| 0000938 | PartDesign | Bug | public | 2013-01-01 08:38 | 2022-01-24 19:16 |
| Reporter | ghia | Assigned To | wmayer | ||
| Summary | 0000938: Fillet can not round a face (upstream OCC bug) | ||||
| Description | See file in addendum of 0000937 While the shape is 20 mm thick, you can not place 2 fillets of 10 mm Fillet001 which is 9 mm can not be set to 10 | ||||
| Additional Information | This ticket is being tracked from OCC Bugs in the Bugtracker forum thread. | ||||
| Tags | #ready-for-migration, fillet, OCC Bug, OCC NotOnRoadmap, upstream | ||||
Could be a float vs. double precision issue. Should be checked once the double-precision branch is merged into master. |
I tried this with the current assembly branch (has float to double change) and there was no change. I also tried this with the OCC DRAWEXE and witnessed the same behavior. also searched OCC forum. Here is one thread. http://www.opencascade.org/org/forum/thread_21317/?forum=3 //OCC rant removed |
http://tracker.dev.opencascade.org/view.php?id=25478 |
Can someone test with OCC 7.5.0 ? Edit: Please remember to update the relationship with Feature 0001192 if this ticket is resolved. |
This ticket has been migrated to GitHub as issue 5561. |
| 2013-01-01 08:38 | ghia | New Issue | |
| 2013-07-02 03:37 | wmayer | Note Added: 0003322 | |
| 2013-07-02 03:37 | wmayer | Status | new => confirmed |
| 2013-07-02 03:37 | wmayer | Status | confirmed => assigned |
| 2013-07-02 03:37 | wmayer | Assigned To | => wmayer |
| 2013-09-23 17:29 | tanderson69 | Note Added: 0003644 | |
| 2013-09-23 17:30 | tanderson69 | Note Edited: 0003644 | |
| 2015-01-14 13:34 | wmayer | Note Added: 0005652 | |
| 2015-02-02 08:56 | shoogen | Relationship added | has duplicate 0001946 |
| 2015-02-02 08:56 | shoogen | Tag Attached: fillet | |
| 2017-03-09 02:47 | normandc | Tag Attached: OCC Bug | |
| 2017-03-09 02:47 | normandc | Tag Attached: upstream | |
| 2017-03-09 02:49 | normandc | Relationship added | parent of 0001192 |
| 2017-08-28 14:37 | Kunda1 | Tag Attached: OCC NotOnRoadmap | |
| 2018-07-05 00:34 | Kunda1 | Description Updated | |
| 2020-12-31 12:01 | Kunda1 | Additional Information Updated | |
| 2020-12-31 12:01 | Kunda1 | Summary | Fillet can not round a face => Fillet can not round a face (upstream OCC bug) |
| 2020-12-31 12:02 | Kunda1 | Note Added: 0015183 | |
| 2020-12-31 12:04 | Kunda1 | Note Edited: 0015183 | |
