| 0000617 | FreeCAD | Bug | public | 2012-03-02 04:48 | 2018-09-22 21:37 |
| Reporter | peepsalot | Assigned To | shoogen | ||
| Summary | 0000617: Error when fusing torus and tangent cylinder | ||||
| Description | When perfoming a fuse operation on torus and cylinder, the resulting shape is incomplete, missing most of it's faces. Attached is a simple python script which reproduces the issue. Here is an example picture of the cylinder and torus as separate pieces on the left, and the union result on the right. http://i.imgur.com/SknDA.png Ubuntu Linux 11.10 64bit FreeCAD 0.13 5076 (Launchpad) | ||||
| Tags | OCC Bug, OCC Unscheduled, upstream | ||||
2012-03-02 04:48
I confirm this, same FreeCAD version and OS. I tried revolving a circle to get a torus, and padding a tangent cylinder, but the fuse of both shapes fails as well. |
reproduced on Windows but without crash |
Using OCC 6.6 or later this works now. |
in occt 6.8 the BOP returns an invalid shape. The shell is reported to have Invalid MultiConnexity. |
http://tracker.dev.opencascade.org/view.php?id=25781 http://tracker.dev.opencascade.org/view.php?id=25771 |
With OCCT 7.0 it works and bop check doesn't report any errors any more. |
Confirmed on OCC 7.3.0. OS: Ubuntu 18.04.1 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.18.14784 (Git) Build type: Release Branch: master Hash: ac21bcc35c56b360e03c646f5cfdcf15e5769717 Python version: 2.7.15rc1 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 7.3.0 Locale: French/Canada (fr_CA) |
| 2012-03-02 04:48 | peepsalot | New Issue | |
| 2012-03-02 04:48 | peepsalot | File Added: UnionTest.py | |
| 2012-03-03 18:09 | normandc | Note Added: 0001702 | |
| 2012-03-09 06:16 |
Note Added: 0001731 | |
| 2012-03-09 06:16 |
| 2014-03-02 11:18 | wmayer | Note Added: 0004347 | |
| 2014-03-02 11:18 | wmayer | Status | acknowledged => closed |
| 2014-03-02 11:18 | wmayer | Resolution | open => no change required |
| 2014-03-02 11:18 | wmayer | Fixed in Version | => 0.14 |
| 2015-02-02 13:46 | shoogen | Assigned To | => shoogen |
| 2015-02-02 13:46 | shoogen | Note Added: 0005756 | |
| 2015-02-02 13:46 | shoogen | Status | closed => feedback |
| 2015-02-02 13:46 | shoogen | Resolution | no change required => reopened |
| 2015-02-02 13:46 | shoogen | Tag Attached: OCC Bug | |
| 2015-02-02 14:52 | shoogen | Note Added: 0005757 | |
| 2015-02-03 12:16 | shoogen | Status | feedback => acknowledged |
| 2017-01-15 04:44 | Kunda1 | Tag Attached: upstream | |
| 2017-01-27 01:27 | Kunda1 | Tag Attached: bump | |
| 2017-01-27 01:27 | Kunda1 | Tag Attached: unscheduled | |
| 2017-08-22 11:58 | Kunda1 | Tag Renamed | unscheduled => OCC Unscheduled |
| 2018-01-19 16:54 | Kunda1 | Description Updated | |
| 2018-01-19 16:55 | Kunda1 | Description Updated | |
| 2018-01-19 16:55 | Kunda1 | File Added: SknDA.png | |
| 2018-09-22 20:17 | wmayer | Status | acknowledged => closed |
| 2018-09-22 20:17 | wmayer | Fixed in Version | 0.14 => 0.17 |
| 2018-09-22 20:17 | wmayer | Note Added: 0011823 | |
| 2018-09-22 20:47 | normandc | Note Added: 0011824 | |
| 2018-09-22 21:37 | Kunda1 | Tag Detached: bump |
