| 0004711 | FreeCAD | Bug | public | 2021-07-23 03:10 | 2022-02-06 13:44 |
| Reporter | kevinnguyen2020 | Assigned To | Kunda1 | ||
| Summary | 0004711: connect failed: No such file or directory (should be fixed in next point release of upstream spacenavd) | ||||
| Description | Run KiCAD from Terminal. FreeCAD 0.20, Libs: 0.20R25306 (Git) © Juergen Riegel, Werner Mayer, Yorik van Havre and others 2001-2021 FreeCAD is free and open-source software licensed under the terms of LGPL2+ license. FreeCAD wouldn't be possible without FreeCAD community. ##### #### ### #### # # # # # # # ## #### #### # # # # # #### # # # # # # # ##### # # # # #### #### # # # # # # # # # # # # # # ## ## ## # # #### #### ### # # #### ## ## ## connect failed: No such file or directory | ||||
| Steps To Reproduce | 1. Build KiCAD 0.20 from source code...done 2. Run from Terminal | ||||
| Additional Information | FreeCAD 0.20, Libs: 0.20R25306 (Git) © Juergen Riegel, Werner Mayer, Yorik van Havre and others 2001-2021 FreeCAD is free and open-source software licensed under the terms of LGPL2+ license. FreeCAD wouldn't be possible without FreeCAD community. ##### #### ### #### # # # # # # # ## #### #### # # # # # #### # # # # # # # ##### # # # # #### #### # # # # # # # # # # # # # # ## ## ## # # #### #### ### # # #### ## ## ## connect failed: No such file or directory | ||||
| Tags | 3dconnexion, spacenavigator, upstream | ||||
| FreeCAD Information | Version 0.20 | ||||
@kevinnguyen2020 : please address your issue according our reporting guidelines by opening a new topic on our forum. Thx Also make the difference between Kicad and FreeCAD. |
Next time as openBrain stated, please report to the forum. But anyway, we have no idea what OS you're on or where you d/led FC from? Also can you get the GUI to work? If so please post your full About info |
Forum thread: https://forum.freecadweb.org/viewtopic.php?f=8&t=65632 |
Opened upstream discussion: https://github.com/FreeSpacenav/spacenavd/issues/56 |
Upstream says it's fixed but not released. They're considering a minor release https://github.com/FreeSpacenav/spacenavd/issues/56#issuecomment-1030385338 |
Upstream released a new minor version (v0.3) https://github.com/FreeSpacenav/libspnav/releases/tag/v0.3 This ticket is now closed as the issue is solved as the different OS platforms/distros incorporate the latest version. |
| 2021-07-23 03:10 | kevinnguyen2020 | New Issue | |
| 2021-07-26 17:54 | openBrain | Status | new => feedback |
| 2021-07-26 17:54 | openBrain | Note Added: 0015756 | |
| 2021-07-28 00:00 | Kunda1 | Note Added: 0015761 | |
| 2022-01-24 20:12 | Kunda1 | Note Added: 0016280 | |
| 2022-01-24 20:13 | Kunda1 | Tag Attached: #pending-forum | |
| 2022-02-04 18:41 | Kunda1 | Note Added: 0016349 | |
| 2022-02-04 18:42 | Kunda1 | Tag Attached: upstream | |
| 2022-02-04 18:42 | Kunda1 | Tag Attached: 3dconnexion | |
| 2022-02-04 18:42 | Kunda1 | Tag Attached: spacenavigator | |
| 2022-02-04 18:43 | Kunda1 | Assigned To | => Kunda1 |
| 2022-02-04 18:43 | Kunda1 | Status | feedback => assigned |
| 2022-02-04 18:43 | Kunda1 | Tag Attached: #ready-for-migration | |
| 2022-02-04 18:44 | Kunda1 | Tag Detached: #pending-forum | |
| 2022-02-05 02:32 | Kunda1 | Note Added: 0016362 | |
| 2022-02-05 03:01 | Kunda1 | Summary | connect failed: No such file or directory => connect failed: No such file or directory (should be fixed in next point release of upstream spacenavd) |
| 2022-02-06 13:44 | Kunda1 | Status | assigned => closed |
| 2022-02-06 13:44 | Kunda1 | Resolution | open => fixed |
| 2022-02-06 13:44 | Kunda1 | Note Added: 0016363 | |
| 2022-02-06 13:44 | Kunda1 | Tag Detached: #ready-for-migration |
