| 0000859 | FreeCAD | Bug | public | 2012-10-29 22:30 | 2012-12-05 13:46 |
| Reporter | pervices | Assigned To | yorik | ||
| Priority | normal | Severity | crash | Reproducibility | have not tried |
| Summary | 0000859: Deleting wires/dimensions causes illegal storage crash | ||||
| Description | Using git version: FreeCAD 0.13, Libs: 0.13R1535 (Git: 8de40bc3a) When attempting to delete a line or dimension from the Project: Labels & Attributes (regardless of mode), the program crashes and reports "illegal storage access..." To reproduce: 1. Open freecad-git 2. Load, through the file -> open file the attached file (NOCTAR-bracket.FCStd) 3. Select "Dimension" from the Labels & Attributes list (under project) 4. When highlighted, press "delete" Expected result: Dimension line is removed from the draft/drawing Actual result: Program crash with "Illegal storage access..." reported | ||||
| Additional Information | This issue was also reproduced by my co-founder and when toggling the edit mode, the following errors occurred: ViewProviderPythonFeature::setEdit (Dimension): No such command 'Draft_Edit' ViewProviderPythonFeature::unsetEdit (Dimension): 'module' object has no attribute 'activeDraftCommand' ViewProviderPythonFeature::setEdit (DWire): No such command 'Draft_Edit' Exception (Mon Oct 29 19:12:27 2012): Failed to set object 'DWire' in edit mode Stack Trace: Traceback (most recent call last): File "<string>", line 1, in <module> ViewProviderPythonFeature::setEdit (DWire): No such command 'Draft_Edit' Exception (Mon Oct 29 19:12:31 2012): Failed to set object 'DWire' in edit mode Stack Trace: Traceback (most recent call last): File "<string>", line 1, in <module> ViewProviderPythonFeature::setEdit (Line006): No such command 'Draft_Edit' Exception (Mon Oct 29 19:12:40 2012): Failed to set object 'Line006' in edit mode Stack Trace: Traceback (most recent call last): File "<string>", line 1, in <module> Illegal storage access... ---- A very cursory search of the forum finds that this bug MAY be related to 0000722 | ||||
2012-10-29 22:30
Hm we had that bug some time ago already... I'll have a look |
Thank you very much for looking into this. We have been having a number of problems with stability. We have tried logging the errors but it has not really helped, we were hoping for more verbose logs. For background info, we are running arch linux 3.6.2 kernel on a 64-bit system |
Some additional information: When opening the file directly (without having freecad-git open) you are able to delete objects without crashing. The problem still exists when opening the file from the file-->open graphical interface. |
Also, it is possible to delete the attributes (e.g., dimension lines, measurements, etc.) by right clicking on the attribute in the project tree and selecting delete. Crash occurs when using delete key from key board. |
Hi, Thanks for all your feedback on that matter... Unfortunately I can't reproduce the problem, neither in your attached file following the steps above, nor in any other combination. In fact I can't make it crash by deleting dimensions anymore... I remember in the past this problem was very hard to debug because it happened sometimes yes sometimes no and I never could fully determine a set of conditions that made it always happen. I'm wondering if it could be somehow related to the opengl view... What is your 3D chip and what driver do you use? |
Apparently you built your FreeCAD version yourself. Then could you run FreeCAD in the debugger and post the stacktrace here, please? |
Sorry, just looking at this now. I was able to reproduce the problem in debug and attached the output. Unfortunately I do not have symbols enabled, but the file may still help you. |
2012-11-12 15:41
Hm, according to stack trace it looks similar to 0000665. |
It could be... Maybe I'm foolded because the OP says it happens with Draft dimensions, which looks like a bug we had before. But indeed the trace contain no reference to coin, which is not like the other bug... In case you are right Werner, the bug should be fixed with the latest revision, right? pervices, can you check? |
This bug is fixed in the latest revision but other more major problems occurred for me. I have reported these as a new ticket (899) |
| 2012-10-29 22:30 | pervices | New Issue | |
| 2012-10-29 22:30 | pervices | File Added: NOCTAR-bracket.FCStd | |
| 2012-10-30 01:20 | yorik | Note Added: 0002472 | |
| 2012-10-30 01:20 | yorik | Status | new => assigned |
| 2012-10-30 01:20 | yorik | Assigned To | => yorik |
| 2012-10-30 20:04 | pervices | Note Added: 0002477 | |
| 2012-10-30 20:04 | pervices | Note Edited: 0002477 | |
| 2012-11-06 18:34 | pervices | Note Added: 0002494 | |
| 2012-11-07 14:15 | pervices | Note Added: 0002502 | |
| 2012-11-09 12:33 | yorik | Note Added: 0002504 | |
| 2012-11-10 10:01 | wmayer | Note Added: 0002505 | |
| 2012-11-12 15:40 | pervices | Note Added: 0002508 | |
| 2012-11-12 15:41 | pervices | File Added: debug-report | |
| 2012-12-04 11:40 | wmayer | Note Added: 0002609 | |
| 2012-12-04 12:21 | yorik | Note Added: 0002610 | |
| 2012-12-05 13:44 | pervices | Note Added: 0002612 | |
| 2012-12-05 13:46 | yorik | Status | assigned => closed |
| 2012-12-05 13:46 | yorik | Resolution | open => fixed |
| 2012-12-05 13:46 | yorik | Fixed in Version | => 0.13 |
