| 0004462 | Draft | Bug | public | 2020-10-15 19:31 | 2020-12-01 11:17 |
| Reporter | hardrock | Assigned To | |||
| Priority | normal | Severity | major | Reproducibility | sometimes |
| Platform | x86-64 | OS | Ubuntu | OS Version | 18.04 |
| Summary | 0004462: Upgrade from shell to solid failed - UnboundLocalError | ||||
| Description | Therhe is number of faces. Need to make solid from them. Use Draft Upgrade to make shell. Use it again to make solid -> UnboundLocalError. | ||||
| Steps To Reproduce | 1. Select all faces 2. Use Draft Upgrade -> Shell will appear 3. Select shell, use Draft Upgrade -> error | ||||
| Additional Information | Report 22:30:42 ---------------- 22:30:42 GuiCommand: Upgrade 22:30:42 ---------------- 22:30:42 Upgrade objects 22:30:42 Found several objects: creating a shell 22:30:45 ---------------- 22:30:45 GuiCommand: Upgrade 22:30:45 ---------------- 22:30:45 Upgrade objects 22:30:45 Traceback (most recent call last): File "/usr/share/freecad-daily/Mod/Draft/draftutils/todo.py", line 167, in doTasks Gui.doCommand(string) File "<string>", line 1, in <module> File "/usr/share/freecad-daily/Mod/Draft/draftfunctions/upgrade.py", line 416, in upgrade result = makeSolid(objects[0]) File "/usr/share/freecad-daily/Mod/Draft/draftfunctions/upgrade.py", line 148, in makeSolid return newobj UnboundLocalError: local variable 'newobj' referenced before assignment 22:30:45 ToDo.doTasks, Unexpected error: <class 'UnboundLocalError'> in ['_objs_ = Draft.upgrade(FreeCADGui.Selection.getSelection(), delete=True)', 'FreeCAD.ActiveDocument.recompute()'] | ||||
| FreeCAD Information | OS: Ubuntu 18.04.4 LTS (Unity:Unity7:ubuntu/unity) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19. Build type: Release Branch: unknown Hash: b0d7850406e046f3b7a8cd5da261e7d54df6bd99 Python version: 3.6.9 Qt version: 5.9.5 Coin version: 4.0.0a OCC version: 7.3.0 Locale: Russian/Russia (ru_RU) | ||||
Discussion thread: https://forum.freecadweb.org/viewtopic.php?f=8&t=51204 |
fixed in this version: OS: macOS 10.15 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.22670 (Git) Build type: Release Branch: master Hash: 12155f4aab09047c5697db0c1b3cf93b02edda03 Python version: 3.8.6 Qt version: 5.12.9 Coin version: 4.0.0 OCC version: 7.4.0 Locale: C/Default (C) |
Many of the original faces do not pass the check geometry test. So it is expected that this would not work. |
How should we proceed. It sounds like PEBKAC |
Reopening as it seems FreeCAD Pull Request 4067 is related and has a fix for this ticket |
Certainly the error is because the shape is not closed, but the makeSolid function fails to catch this and generates the reported error. In the mentioned pull request this behavior is corrected. |
Changing status to 'fixed' and closing ticket |
FreeCAD: master 8e080f1d 2020-11-16 04:56:50 Details Diff |
Draft: Some fixes in upgrade function. bug 0004460, fixes 0004462, 0004080 |
Affected Issues 0004080, 0004460, 0004462 |
| mod - src/Mod/Draft/DraftGeomUtils.py | Diff File | ||
| mod - src/Mod/Draft/draftfunctions/upgrade.py | Diff File | ||
| mod - src/Mod/Draft/draftgeoutils/faces.py | Diff File | ||
| 2020-10-15 19:31 | hardrock | New Issue | |
| 2020-10-15 19:31 | hardrock | File Added: bug_upgrade_from_shell_to_solid_failed.FCStd | |
| 2020-10-15 21:19 | Kunda1 | Note Added: 0014878 | |
| 2020-10-15 21:19 | Kunda1 | Tag Attached: #pending-forum | |
| 2020-10-15 22:46 | chrisb | Assigned To | => chrisb |
| 2020-10-15 22:46 | chrisb | Status | new => closed |
| 2020-10-15 22:46 | chrisb | Resolution | open => unable to reproduce |
| 2020-10-15 22:46 | chrisb | Fixed in Version | => 0.19 |
| 2020-10-15 22:46 | chrisb | Note Added: 0014879 | |
| 2020-10-16 08:11 | jmaustpc | Note Added: 0014884 | |
| 2020-10-16 14:04 | openBrain | Tag Detached: #pending-forum | |
| 2020-11-14 11:12 | Kunda1 | Note Added: 0014985 | |
| 2020-11-20 17:23 | Kunda1 | Assigned To | chrisb => |
| 2020-11-20 17:23 | Kunda1 | Status | closed => confirmed |
| 2020-11-20 17:24 | Kunda1 | Note Added: 0015009 | |
| 2020-11-20 17:27 | Kunda1 | Relationship added | related to 0004460 |
| 2020-11-21 01:43 | marioalexis | Note Added: 0015012 | |
| 2020-11-25 10:30 | marioalexis | Changeset attached | => FreeCAD master 8e080f1d |
| 2020-11-25 10:30 | marioalexis | Note Added: 0015019 | |
| 2020-12-01 11:16 | Kunda1 | Status | confirmed => resolved |
| 2020-12-01 11:16 | Kunda1 | Description Updated | |
| 2020-12-01 11:16 | Kunda1 | Steps to Reproduce Updated | |
| 2020-12-01 11:16 | Kunda1 | Additional Information Updated | |
| 2020-12-01 11:16 | Kunda1 | FreeCAD Information | OS: Ubuntu 18.04.4 LTS (Unity:Unity7:ubuntu/unity) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19. Build type: Release Branch: unknown Hash: b0d7850406e046f3b7a8cd5da261e7d54df6bd99 Python version: 3.6.9 Qt version: 5.9.5 Coin versi... => OS: Ubuntu 18.04.4 LTS (Unity:Unity7:ubuntu/unity) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19. Build type: Release Branch: unknown Hash: b0d7850406e046f3b7a8cd5da261e7d54df6bd99 Python version: 3.6.9 Qt version: 5.9.5 C... |
| 2020-12-01 11:17 | Kunda1 | Resolution | unable to reproduce => fixed |
| 2020-12-01 11:17 | Kunda1 | Status | resolved => closed |
| 2020-12-01 11:17 | Kunda1 | Note Added: 0015030 |
