| 0000891 | Draft | Bug | public | 2012-11-28 21:50 | 2012-12-20 22:23 |
| Reporter | more10 | Assigned To | yorik | ||
| Summary | 0000891: Snap to intersection doesn't work in draft module | ||||
| Description | In draft module the working plane is set to a surface not aligned to any axis. Snapping to intersection doesn't work. When only intersection is enabled, intersection is indicated only for where endpoints meet. | ||||
| Additional Information | revision 1694 on a 32 bit ubuntu running in vmware workstation. | ||||
To have intersection to work, you need to pass the mouse first on the 2 objects you want to find the intersection of... Sorry, that is not well documented yet. |
I have tried that. Use the drawing I uploaded, using the same drafting plane as the other bugs I reported. |
Hm the problem is that the curved edges of your solid object are bsplines (this happens often with the opencascade engine), and until now I couldn't find a way to find an intersection on a bspline... I'm afraid I won't be able to solve this one now. But I'll definitely add this to the documentation... |
that said, there is really a problem even with straight lines, related to bug 0000893 |
This is fixed in 496a216 |
| 2012-11-28 21:50 | more10 | New Issue | |
| 2012-11-28 23:51 | yorik | Note Added: 0002594 | |
| 2012-11-28 23:55 | yorik | Status | new => assigned |
| 2012-11-28 23:55 | yorik | Assigned To | => yorik |
| 2012-11-29 00:36 | more10 | Note Added: 0002598 | |
| 2012-11-29 20:13 | yorik | Note Added: 0002600 | |
| 2012-11-29 20:15 | yorik | Note Added: 0002601 | |
| 2012-11-29 20:16 | yorik | Relationship added | child of 0000893 |
| 2012-11-29 20:18 | yorik | Relationship added | has duplicate 0000892 |
| 2012-12-05 13:50 | yorik | Project | FreeCAD => Draft |
| 2012-12-20 22:23 | yorik | Note Added: 0002732 | |
| 2012-12-20 22:23 | yorik | Status | assigned => closed |
| 2012-12-20 22:23 | yorik | Resolution | open => fixed |
| 2012-12-20 22:23 | yorik | Fixed in Version | => 0.13 |
