ │ │ ├── circles_apollonius.py
│ │ │ ├── circles_incomplete.py
│ │ │ ├── circles.py
│ │ │ ├── cuboids.py
│ │ │ ├── edges.py
│ │ │ ├── faces.py
│ │ │ ├── fillets.py
│ │ │ ├── general.py
│ │ │ ├── geometry.py
│ │ │ ├── intersections.py
│ │ │ ├── linear_algebra.py
│ │ │ ├── offsets.py
│ │ │ ├── sort_edges.py
│ │ │ └── wires.py
│ │ ├── DraftGui.py
│ │ ├── draftguitools
│ │ │ ├── gui_annotationstyleeditor.py
│ │ │ ├── gui_arcs.py
│ │ │ ├── gui_array_simple.py
│ │ │ ├── gui_arrays.py
│ │ │ ├── gui_base_original.py
│ │ │ ├── gui_base.py
│ │ │ ├── gui_beziers.py
│ │ │ ├── gui_circles.py
│ │ │ ├── gui_circulararray.py
│ │ │ ├── gui_clone.py
│ │ │ ├── gui_dimension_ops.py
│ │ │ ├── gui_dimensions.py
│ │ │ ├── gui_downgrade.py
│ │ │ ├── gui_draft2sketch.py
│ │ │ ├── gui_drawing.py
│ │ │ ├── gui_edit_arch_objects.py
│ │ │ ├── gui_edit_draft_objects.py
│ │ │ ├── gui_edit_part_objects.py
│ │ │ ├── gui_edit.py
│ │ │ ├── gui_edit_sketcher_objects.py
│ │ │ ├── gui_ellipses.py
│ │ │ ├── gui_facebinders.py
│ │ │ ├── gui_fillets.py
│ │ │ ├── gui_grid.py
│ │ │ ├── gui_groups.py
│ │ │ ├── gui_heal.py
│ │ │ ├── gui_join.py
│ │ │ ├── gui_labels.py
│ │ │ ├── gui_lineops.py
│ │ │ ├── gui_lineslope.py
│ │ │ ├── gui_lines.py
│ │ │ ├── gui_mirror.py
│ │ │ ├── gui_move.py
│ │ │ ├── gui_offset.py
│ │ │ ├── gui_orthoarray.py
│ │ │ ├── gui_patharray.py
│ │ │ ├── gui_planeproxy.py
│ │ │ ├── gui_pointarray.py
│ │ │ ├── gui_points.py
│ │ │ ├── gui_polararray.py
│ │ │ ├── gui_polygons.py
│ │ │ ├── gui_rectangles.py
│ │ │ ├── gui_rotate.py
│ │ │ ├── gui_scale.py
│ │ │ ├── gui_selectplane.py
│ │ │ ├── gui_shape2dview.py
│ │ │ ├── gui_shapestrings.py
│ │ │ ├── gui_snapper.py
│ │ │ ├── gui_snaps.py
│ │ │ ├── gui_splines.py
│ │ │ ├── gui_split.py
│ │ │ ├── gui_stretch.py
│ │ │ ├── gui_styles.py
│ │ │ ├── gui_subelements.py
│ │ │ ├── gui_texts.py
│ │ │ ├── gui_togglemodes.py
│ │ │ ├── gui_tool_utils.py
│ │ │ ├── gui_trackers.py
│ │ │ ├── gui_trimex.py
│ │ │ ├── gui_upgrade.py
│ │ │ ├── gui_wire2spline.py
│ │ │ └── README.md
│ │ ├── DraftLayer.py
│ │ ├── draftmake
│ │ │ ├── make_arc_3points.py
│ │ │ ├── make_array.py
│ │ │ ├── make_bezcurve.py
│ │ │ ├── make_block.py
│ │ │ ├── make_bspline.py
│ │ │ ├── make_circle.py
│ │ │ ├── make_circulararray.py
│ │ │ ├── make_clone.py
│ │ │ ├── make_copy.py
│ │ │ ├── make_dimension.py
│ │ │ ├── make_drawingview.py
│ │ │ ├── make_ellipse.py
│ │ │ ├── make_facebinder.py
│ │ │ ├── make_fillet.py
│ │ │ ├── make_label.py
│ │ │ ├── make_line.py
│ │ │ ├── make_orthoarray.py
│ │ │ ├── make_patharray.py
│ │ │ ├── make_pointarray.py
│ │ │ ├── make_point.py
│ │ │ ├── make_polararray.py
│ │ │ ├── make_polygon.py
│ │ │ ├── make_rectangle.py
│ │ │ ├── make_shape2dview.py
│ │ │ ├── make_shapestring.py
│ │ │ ├── make_sketch.py
│ │ │ ├── make_text.py
│ │ │ ├── make_wire.py
│ │ │ ├── make_wpproxy.py
│ │ │ └── README.md
│ │ ├── draftobjects
│ │ │ ├── array.py
│ │ │ ├── base.py
│ │ │ ├── bezcurve.py
│ │ │ ├── block.py
│ │ │ ├── bspline.py
│ │ │ ├── circle.py
│ │ │ ├── clone.py
│ │ │ ├── dimension.py
│ │ │ ├── draft_annotation.py
│ │ │ ├── draftlink.py
│ │ │ ├── drawingview.py
│ │ │ ├── ellipse.py
│ │ │ ├── facebinder.py
│ │ │ ├── fillet.py
│ │ │ ├── label.py
│ │ │ ├── patharray.py
│ │ │ ├── pointarray.py
│ │ │ ├── point.py
│ │ │ ├── polygon.py
│ │ │ ├── README.md
│ │ │ ├── rectangle.py
│ │ │ ├── shape2dview.py
│ │ │ ├── shapestring.py
│ │ │ ├── text.py
│ │ │ ├── wire.py
│ │ │ └── wpproxy.py
│ │ ├── Draft.py
│ │ ├── Draft_rc.py
│ │ ├── drafttaskpanels
│ │ │ ├── README.md
│ │ │ ├── task_circulararray.py
│ │ │ ├── task_orthoarray.py
│ │ │ ├── task_polararray.py
│ │ │ ├── task_scale.py
│ │ │ ├── task_selectplane.py
│ │ │ └── task_shapestring.py
│ │ ├── drafttests
│ │ │ ├── auxiliary.py
│ │ │ ├── draft_test_objects.py
│ │ │ ├── README.md
│ │ │ ├── test_airfoildat.py
│ │ │ ├── test_creation.py
│ │ │ ├── test_dwg.py
│ │ │ ├── test_dxf.py
│ │ │ ├── test_import_gui.py
│ │ │ ├── test_import.py
│ │ │ ├── test_import_tools.py
│ │ │ ├── test_modification.py
│ │ │ ├── test_oca.py
│ │ │ ├── test_pivy.py
│ │ │ └── test_svg.py
│ │ ├── DraftTools.py
│ │ ├── draftutils
│ │ │ ├── gui_utils.py
│ │ │ ├── init_draft_statusbar.py
│ │ │ ├── init_tools.py
│ │ │ ├── messages.py
│ │ │ ├── README.md
│ │ │ ├── todo.py
│ │ │ ├── translate.py
│ │ │ └── utils.py
│ │ ├── DraftVecUtils.py
│ │ ├── draftviewproviders
│ │ │ ├── README.md
│ │ │ ├── view_array.py
│ │ │ ├── view_base.py
│ │ │ ├── view_bezcurve.py
│ │ │ ├── view_bspline.py
│ │ │ ├── view_circulararray.py
│ │ │ ├── view_clone.py
│ │ │ ├── view_dimension.py
│ │ │ ├── view_draft_annotation.py
│ │ │ ├── view_draftlink.py
│ │ │ ├── view_facebinder.py
│ │ │ ├── view_fillet.py
│ │ │ ├── view_label.py
│ │ │ ├── view_orthoarray.py
│ │ │ ├── view_point.py
│ │ │ ├── view_polararray.py
│ │ │ ├── view_rectangle.py
│ │ │ ├── view_text.py
│ │ │ ├── view_wire.py
│ │ │ └── view_wpproxy.py
│ │ ├── getSVG.py
│ │ ├── importAirfoilDAT.py
│ │ ├── importDWG.py
│ │ ├── importDXF.py
│ │ ├── importOCA.py
│ │ ├── importSVG.py
│ │ ├── InitGui.py
│ │ ├── Init.py
│ │ ├── TestDraftGui.py
│ │ ├── TestDraft.py
│ │ └── WorkingPlane.py
│ ├── Drawing
│ │ ├── DrawingExample.py
│ │ ├── DrawingPatterns.py
│ │ ├── DrawingTests.py
│ │ ├── InitGui.py
│ │ ├── Init.py
│ │ └── README.md
│ ├── Fem
│ │ ├── coding_conventions.md
│ │ ├── femcommands
│ │ │ ├── commands.py
│ │ │ └── manager.py
│ │ ├── femexamples
│ │ │ ├── boxanalysis_frequency.py
│ │ │ ├── boxanalysis_static.py
│ │ │ ├── ccx_cantilever_faceload.py
│ │ │ ├── ccx_cantilever_hexa20faceload.py
│ │ │ ├── ccx_cantilever_nodeload.py
│ │ │ ├── ccx_cantilever_prescribeddisplacement.py
│ │ │ ├── constraint_contact_shell_shell.py
│ │ │ ├── constraint_contact_solid_solid.py
│ │ │ ├── constraint_tie.py
│ │ │ ├── manager.py
│ │ │ ├── material_multiple_twoboxes.py
│ │ │ ├── material_nl_platewithhole.py
│ │ │ ├── meshes
│ │ │ │ ├── __init__.py
│ │ │ │ ├── mesh_boxanalysis_tetra10.py
│ │ │ │ ├── mesh_boxes_2_vertikal_tetra10.py
│ │ │ │ ├── mesh_canticcx_hexa20.py
│ │ │ │ ├── mesh_canticcx_tetra10.py
│ │ │ │ ├── mesh_constraint_tie_tetra10.py
│ │ │ │ ├── mesh_contact_box_halfcylinder_tetra10.py
│ │ │ │ ├── mesh_contact_tube_tube_tria3.py
│ │ │ │ ├── mesh_platewithhole_tetra10.py
│ │ │ │ ├── mesh_rc_wall_2d_tria6.py
│ │ │ │ ├── mesh_thermomech_bimetall_tetra10.py
│ │ │ │ ├── mesh_thermomech_flow1d_seg3.py
│ │ │ │ └── mesh_thermomech_spine_tetra10.py
│ │ │ ├── rc_wall_2d.py
│ │ │ ├── thermomech_bimetall.py
│ │ │ ├── thermomech_flow1d.py
│ │ │ └── thermomech_spine.py
│ │ ├── femguiobjects
│ │ │ └── readme.md
│ │ ├── femguiutils
│ │ │ ├── migrate_gui.py
│ │ │ └── selection_widgets.py
│ │ ├── feminout
│ │ │ ├── convert2TetGen.py
│ │ │ ├── importCcxDatResults.py
│ │ │ ├── importCcxFrdResults.py
│ │ │ ├── importFenicsMesh.py
│ │ │ ├── importInpMesh.py
│ │ │ ├── importPyMesh.py
│ │ │ ├── importToolsFem.py
│ │ │ ├── importVTKResults.py
│ │ │ ├── importYamlJsonMesh.py
│ │ │ ├── importZ88Mesh.py
│ │ │ ├── importZ88O2Results.py
│ │ │ ├── readFenicsXDMF.py
│ │ │ ├── readFenicsXML.py
│ │ │ ├── writeFenicsXDMF.py
│ │ │ └── writeFenicsXML.py
│ │ ├── femmesh
│ │ │ ├── femmesh2mesh.py
│ │ │ ├── gmshtools.py
│ │ │ └── meshtools.py
│ │ ├── femobjects
│ │ │ ├── base_fempythonobject.py
│ │ │ ├── constraint_bodyheatsource.py
│ │ │ ├── constraint_electrostaticpotential.py
│ │ │ ├── constraint_flowvelocity.py
│ │ │ ├── constraint_initialflowvelocity.py
│ │ │ ├── constraint_selfweight.py
│ │ │ ├── element_fluid1D.py
│ │ │ ├── element_geometry1D.py
│ │ │ ├── element_geometry2D.py
│ │ │ ├── element_rotation1D.py
│ │ │ ├── material_common.py
│ │ │ ├── material_mechanicalnonlinear.py
│ │ │ ├── material_reinforced.py
│ │ │ ├── mesh_boundarylayer.py
│ │ │ ├── mesh_gmsh.py
│ │ │ ├── mesh_group.py
│ │ │ ├── mesh_region.py
│ │ │ ├── mesh_result.py
│ │ │ ├── result_mechanical.py
│ │ │ └── solver_ccxtools.py
│ │ ├── femresult
│ │ │ └── resulttools.py
│ │ ├── femsolver
│ │ │ ├── calculix
│ │ │ │ ├── solver.py
│ │ │ │ ├── tasks.py
│ │ │ │ └── writer.py
│ │ │ ├── elmer
│ │ │ │ ├── equations
│ │ │ │ │ ├── elasticity.py
│ │ │ │ │ ├── electricforce.py
│ │ │ │ │ ├── electrostatic.py
│ │ │ │ │ ├── equation.py
│ │ │ │ │ ├── flow.py
│ │ │ │ │ ├── fluxsolver.py
│ │ │ │ │ ├── heat.py
│ │ │ │ │ ├── __init__.py
│ │ │ │ │ ├── linear.py
│ │ │ │ │ └── nonlinear.py
│ │ │ │ ├── sifio.py
│ │ │ ├── equationbase.py
│ │ │ ├── fenics
│ │ │ │ ├── fenics_tools.py
│ │ │ │ └── __init__.py
│ │ │ ├── reportdialog.py
│ │ │ ├── report.py
│ │ │ ├── run.py
│ │ │ ├── settings.py
│ │ │ ├── signal.py
│ │ │ ├── solverbase.py
│ │ │ ├── solver_taskpanel.py
│ │ │ ├── task.py
│ │ │ ├── writerbase.py
│ │ │ └── z88
│ │ │ ├── solver.py
│ │ │ ├── tasks.py
│ │ │ └── writer.py
│ │ ├── femtaskpanels
│ │ │ ├── task_constraint_electrostaticpotential.py
│ │ │ ├── task_constraint_flowvelocity.py
│ │ │ ├── task_constraint_initialflowvelocity.py
│ │ │ ├── task_constraint_tie.py
│ │ │ ├── task_element_fluid1D.py
│ │ │ ├── task_element_geometry1D.py
│ │ │ ├── task_element_geometry2D.py
│ │ │ ├── task_element_rotation1D.py
│ │ │ ├── task_material_common.py
│ │ │ ├── task_material_reinforced.py
│ │ │ ├── task_mesh_boundarylayer.py
│ │ │ ├── task_mesh_gmsh.py
│ │ │ ├── task_mesh_group.py
│ │ │ ├── task_mesh_region.py
│ │ │ ├── task_result_mechanical.py
│ │ │ └── task_solver_ccxtools.py
│ │ ├── femtest
│ │ │ ├── app
│ │ │ │ ├── support_utils.py
│ │ │ │ ├── test_ccxtools.py
│ │ │ │ ├── test_common.py
│ │ │ │ ├── test_femimport.py
│ │ │ │ ├── test_material.py
│ │ │ │ ├── test_mesh.py
│ │ │ │ ├── test_object.py
│ │ │ │ ├── test_open.py
│ │ │ │ ├── test_result.py
│ │ │ │ └── test_solverframework.py
│ │ │ ├── data
│ │ │ │ ├── ccx
│ │ │ │ │ ├── canti_ccx_faceload_hexa20.inp
│ │ │ │ │ ├── constraint_contact_shell_shell.FCStd
│ │ │ │ │ ├── constraint_contact_shell_shell.inp
│ │ │ │ │ ├── constraint_contact_solid_solid.FCStd
│ │ │ │ │ ├── constraint_contact_solid_solid.inp
│ │ │ │ │ ├── constraint_tie.inp
│ │ │ │ │ ├── cube.FCStd
│ │ │ │ │ ├── cube_frequency.dat
│ │ │ │ │ ├── cube_frequency_expected_values
│ │ │ │ │ ├── cube_frequency.FCStd
│ │ │ │ │ ├── cube_frequency.frd
│ │ │ │ │ ├── cube_frequency.inp
│ │ │ │ │ ├── cube_static.dat
│ │ │ │ │ ├── cube_static_expected_values
│ │ │ │ │ ├── cube_static.FCStd
│ │ │ │ │ ├── cube_static.frd
│ │ │ │ │ ├── cube_static.inp
│ │ │ │ │ ├── Flow1D_thermomech.dat
│ │ │ │ │ ├── Flow1D_thermomech_expected_values
│ │ │ │ │ ├── Flow1D_thermomech.FCStd
│ │ │ │ │ ├── Flow1D_thermomech.frd
│ │ │ │ │ ├── Flow1D_thermomech_inout_nodes.txt
│ │ │ │ │ ├── Flow1D_thermomech.inp
│ │ │ │ │ ├── mat_multiple.inp
│ │ │ │ │ ├── mat_nonlinear.inp
│ │ │ │ │ ├── spine_thermomech.dat
│ │ │ │ │ ├── spine_thermomech_expected_values
│ │ │ │ │ ├── spine_thermomech.FCStd
│ │ │ │ │ ├── spine_thermomech.frd
│ │ │ │ │ ├── spine_thermomech.inp
│ │ │ │ │ └── thermomech_bimetall.inp
│ │ │ │ ├── elmer
│ │ │ │ │ ├── case.sif
│ │ │ │ │ ├── ELMERSOLVER_STARTINFO
│ │ │ │ │ ├── group_mesh.geo
│ │ │ │ │ └── __init__.py
│ │ │ │ ├── mesh
│ │ │ │ │ ├── tetra10_mesh.inp
│ │ │ │ │ ├── tetra10_mesh.unv
│ │ │ │ │ ├── tetra10_mesh.vtk
│ │ │ │ │ ├── tetra10_mesh.yml
│ │ │ │ │ └── tetra10_mesh.z88
│ │ │ │ └── open
│ │ │ │ ├── all_objects_de9b3fb438.FCStd
│ │ │ ├── gui
│ │ │ │ └── test_open.py
│ │ │ ├── test_commands.sh
│ │ │ └── test_information.md
│ │ ├── femtools
│ │ │ ├── ccxtools.py
│ │ │ ├── checksanalysis.py
│ │ │ ├── constants.py
│ │ │ ├── errors.py
│ │ │ ├── femutils.py
│ │ │ ├── geomtools.py
│ │ │ ├── membertools.py
│ │ │ ├── migrate_app.py
│ │ │ └── tokrules.py
│ │ ├── femviewprovider
│ │ │ ├── view_base_femconstraint.py
│ │ │ ├── view_base_femobject.py
│ │ │ ├── view_constraint_bodyheatsource.py
│ │ │ ├── view_constraint_electrostaticpotential.py
│ │ │ ├── view_constraint_flowvelocity.py
│ │ │ ├── view_constraint_initialflowvelocity.py
│ │ │ ├── view_constraint_selfweight.py
│ │ │ ├── view_constraint_tie.py
│ │ │ ├── view_element_fluid1D.py
│ │ │ ├── view_element_geometry1D.py
│ │ │ ├── view_element_geometry2D.py
│ │ │ ├── view_element_rotation1D.py
│ │ │ ├── view_material_common.py
│ │ │ ├── view_material_mechanicalnonlinear.py
│ │ │ ├── view_material_reinforced.py
│ │ │ ├── view_mesh_boundarylayer.py
│ │ │ ├── view_mesh_gmsh.py
│ │ │ ├── view_mesh_group.py
│ │ │ ├── view_mesh_region.py
│ │ │ ├── view_mesh_result.py
│ │ │ ├── view_result_mechanical.py
│ │ │ └── view_solver_ccxtools.py
│ │ ├── InitGui.py
│ │ ├── Init.py
│ │ ├── ObjectsFem.py
│ │ ├── Resources
│ │ │ └── ui
│ │ │ ├── ConstraintTie.ui
│ │ │ ├── ElectrostaticPotential.ui
│ │ │ ├── ElementFluid1D.ui
│ │ │ ├── ElementGeometry1D.ui
│ │ │ ├── ElementGeometry2D.ui
│ │ │ ├── ElementRotation1D.ui
│ │ │ ├── FlowVelocity.ui
│ │ │ ├── InitialFlowVelocity.ui
│ │ │ ├── MaterialReinforcement.ui
│ │ │ ├── Material.ui
│ │ │ ├── MeshBoundaryLayer.ui
│ │ │ ├── MeshGmsh.ui
│ │ │ ├── MeshGroup.ui
│ │ │ ├── MeshGroupXDMFExport.ui
│ │ │ ├── MeshRegion.ui
│ │ │ ├── ResultHints.ui
│ │ │ ├── ResultShow.ui
│ │ │ └── SolverCalculix.ui
│ │ ├── TestFemApp.py
│ │ └── TestFemGui.py
│ ├── Idf
│ │ ├── Idflibs
│ │ │ ├── 0603_SMD.stp
│ │ │ ├── 0805_SMD.stp
│ │ │ ├── 1206_SMD.stp
│ │ │ ├── 1210_SMD.stp
│ │ │ ├── 1812_SMD.stp
│ │ │ ├── 2225_SMD.stp
│ │ │ ├── 2512_SMD.stp
│ │ │ ├── CAP_50SGV_8_10.stp
│ │ │ ├── EPL22_6_16.stp
│ │ │ ├── footprints_models.csv
│ │ │ ├── I22_2_5_16.stp
│ │ │ ├── I22_2_5_16withEPL22_6_16.stp
│ │ │ ├── License.txt
│ │ │ ├── MSOP_10.stp
│ │ │ ├── RLF_12545.igs
│ │ │ ├── RLF_12545.stp
│ │ │ ├── RLF_7030.stp
│ │ │ ├── SMB_DO_214AA.stp
│ │ │ ├── SMC_DO_214AB.stp
│ │ │ ├── SOD_323.igs
│ │ │ ├── SOD_323.stp
│ │ │ ├── SOD_523.stp
│ │ │ ├── SOT23.igs
│ │ │ ├── SOT23.stp
│ │ │ ├── SOT_323_3.stp
│ │ │ ├── SOT404.igs
│ │ │ ├── SOT404.stp
│ │ │ ├── SOT428_DPAK.stp
│ │ │ ├── SOT_96.stp
│ │ │ ├── TCMT1107_4.stp
│ │ │ ├── TSM_103_01_L_DV_A.stp
│ │ │ ├── TSM_104_01_L_DV_A.stp
│ │ │ ├── TSS0P_8.stp
│ │ │ └── VC0603_SMD.stp
│ │ ├── Idf.py
│ │ └── Init.py
│ ├── Image
│ │ ├── ImageTools
│ │ │ ├── _CommandImageScaling.py
│ │ ├── InitGui.py
│ │ └── Init.py
│ ├── Import
│ │ ├── gzip_utf8.py
│ │ ├── InitGui.py
│ │ ├── Init.py
│ │ └── stepZ.py
│ ├── Inspection
│ │ ├── InitGui.py
│ │ └── Init.py
│ ├── Material
│ │ ├── importFCMat.py
│ │ ├── InitGui.py
│ │ ├── Init.py
│ │ ├── MaterialEditor.py
│ │ ├── Material.py
│ │ ├── Material_rc.py
│ │ ├── materials-editor.ui
│ │ ├── materialtools
│ │ │ ├── cardutils.py
│ │ └── Templatematerial.yml
│ ├── Measure
│ │ └── Init.py
│ ├── Mesh
│ │ ├── BuildRegularGeoms.py
│ │ ├── InitGui.py
│ │ ├── Init.py
│ │ └── MeshTestsApp.py
│ ├── MeshPart
│ │ ├── InitGui.py
│ │ ├── Init.py
│ │ └── MeshFlatteningCommand.py
│ ├── OpenSCAD
│ │ ├── colorcodeshapes.py
│ │ ├── expandplacements.py
│ │ ├── exportCSG.py
│ │ ├── importCSG.py
│ │ ├── InitGui.py
│ │ ├── Init.py
│ │ ├── OpenSCAD2Dgeom.py
│ │ ├── OpenSCADCommands.py
│ │ ├── OpenSCADFeatures.py
│ │ ├── OpenSCAD_rc.py
│ │ ├── OpenSCADUtils.py
│ │ ├── replaceobj.py
│ │ └── tokrules.py
│ ├── Part
│ │ ├── AttachmentEditor
│ │ │ ├── Commands.py
│ │ │ ├── FrozenClass.py
│ │ │ ├── TaskAttachmentEditor.py
│ │ │ └── TaskAttachmentEditor.ui
│ │ ├── BasicShapes
│ │ │ └── Shapes.py
│ │ ├── BOPTools
│ │ │ ├── GeneralFuseResult.py
│ │ │ ├── JoinAPI.py
│ │ │ ├── JoinFeatures.py
│ │ │ ├── ShapeMerge.py
│ │ │ ├── SplitAPI.py
│ │ │ ├── SplitFeatures.py
│ │ │ └── Utils.py
│ │ ├── CompoundTools
│ │ │ ├── _CommandCompoundFilter.py
│ │ │ ├── _CommandExplodeCompound.py
│ │ │ ├── CompoundFilter.py
│ │ │ ├── Explode.py
│ │ ├── InitGui.py
│ │ ├── Init.py
│ │ ├── MakeBottle.py
│ │ ├── parttests
│ │ │ └── part_test_objects.py
│ │ ├── TestPartApp.py
│ │ └── TestPartGui.py
│ ├── PartDesign
│ │ ├── fcgear
│ │ │ ├── fcgeardialog.py
│ │ │ ├── fcgear.py
│ │ │ ├── involute.py
│ │ │ └── svggear.py
│ │ ├── fcsprocket
│ │ │ ├── fcsprocketdialog.py
│ │ │ ├── fcsprocket.py
│ │ │ └── sprocket.py
│ │ ├── InitGui.py
│ │ ├── __init__.py
│ │ ├── Init.py
│ │ ├── InvoluteGearFeature.py
│ │ ├── InvoluteGearFeature.ui
│ │ ├── PartDesignTests
│ │ │ ├── TestBoolean.py
│ │ │ ├── TestChamfer.py
│ │ │ ├── TestDatum.py
│ │ │ ├── TestDraft.py
│ │ │ ├── TestFillet.py
│ │ │ ├── TestHole.py
│ │ │ ├── TestLinearPattern.py
│ │ │ ├── TestLoft.py
│ │ │ ├── TestMirrored.py
│ │ │ ├── TestMultiTransform.py
│ │ │ ├── TestPad.py
│ │ │ ├── TestPipe.py
│ │ │ ├── TestPocket.py
│ │ │ ├── TestPolarPattern.py
│ │ │ ├── TestPrimitive.py
│ │ │ ├── TestRevolve.py
│ │ │ ├── TestShapeBinder.py
│ │ │ └── TestThickness.py
│ │ ├── Scripts
│ │ │ ├── DistanceBolt.py
│ │ │ ├── Epitrochoid.py
│ │ │ ├── FilletArc.py
│ │ │ ├── Gear.py
│ │ │ ├── Parallelepiped.py
│ │ │ ├── RadialCopy.py
│ │ │ └── Spring.py
│ │ ├── SprocketFeature.py
│ │ ├── SprocketFeature.ui
│ │ ├── TestPartDesignApp.py
│ │ ├── TestPartDesignGui.py
│ │ └── WizardShaft
│ │ ├── __init__.py
│ │ ├── SegmentFunction.py
│ │ ├── ShaftDiagram.py
│ │ ├── ShaftFeature.py
│ │ ├── Shaft.py
│ │ ├── WizardShaft.py
│ │ ├── WizardShaft.svg
│ │ └── WizardShaftTable.py
│ ├── Path
│ │ ├── Images
│ │ │ ├── Ops
│ │ │ │ └── chamfer.svg
│ │ │ └── Tools
│ │ │ ├── drill.svg
│ │ │ ├── endmill.svg
│ │ │ └── v-bit.svg
│ │ ├── InitGui.py
│ │ ├── Init.py
│ │ ├── PathCommands.py
│ │ ├── PathScripts
│ │ │ ├── PathAdaptiveGui.py
│ │ │ ├── PathAdaptive.py
│ │ │ ├── PathAreaOp.py
│ │ │ ├── PathArray.py
│ │ │ ├── PathCircularHoleBaseGui.py
│ │ │ ├── PathCircularHoleBase.py
│ │ │ ├── PathCommands.py
│ │ │ ├── PathComment.py
│ │ │ ├── PathCopy.py
│ │ │ ├── PathCustomGui.py
│ │ │ ├── PathCustom.py
│ │ │ ├── PathDeburrGui.py
│ │ │ ├── PathDeburr.py
│ │ │ ├── PathDressupAxisMap.py
│ │ │ ├── PathDressupDogbone.py
│ │ │ ├── PathDressupDragknife.py
│ │ │ ├── PathDressupHoldingTags.py
│ │ │ ├── PathDressupLeadInOut.py
│ │ │ ├── PathDressupPathBoundaryGui.py
│ │ │ ├── PathDressupPathBoundary.py
│ │ │ ├── PathDressup.py
│ │ │ ├── PathDressupRampEntry.py
│ │ │ ├── PathDressupTagGui.py
│ │ │ ├── PathDressupTagPreferences.py
│ │ │ ├── PathDressupTag.py
│ │ │ ├── PathDressupZCorrect.py
│ │ │ ├── PathDrillingGui.py
│ │ │ ├── PathDrilling.py
│ │ │ ├── PathEngraveBase.py
│ │ │ ├── PathEngraveGui.py
│ │ │ ├── PathEngrave.py
│ │ │ ├── PathFixture.py
│ │ │ ├── PathGeom.py
│ │ │ ├── PathGetPoint.py
│ │ │ ├── PathGuiInit.py
│ │ │ ├── PathGui.py
│ │ │ ├── PathHelixGui.py
│ │ │ ├── PathHelix.py
│ │ │ ├── PathHop.py
│ │ │ ├── PathIconViewProvider.py
│ │ │ ├── PathInspect.py
│ │ │ ├── PathJobCmd.py
│ │ │ ├── PathJobDlg.py
│ │ │ ├── PathJobGui.py
│ │ │ ├── PathJob.py
│ │ │ ├── PathLog.py
│ │ │ ├── PathMillFaceGui.py
│ │ │ ├── PathMillFace.py
│ │ │ ├── PathOpGui.py
│ │ │ ├── PathOp.py
│ │ │ ├── PathOpTools.py
│ │ │ ├── PathPocketBaseGui.py
│ │ │ ├── PathPocketBase.py
│ │ │ ├── PathPocketGui.py
│ │ │ ├── PathPocket.py
│ │ │ ├── PathPocketShapeGui.py
│ │ │ ├── PathPocketShape.py
│ │ │ ├── PathPostProcessor.py
│ │ │ ├── PathPost.py
│ │ │ ├── PathPreferencesPathDressup.py
│ │ │ ├── PathPreferencesPathJob.py
│ │ │ ├── PathPreferences.py
│ │ │ ├── PathProbeGui.py
│ │ │ ├── PathProbe.py
│ │ │ ├── PathProfileContourGui.py
│ │ │ ├── PathProfileContour.py
│ │ │ ├── PathProfileEdgesGui.py
│ │ │ ├── PathProfileEdges.py
│ │ │ ├── PathProfileFacesGui.py
│ │ │ ├── PathProfileFaces.py
│ │ │ ├── PathProfileGui.py
│ │ │ ├── PathProfile.py
│ │ │ ├── PathSanity.py
│ │ │ ├── PathSelection.py
│ │ │ ├── PathSetupSheetGui.py
│ │ │ ├── PathSetupSheetOpPrototypeGui.py
│ │ │ ├── PathSetupSheetOpPrototype.py
│ │ │ ├── PathSetupSheet.py
│ │ │ ├── PathSimpleCopy.py
│ │ │ ├── PathSimulatorGui.py
│ │ │ ├── PathSlotGui.py
│ │ │ ├── PathSlot.py
│ │ │ ├── PathStock.py
│ │ │ ├── PathStop.py
│ │ │ ├── PathSurfaceGui.py
│ │ │ ├── PathSurface.py
│ │ │ ├── PathSurfaceSupport.py
│ │ │ ├── PathToolBitCmd.py
│ │ │ ├── PathToolBitEdit.py
│ │ │ ├── PathToolBitGui.py
│ │ │ ├── PathToolBitLibraryCmd.py
│ │ │ ├── PathToolBitLibraryGui.py
│ │ │ ├── PathToolBit.py
│ │ │ ├── PathToolControllerGui.py
│ │ │ ├── PathToolController.py
│ │ │ ├── PathToolEdit.py
│ │ │ ├── PathToolLibraryEditor.py
│ │ │ ├── PathToolLibraryManager.py
│ │ │ ├── PathUtil.py
│ │ │ ├── PathUtilsGui.py
│ │ │ ├── PathUtils.py
│ │ │ ├── PathWaterlineGui.py
│ │ │ ├── PathWaterline.py
│ │ │ ├── post
│ │ │ │ ├── centroid_post.py
│ │ │ │ ├── comparams_post.py
│ │ │ │ ├── dynapath_post.py
│ │ │ │ ├── example_pre.py
│ │ │ │ ├── gcode_pre.py
│ │ │ │ ├── grbl_post.py
│ │ │ │ ├── jtech_post.py
│ │ │ │ ├── linuxcnc_post.py
│ │ │ │ ├── mach3_mach4_post.py
│ │ │ │ ├── opensbp_post.py
│ │ │ │ ├── opensbp_pre.py
│ │ │ │ ├── philips_post.py
│ │ │ │ ├── rml_post.py
│ │ │ │ ├── slic3r_pre.py
│ │ │ │ └── smoothie_post.py
│ │ │ └── PostUtils.py
│ │ ├── PathTests
│ │ │ ├── boxtest.fcstd
│ │ │ ├── PathTestUtils.py
│ │ │ ├── test_centroid_00.ngc
│ │ │ ├── test_geomop.fcstd
│ │ │ ├── test_holes00.fcstd
│ │ │ ├── test_linuxcnc_00.ngc
│ │ │ ├── TestPathCore.py
│ │ │ ├── TestPathDeburr.py
│ │ │ ├── TestPathDepthParams.py
│ │ │ ├── TestPathDressupDogbone.py
│ │ │ ├── TestPathDressupHoldingTags.py
│ │ │ ├── TestPathGeom.py
│ │ │ ├── TestPathHelix.py
│ │ │ ├── TestPathLog.py
│ │ │ ├── TestPathOpTools.py
│ │ │ ├── TestPathPost.py
│ │ │ ├── TestPathPreferences.py
│ │ │ ├── TestPathSetupSheet.py
│ │ │ ├── TestPathStock.py
│ │ │ ├── TestPathToolBit.py
│ │ │ ├── TestPathToolController.py
│ │ │ ├── TestPathTool.py
│ │ │ ├── TestPathTooltable.py
│ │ │ └── TestPathUtil.py
│ │ ├── TestPathApp.py
│ │ └── Tools
│ │ ├── Bit
│ │ │ ├── t1.fctb
│ │ │ ├── t2.fctb
│ │ │ ├── t3.fctb
│ │ │ ├── t4.fctb
│ │ │ ├── t5.fctb
│ │ │ ├── t6.fctb
│ │ │ ├── t7.fctb
│ │ │ ├── t8.fctb
│ │ │ └── t9.fctb
│ │ ├── Library
│ │ │ └── endmills.fctl
│ │ └── Shape
│ │ ├── ballend.fcstd
│ │ ├── bullnose.fcstd
│ │ ├── drill.fcstd
│ │ ├── endmill.fcstd
│ │ └── v-bit.fcstd
│ ├── Points
│ │ ├── InitGui.py
│ │ └── Init.py
│ ├── Raytracing
│ │ ├── InitGui.py
│ │ ├── Init.py
│ │ └── RaytracingExample.py
│ │ ├── InitGui.py
│ │ └── Init.py
│ ├── Robot
│ │ ├── InitGui.py
│ │ ├── Init.py
│ │ ├── KukaExporter.py
│ │ ├── MovieTool.py
│ │ ├── RobotExample.py
│ │ └── RobotExampleTrajectoryOutOfShapes.py
│ ├── Show
│ │ ├── Containers.py
│ │ ├── DepGraphTools.py
│ │ ├── __init__.py
│ │ ├── mTempoVis.py
│ │ ├── SceneDetail.py
│ │ ├── SceneDetails
│ │ │ ├── Camera.py
│ │ │ ├── ClipPlane.py
│ │ │ ├── ObjectClipPlane.py
│ │ │ ├── Pickability.py
│ │ │ ├── VProperty.py
│ │ │ └── Workbench.py
│ │ ├── ShowUtils.py
│ │ ├── TVObserver.py
│ │ └── TVStack.py
│ ├── Sketcher
│ │ ├── InitGui.py
│ │ ├── Init.py
│ │ ├── ProfileLib
│ │ │ ├── Hexagon.py
│ │ │ └── RegularPolygon.py
│ │ ├── Profiles.py
│ │ ├── SketcherExample.py
│ │ ├── TestSketcherApp.py
│ │ └── TestSketcherGui.py
│ ├── Spreadsheet
│ │ ├── importXLSX.py
│ │ ├── InitGui.py
│ │ ├── Init.py
│ │ └── TestSpreadsheet.py
│ ├── Start
│ │ ├── InitGui.py
│ │ ├── Init.py
│ │ └── StartPage
│ │ ├── __init__.py
│ │ ├── StartPage.py
│ │ └── TranslationTexts.py
│ ├── Surface
│ │ ├── InitGui.py
│ │ └── Init.py
│ ├── TechDraw
│ │ ├── InitGui.py
│ │ ├── Init.py
│ │ ├── TDTest
│ │ │ ├── DHatchTest.py
│ │ │ ├── DProjGroupTest.py
│ │ │ ├── DVAnnoSymImageTest.py
│ │ │ ├── DVBalloonTest.py
│ │ │ ├── DVDimensionTest.py
│ │ │ ├── DVPartTest.py
│ │ │ ├── DVSectionTest.py
│ │ │ ├── TestHatch.svg
│ │ │ ├── TestSymbol.svg
│ │ │ └── TestTemplate.svg
│ │ └── TestTechDrawApp.py
│ ├── Test
│ │ ├── BaseTests.py
│ │ ├── Document.py
│ │ ├── InitGui.py
│ │ ├── __init__.py
│ │ ├── Init.py
│ │ ├── Menu.py
│ │ ├── qtunittest.py
│ │ ├── TestApp.py
│ │ ├── TestGui.py
│ │ ├── testmakeWireString.py
│ │ ├── TestPythonSyntax.py
│ │ ├── UnicodeTests.py
│ │ ├── unittestgui.py
│ │ ├── UnitTests.py
│ ├── Tux
│ │ ├── InitGui.py
│ │ ├── NavigationIndicatorGui.py
│ │ ├── PersistentToolbarsGui.py
│ │ ├── PersistentToolbars.py
│ │ └── Tux_rc.py
│ └── Web
│ ├── InitGui.py
│ ├── Init.py
│ └── TestWebGui.py
└── share
├── 3Dconnexion
│ └── 3DConnexion.xml
├── applications
│ └── org.freecadweb.FreeCAD.desktop
├── doc
│ └── FreeCAD
│ ├── freecad.qch
│ ├── freecad.qhc
│ └── ThirdPartyLibraries.html
├── examples
│ ├── ArchDetail.FCStd
│ ├── draft_test_objects.FCStd
│ ├── EngineBlock.FCStd
│ ├── FemCalculixCantilever2D.FCStd
│ ├── FemCalculixCantilever3D.FCStd
│ ├── FemCalculixCantilever3D_newSolver.FCStd
│ ├── PartDesignExample.FCStd
│ ├── RobotExample.FCStd
│ └── Schenkel.stp
├── Gui
│ └── Stylesheets
│ ├── Dark-blue.qss
│ ├── Dark-contrast.qss
│ ├── Darker-blue.qss
│ ├── Darker-green.qss
│ ├── Darker-orange.qss
│ ├── Dark-green.qss
│ ├── Dark-orange.qss
│ ├── images_dark-light
│ │ ├── background_freecad_dark.svg
│ │ ├── background_freecad_light.svg
│ │ ├── background_freecad.svg
│ │ ├── branch_end_closed_dark.svg
│ │ ├── branch_end_closed_light.svg
│ │ ├── branch_end_dark.svg
│ │ ├── branch_end_light.svg
│ │ ├── branch_end_open_dark.svg
│ │ ├── branch_end_open_light.svg
│ │ ├── branch_more_closed_dark.svg
│ │ ├── branch_more_closed_light.svg
│ │ ├── branch_more_dark.svg
│ │ ├── branch_more_light.svg
│ │ ├── branch_more_open_dark.svg
│ │ ├── branch_more_open_light.svg
│ │ ├── branch_vline_dark.svg
│ │ ├── branch_vline_light.svg
│ │ ├── checkbox_indeterminate_light.svg
│ │ ├── checkbox_light.svg
│ │ ├── close_dark.svg
│ │ ├── close_light.svg
│ │ ├── down_arrow_darker.svg
│ │ ├── down_arrow_dark.svg
│ │ ├── down_arrow_disabled_dark.svg
│ │ ├── down_arrow_disabled_light.svg
│ │ ├── down_arrow_lighter.svg
│ │ ├── down_arrow_light.svg
│ │ ├── Hmovetoolbar_dark.svg
│ │ ├── Hmovetoolbar_light.svg
│ │ ├── Hsepartoolbar_dark.svg
│ │ ├── Hsepartoolbar_light.svg
│ │ ├── left_arrow_darker.svg
│ │ ├── left_arrow_dark.svg
│ │ ├── left_arrow_disabled_dark.svg
│ │ ├── left_arrow_disabled_light.svg
│ │ ├── left_arrow_lighter.svg
│ │ ├── left_arrow_light.svg
│ │ ├── more_dark.svg
│ │ ├── more_light.svg
│ │ ├── radiobutton_dark.svg
│ │ ├── radiobutton_light.svg
│ │ ├── right_arrow_darker.svg
│ │ ├── right_arrow_dark.svg
│ │ ├── right_arrow_disabled_dark.svg
│ │ ├── right_arrow_disabled_light.svg
│ │ ├── right_arrow_lighter.svg
│ │ ├── right_arrow_light.svg
│ │ ├── sizegrip_dark.svg
│ │ ├── sizegrip_light.svg
│ │ ├── splitter_horizontal_dark.svg
│ │ ├── splitter_horizontal_light.svg
│ │ ├── splitter_vertical_dark.svg
│ │ ├── splitter_vertical_light.svg
│ │ ├── transparent.svg
│ │ ├── undock_dark.svg
│ │ ├── undock_light.svg
│ │ ├── up_arrow_darker.svg
│ │ ├── up_arrow_dark.svg
│ │ ├── up_arrow_disabled_dark.svg
│ │ ├── up_arrow_disabled_light.svg
│ │ ├── up_arrow_lighter.svg
│ │ ├── up_arrow_light.svg
│ │ ├── up-down_arrow_darker.svg
│ │ ├── up-down_arrow_dark.svg
│ │ ├── up-down_arrow_disabled_dark.svg
│ │ ├── up-down_arrow_disabled_light.svg
│ │ ├── up-down_arrow_lighter.svg
│ │ ├── up-down_arrow_light.svg
│ │ ├── Vmovetoolbar_dark.svg
│ │ ├── Vmovetoolbar_light.svg
│ │ ├── Vsepartoolbar_dark.svg
│ │ └── Vsepartoolbar_light.svg
│ ├── Light-blue.qss
│ ├── Light-green.qss
│ └── Light-orange.qss
├── icons
│ └── hicolor
│ ├── 16x16
│ │ └── apps
│ ├── 32x32
│ │ └── apps
│ ├── 48x48
│ │ └── apps
│ ├── 64x64
│ │ └── apps
│ └── scalable
│ ├── apps
│ │ ├── freecad.svg
│ │ └── org.freecadweb.FreeCAD.svg
│ └── mimetypes
│ └── application-x-extension-fcstd.svg
├── License.txt
├── metainfo
│ └── org.freecadweb.FreeCAD.appdata.xml
├── mime
│ └── packages
│ └── org.freecadweb.FreeCAD.xml
├── Mod
│ ├── Arch
│ │ ├── Presets
│ │ │ ├── ifc_contexts_IFC2X3.json
│ │ │ ├── ifc_contexts_IFC4.json
│ │ │ ├── ifc_products_IFC2X3.json
│ │ │ ├── ifc_products_IFC4.json
│ │ │ ├── ifc_types_IFC2X3.json
│ │ │ ├── ifc_types_IFC4.json
│ │ │ ├── profiles.csv
│ │ │ └── pset_definitions.csv
│ │ └── Resources
│ │ └── icons
│ │ └── ArchWorkbench.svg
│ ├── Complete
│ │ └── Resources
│ │ └── icons
│ │ └── CompleteWorkbench.svg
│ ├── Draft
│ │ └── Resources
│ │ └── icons
│ │ └── DraftWorkbench.svg
│ ├── Drawing
│ │ ├── Resources
│ │ │ └── icons
│ │ │ └── DrawingWorkbench.svg
│ │ └── Templates
│ │ ├── A0_Landscape_ISO7200.dxf
│ │ ├── A0_Landscape_ISO7200.svg
│ │ ├── A0_Landscape_plain.dxf
│ │ ├── A0_Landscape_plain.svg
│ │ ├── A0_Portrait_plain.dxf
│ │ ├── A0_Portrait_plain.svg
│ │ ├── A1_Landscape_ISO7200.dxf
│ │ ├── A1_Landscape_ISO7200.svg
│ │ ├── A1_Landscape_plain.dxf
│ │ ├── A1_Landscape_plain.svg
│ │ ├── A1_Portrait_plain.dxf
│ │ ├── A1_Portrait_plain.svg
│ │ ├── A2_Landscape_ISO7200.dxf
│ │ ├── A2_Landscape_ISO7200.svg
│ │ ├── A2_Landscape_plain.dxf
│ │ ├── A2_Landscape_plain.svg
│ │ ├── A2_Portrait_plain.dxf
│ │ ├── A2_Portrait_plain.svg
│ │ ├── A3_Landscape.dxf
│ │ ├── A3_Landscape_ISO7200.dxf
│ │ ├── A3_Landscape_ISO7200.svg
│ │ ├── A3_Landscape_plain.dxf
│ │ ├── A3_Landscape_plain.svg
│ │ ├── A3_Landscape.svg
│ │ ├── A3_Portrait_plain.dxf
│ │ ├── A3_Portrait_plain.svg
│ │ ├── A4_Landscape.dxf
│ │ ├── A4_Landscape_ISO7200.dxf
│ │ ├── A4_Landscape_ISO7200.svg
│ │ ├── A4_Landscape_plain.dxf
│ │ ├── A4_Landscape_plain.svg
│ │ ├── A4_Landscape.svg
│ │ ├── A4_Portrait_ISO7200.dxf
│ │ ├── A4_Portrait_ISO7200.svg
│ │ ├── A4_Portrait_plain.dxf
│ │ └── A4_Portrait_plain.svg
│ ├── Fem
│ │ └── Resources
│ │ └── icons
│ │ └── FemWorkbench.svg
│ ├── Image
│ │ └── Resources
│ │ └── icons
│ │ └── ImageWorkbench.svg
│ ├── Import
│ │ └── DxfPlate
│ │ ├── blocks10.rub
│ │ ├── blocks112.rub
│ │ ├── blocks114.rub
│ │ ├── classes14.rub
│ │ ├── entities0.rub
│ │ ├── entities12.rub
│ │ ├── entities14.rub
│ │ ├── header0.rub
│ │ ├── header12.rub
│ │ ├── header14.rub
│ │ ├── objects14.rub
│ │ ├── tables10.rub
│ │ ├── tables112.rub
│ │ ├── tables114.rub
│ │ ├── tables20.rub
│ │ ├── tables212.rub
│ │ └── tables214.rub
│ ├── Inspection
│ │ └── Resources
│ │ └── icons
│ │ └── InspectionWorkbench.svg
│ ├── Material
│ │ ├── FluidMaterial
│ │ │ ├── Air.FCMat
│ │ │ ├── None.FCMat
│ │ │ └── Water.FCMat
│ │ └── StandardMaterial
│ │ ├── ABS-Generic.FCMat
│ │ ├── Acrylic-Glass-Generic.FCMat
│ │ ├── AlMg3F24.FCMat
│ │ ├── AlMgSi1F31.FCMat
│ │ ├── Aluminum-6061-T6.FCMat
│ │ ├── AlZn4-5Mg1F35.FCMat
│ │ ├── CalculiX-Steel.FCMat
│ │ ├── Concrete-EN-C35_45.FCMat
│ │ ├── Concrete-Generic.FCMat
│ │ ├── Glass-E-GlassFibre.FCMat
│ │ ├── Glass-Generic.FCMat
│ │ ├── Glass-S2-GlassFibre.FCMat
│ │ ├── None.FCMat
│ │ ├── PA6-Generic.FCMat
│ │ ├── PET-Generic.FCMat
│ │ ├── PLA-Generic.FCMat
│ │ ├── PP-Generic.FCMat
│ │ ├── PTFE-Generic.FCMat
│ │ ├── PVC-Generic.FCMat
│ │ ├── Reinforcement-FIB-B500.FCMat
│ │ ├── Steel-15CrNi6.FCMat
│ │ ├── Steel-17CrNiMo6.FCMat
│ │ ├── Steel-1C22.FCMat
│ │ ├── Steel-1C35.FCMat
│ │ ├── Steel-1C45.FCMat
│ │ ├── Steel-1C60.FCMat
│ │ ├── Steel-20NiCrMo2.FCMat
│ │ ├── Steel-28Mn6.FCMat
│ │ ├── Steel-2C10.FCMat
│ │ ├── Steel-30CrNiMo8.FCMat
│ │ ├── Steel-34CrNiMo6.FCMat
│ │ ├── Steel-36CrNiMo4.FCMat
│ │ ├── Steel-36NiCrMo16.FCMat
│ │ ├── Steel-3C15.FCMat
│ │ ├── Steel-3C22.FCMat
│ │ ├── Steel-3C35.FCMat
│ │ ├── Steel-3V45.FCMat
│ │ ├── Steel-C10.FCMat
│ │ ├── Steel-C15.FCMat
│ │ ├── Steel-C22E.FCMat
│ │ ├── Steel-C25E.FCMat
│ │ ├── Steel-C30E.FCMat
│ │ ├── Steel-C40E.FCMat
│ │ ├── Steel-C50E.FCMat
│ │ ├── Steel-C55E.FCMat
│ │ ├── Steel-C60E.FCMat
│ │ ├── Steel-E295.FCMat
│ │ ├── Steel-E295-GC.FCMat
│ │ ├── Steel-E335.FCMat
│ │ ├── Steel-E335-GC.FCMat
│ │ ├── Steel-E360.FCMat
│ │ ├── Steel-E360-GC.FCMat
│ │ ├── Steel-EN-GJL-100.FCMat
│ │ ├── Steel-EN-GJL-150.FCMat
│ │ ├── Steel-EN-GJL-200.FCMat
│ │ ├── Steel-EN-GJL-250.FCMat
│ │ ├── Steel-EN-GJL-300.FCMat
│ │ ├── Steel-EN-GJL-350.FCMat
│ │ ├── Steel-EN-GJMB-350-10.FCMat
│ │ ├── Steel-EN-GJMB-550-4.FCMat
│ │ ├── Steel-EN-GJMB-650-2.FCMat
│ │ ├── Steel-EN-GJMW-350-4.FCMat
│ │ ├── Steel-EN-GJMW-360-12.FCMat
│ │ ├── Steel-EN-GJMW-400-5.FCMat
│ │ ├── Steel-EN-GJMW-450-7.FCMat
│ │ ├── Steel-EN-GJS-400-15.FCMat
│ │ ├── Steel-EN-GJS-500-7.FCMat
│ │ ├── Steel-EN-GJS-600-3.FCMat
│ │ ├── Steel-EN-GJS-700-2.FCMat
│ │ ├── Steel-EN-GJS-800-1.FCMat
│ │ ├── Steel-G16Mn5.FCMat
│ │ ├── Steel-G200.FCMat
│ │ ├── Steel-G20Mn5.FCMat
│ │ ├── Steel-G230.FCMat
│ │ ├── Steel-G260.FCMat
│ │ ├── Steel-G300.FCMat
│ │ ├── Steel-G30Mn5.FCMat
│ │ ├── Steel-Generic.FCMat
│ │ ├── Steel-S185.FCMat
│ │ ├── Steel-S235JO.FCMat
│ │ ├── Steel-S235JR.FCMat
│ │ ├── Steel-S235JRG1.FCMat
│ │ ├── Steel-S260NC.FCMat
│ │ ├── Steel-S275JO.FCMat
│ │ ├── Steel-S275JR.FCMat
│ │ ├── Steel-S275N.FCMat
│ │ ├── Steel-S335JO.FCMat
│ │ ├── Steel-S335JR.FCMat
│ │ ├── Steel-S335N.FCMat
│ │ ├── Steel-S340MC.FCMat
│ │ ├── Steel-S355J2G3.FCMat
│ │ ├── Steel-S380MC.FCMat
│ │ ├── Steel-S420MC.FCMat
│ │ ├── Steel-S420N.FCMat
│ │ ├── Steel-S460MC.FCMat
│ │ ├── Steel-S460N.FCMat
│ │ ├── Steel-S500MC.FCMat
│ │ ├── Steel-S550MC.FCMat
│ │ ├── Steel-S690MC.FCMat
│ │ ├── Steel-St-37-2K.FCMat
│ │ ├── Steel-St-E-255.FCMat
│ │ ├── Steel-St-E-315.FCMat
│ │ ├── Steel-St-E-380.FCMat
│ │ ├── Steel-St-E-460.FCMat
│ │ ├── Steel-St-E-500.FCMat
│ │ ├── Steel-X2CrNiMoN17-13-3.FCMat
│ │ ├── Steel-X2CrNiN24-4.FCMat
│ │ ├── Steel-X39CrMo17-1.FCMat
│ │ ├── Steel-X3CrNiMo13-14.FCMat
│ │ ├── Steel-X5CrNi18-10.FCMat
│ │ ├── Steel-X5CrNiMo17-12-2.FCMat
│ │ ├── Steel-X6CrNiTi18-10.FCMat
│ │ ├── TEMPLATE.FCMat
│ │ ├── Tools
│ │ └── Wood-Generic.FCMat
│ ├── Mesh
│ │ └── Resources
│ │ └── icons
│ │ └── MeshWorkbench.svg
│ ├── OpenSCAD
│ │ └── Resources
│ │ └── icons
│ │ └── OpenSCADWorkbench.svg
│ ├── Part
│ │ └── Resources
│ │ └── icons
│ │ └── PartWorkbench.svg
│ ├── PartDesign
│ │ └── Resources
│ │ └── icons
│ │ └── PartDesignWorkbench.svg
│ ├── Path
│ │ └── Resources
│ │ └── icons
│ │ └── PathWorkbench.svg
│ ├── Points
│ │ └── Resources
│ │ └── icons
│ │ └── PointsWorkbench.svg
│ ├── Raytracing
│ │ ├── Resources
│ │ │ └── icons
│ │ │ └── RaytracingWorkbench.svg
│ │ └── Templates
│ │ ├── LuxClassic.lxs
│ │ ├── LuxOutdoor.lxs
│ │ ├── ProjectStd.pov
│ │ ├── RadiosityNormal.pov
│ │ └── RadiosityOutdoorHQ.pov
│ │ └── Resources
│ │ └── icons
│ │ └── ReverseEngineeringWorkbench.svg
│ ├── Robot
│ │ ├── Lib
│ │ │ └── Kuka
│ │ │ ├── kr125_3.wrl
│ │ │ ├── kr_125.csv
│ │ │ ├── kr_16.csv
│ │ │ ├── kr16.wrl
│ │ │ ├── kr_210_2.csv
│ │ │ ├── kr210.WRL
│ │ │ ├── kr500_1.csv
│ │ │ ├── kr500_1.wrl
│ │ │ ├── testprog.dat
│ │ │ └── testprog.src
│ │ └── Resources
│ │ └── icons
│ │ └── RobotWorkbench.svg
│ ├── Sketcher
│ │ └── Resources
│ │ └── icons
│ │ └── SketcherWorkbench.svg
│ ├── Spreadsheet
│ │ └── Resources
│ │ └── icons
│ │ └── SpreadsheetWorkbench.svg
│ ├── Start
│ │ ├── Resources
│ │ │ └── icons
│ │ │ └── StartWorkbench.svg
│ │ └── StartPage
│ │ ├── EnableDownload.py
│ │ ├── images
│ │ │ ├── new_file_thumbnail.svg
│ │ ├── LoadCustom.py
│ │ ├── LoadExample.py
│ │ ├── LoadMRU.py
│ │ ├── LoadNew.py
│ │ ├── OpenSettings.py
│ │ ├── StartPage.css
│ │ ├── StartPage.html
│ │ └── StartPage.js
│ ├── TechDraw
│ │ ├── LineGroup
│ │ │ └── LineGroup.csv
│ │ ├── PAT
│ │ │ └── FCPAT.pat
│ │ ├── Patterns
│ │ │ ├── aluminium.svg
│ │ │ ├── brick01.svg
│ │ │ ├── concrete.svg
│ │ │ ├── cross.svg
│ │ │ ├── cuprous.svg
│ │ │ ├── diagonal1.svg
│ │ │ ├── diagonal2.svg
│ │ │ ├── earth.svg
│ │ │ ├── general_steel.svg
│ │ │ ├── glass.svg
│ │ │ ├── hatch45L.svg
│ │ │ ├── hatch45R.svg
│ │ │ ├── hbone.svg
│ │ │ ├── line.svg
│ │ │ ├── plastic.svg
│ │ │ ├── plus.svg
│ │ │ ├── simple.svg
│ │ │ ├── solid.svg
│ │ │ ├── square.svg
│ │ │ ├── steel.svg
│ │ │ ├── titanium.svg
│ │ │ ├── woodgrain.svg
│ │ │ ├── wood.svg
│ │ │ └── zinc.svg
│ │ ├── Resources
│ │ │ ├── fonts
│ │ │ │ ├── osifont-lgpl3fe.ttf
│ │ │ │ └── osifont.license
│ │ │ └── icons
│ │ │ └── preferences-techdraw.svg
│ │ ├── Symbols
│ │ │ ├── gd-and-t
│ │ │ │ ├── angularity-left.svg
│ │ │ │ ├── angularity-right.svg
│ │ │ │ ├── ConcentricityFrame.svg
│ │ │ │ ├── concentricity.svg
│ │ │ │ ├── CylindricityFrame.svg
│ │ │ │ ├── cylindricity.svg
│ │ │ │ ├── FlatnessFrame.svg
│ │ │ │ ├── flatness.svg
│ │ │ │ ├── ParallelismFrame.svg
│ │ │ │ ├── parallelism.svg
│ │ │ │ ├── perpendicularity.svg
│ │ │ │ ├── position.svg
│ │ │ │ ├── profile-tolerance-of-line.svg
│ │ │ │ ├── profile-tolerance-of-plane.svg
│ │ │ │ ├── ReferenceSurface.svg
│ │ │ │ ├── RoundnessFrame.svg
│ │ │ │ ├── roundness.svg
│ │ │ │ ├── SquarenessFrame.svg
│ │ │ │ ├── symmetry.svg
│ │ │ │ └── totalrunout.svg
│ │ │ ├── other
│ │ │ │ ├── CutLine.svg
│ │ │ │ ├── Diameter.svg
│ │ │ │ ├── Envelope.svg
│ │ │ │ ├── FilletInside.svg
│ │ │ │ ├── FilletOutside.svg
│ │ │ │ ├── IndexCircle.svg
│ │ │ │ ├── IndexTriangle.svg
│ │ │ │ ├── InsideEdgeBroken.svg
│ │ │ │ ├── OutsideEdgeBroken.svg
│ │ │ │ ├── Rectangle.svg
│ │ │ │ ├── SectionLine.svg
│ │ │ │ └── Square.svg
│ │ │ ├── surface-roughness-symbols
│ │ │ │ ├── RoughnessGeneral.svg
│ │ │ │ ├── Roughness.svg
│ │ │ │ ├── surface-roughness-contour.svg
│ │ │ │ ├── surface-roughness-layer-removing.svg
│ │ │ │ ├── surface-roughness-no-layer-removing.svg
│ │ │ │ └── surface-roughness.svg
│ │ │ └── Welding
│ │ │ ├── AWS
│ │ │ │ ├── beadDown.svg
│ │ │ │ ├── beadUp.svg
│ │ │ │ ├── filletDown.svg
│ │ │ │ ├── filletUp.svg
│ │ │ │ ├── plug.svg
│ │ │ │ ├── SquareDown.svg
│ │ │ │ ├── SquareUp.svg
│ │ │ │ ├── VDown.svg
│ │ │ │ └── VUp.svg
│ │ │ ├── blankTile.svg
│ │ │ └── GOST
│ │ │ ├── edge-weld.svg
│ │ │ ├── flanging.svg
│ │ │ ├── flare-bevel-groove.svg
│ │ │ ├── flare-v-groove.svg
│ │ │ ├── gost-2_312
│ │ │ │ ├── cathetus.svg
│ │ │ │ ├── gost-2_312-intermittent.svg
│ │ │ │ ├── gost-2_312-non-closed.svg
│ │ │ │ ├── gost-2_312-site-weld.svg
│ │ │ │ ├── gost-2_312-smooth-processing.svg
│ │ │ │ └── gost-2_312-usilenie-remove.svg
│ │ │ ├── seam-weld.svg
│ │ │ ├── single-bevel-cjp-groove-weld.svg
│ │ │ ├── single-bevel-groove-weld.svg
│ │ │ ├── single-bevel-groove-weld-with-broad-root-face.svg
│ │ │ ├── single-j-groove-weld.svg
│ │ │ ├── single-u-groove-weld.svg
│ │ │ ├── single-v-cjp-groove-weld.svg
│ │ │ ├── single-v-groove-weld.svg
│ │ │ ├── single-v-groove-weld-with-broad-root-face.svg
│ │ │ ├── spile-weld.svg
│ │ │ ├── square-groove-weld.svg
│ │ │ └── surfacing.svg
│ │ └── Templates
│ │ ├── A0_Landscape_blank.svg
│ │ ├── A0_Landscape_ISO7200_Pep.svg
│ │ ├── A0_Landscape_ISO7200TD.svg
│ │ ├── A1_Landscape_blank.svg
│ │ ├── A1_Landscape_ISO7200_Pep.svg
│ │ ├── A1_Landscape_ISO7200TD.svg
│ │ ├── A2_Landscape_blank.svg
│ │ ├── A2_Landscape_ISO7200_Pep.svg
│ │ ├── A2_Landscape_ISO7200TD.svg
│ │ ├── A3_Landscape_blank.svg
│ │ ├── A3_Landscape_EN_m52.svg
│ │ ├── A3_Landscape_FR_m52.svg
│ │ ├── A3_Landscape_ISO7200_Pep.svg
│ │ ├── A3_Landscape_ISO7200TD.svg
│ │ ├── A3_Landscape_IT_m52.svg
│ │ ├── A3_LandscapeTD.svg
│ │ ├── A4_Landscape_blank.svg
│ │ ├── A4_Landscape_ISO7200_Pep.svg
│ │ ├── A4_Landscape_ISO7200TD.svg
│ │ ├── A4_LandscapeTD.svg
│ │ ├── A4_Portrait_blank.svg
│ │ ├── A4_Portrait_ISO7200Pep.svg
│ │ ├── A4_Portrait_ISO7200TD.svg
│ │ ├── ANSIB_Portrait.svg
│ │ ├── ANSIB.svg
│ │ ├── HowToExample.svg
│ │ ├── RU_GOST
│ │ │ ├── Leading
│ │ │ │ ├── Landscape_A0.svg
│ │ │ │ ├── Landscape_A1.svg
│ │ │ │ ├── Landscape_A2.svg
│ │ │ │ ├── Landscape_A3.svg
│ │ │ │ ├── Landscape_A4_NotInGOST.svg
│ │ │ │ ├── Portrait_A0.svg
│ │ │ │ ├── Portrait_A1.svg
│ │ │ │ ├── Portrait_A2.svg
│ │ │ │ ├── Portrait_A3.svg
│ │ │ │ └── Portrait_A4.svg
│ │ │ ├── Leading_text
│ │ │ └── Subsequent
│ │ │ ├── Landscape_A4.svg
│ │ ├── USLetter_Landscape_blank.svg
│ │ ├── USLetter_Landscape.svg
│ │ └── zh_CN
│ │ └── landscape
│ │ ├── A0_Landscape_CN.svg
│ │ ├── A1_Landscape_CN.svg
│ │ ├── A2_Landscape_CN.svg
│ │ ├── A3_Landscape_CN.svg
│ │ └── A4_Landscape_CN.svg
│ ├── Test
│ │ └── Resources
│ │ └── icons
│ │ └── TestWorkbench.svg
│ └── Web
│ └── Resources
│ └── icons
│ └── WebWorkbench.svg
└── pixmaps
└── freecad.xpm
229 directories, 1534 files
Forum thread: https://forum.freecadweb.org/viewtopic.php?f=10&t=47159 |
This ticket has been migrated to GitHub as issue 6067. |
| 2020-05-29 02:31 | hobbes1069 | New Issue | |
| 2020-05-29 02:31 | hobbes1069 | File Added: freecad-install.txt | |
| 2020-05-29 13:44 | hobbes1069 | Note Added: 0014437 | |
| 2020-05-29 22:31 | hobbes1069 | Note Added: 0014440 | |
| 2020-05-30 13:33 | hobbes1069 | Note Added: 0014443 | |
| 2020-06-02 16:21 | vocx | Note Added: 0014456 | |
| 2020-06-02 16:25 | hobbes1069 | Note Added: 0014457 | |
| 2020-06-03 17:26 | hobbes1069 | Note Edited: 0014457 | |
| 2020-07-01 09:18 | PrzemoF | Note Added: 0014607 | |
| 2020-07-01 09:18 | PrzemoF | File Added: FreeCAD_installation_locations.txt | |
| 2020-07-01 09:18 | PrzemoF | Note Added: 0014608 | |
| 2021-03-21 11:17 | Kunda1 | Tag Attached: cmake |
