0001027FreeCADBugpublic2015-01-24 22:46
Reportershoogen Assigned Toshoogen
Status closedResolutionfixed
Product Version0.12
Fixed in Version0.15
Summary0001027: UTF-8 encoded PyString objects are used instead of unicode objects to pass unicode data to the python interpreter
DescriptionUnicode Data should be converted to Python objects using
PyObject* PyUnicode_DecodeUTF8(const char *s, Py_ssize_t size, const char *errors)
or
PyObject* PyUnicode_DecodeUTF8Stateful(const char *s, Py_ssize_t size, const char *errors, Py_ssize_t *consumed)
A proper Unicode aware implementation is used for the FreeCADGui.Console.
In but in most cases FreeCAD encodes unicode data using utf-8 and passes it to the python interpreter as 8bit strings instead of using a proper Unicode object.
This forces the user to handle those strings manualy instead of writing code transparent to unicode objects and to strings that are properly encoded.
For example. The workaround to handle utf-8 encoded file names on an not utf-8 based filesystem. Will break properly encoded strings using the filesystemencoding. (https://sourceforge.net/apps/phpbb/free-cad/viewtopic.php?f=8&t=3589&p=28576)
Tagsunicode
Relationships
related to 0001731 closedshoogen FreeCAD spreadsheet csv import/export - path with umlauts
related to 0001747 closedshoogen FreeCAD QString::toLocal8Bit() strips non-latin charaters
related to 0001763 closedshoogen FreeCAD use UTF8 for filenames
parent of 0001744 closedwmayer FreeCAD Use unicode in Unit system
parent of 0001852 closedshoogen FreeCAD The python interpreter does not recognize the posix locale settings
related to 0001411 closedshoogen FreeCAD Importing and Exporting fails on Windows due to filepath encoding
related to 0001795 closedyorik Arch adapt IFC exporters to accept unicode filenames
shoogen
2014-07-11 19:37
developer   ~0004787
also present in unit system
http://forum.freecad.org/viewtopic.php?f=23&t=6923&p=56527#p56527
shoogen
2014-09-06 09:27
developer   ~0005077
http://stackoverflow.com/questions/10180765/open-file-with-a-unicode-filename
shoogen
2014-09-08 07:50
developer   ~0005079
Currently we use
doCommand(Doc,"f.FileName = \"%s\"",(const char*)fn.toUtf8());
the simplest alternative would be to change it to
doCommand(Doc,"f.FileName = unicode(\"%s\",\"utf-8\")",(const char*)fn.toUtf8());
This will leave a characters readable in the console.
Another solution would be to create suitable escaped unicode literal strings.
This will fix the problems for all python modules. However, the C++ modules would need to be adapted to handle.
I would suggest to change the c++ modules like the python open function.
If the parameter is a string, it is expected to encoded correctly.
If the parameter is a unicode string, it encoded by the by the function.
Therefore i would change a the import and open functions to save the filename paramter to a PyObject. Then we would add a function to Base::Interpreter to convert it to a 8bit cstring.
For a unicode object this would mean to encode the string with the encoding returned by sys.getfilesystemencoding().
On most linux system this would be utf-8. On windows this would be 'mbcs'.
shoogen
2014-12-16 13:35
developer   ~0005392
needs workaround for the 0.15 release.
shoogen
2015-01-24 13:18
developer   ~0005704
we need to address
src/Gui/WidgetFactory.cpp:431
after a fixing 0001852
Related Changesets
FreeCAD: master a53a239f
2014-09-21 23:45:32
shoogen
issue 0001027 use unicode filepaths Affected Issues
0001027
mod - src/App/Application.cpp Diff File
mod - src/App/ApplicationPy.cpp Diff File
mod - src/Base/Tools.cpp Diff File
mod - src/Base/Tools.h Diff File
mod - src/Gui/Application.cpp Diff File
mod - src/Gui/ApplicationPy.cpp Diff File
mod - src/Mod/Cam/App/AppCamPy.cpp Diff File
mod - src/Mod/Drawing/Gui/AppDrawingGuiPy.cpp Diff File
mod - src/Mod/Drawing/Gui/Command.cpp Diff File
mod - src/Mod/Fem/App/AppFemPy.cpp Diff File
mod - src/Mod/Fem/App/FemMeshPyImp.cpp Diff File
mod - src/Mod/Image/Gui/AppImageGuiPy.cpp Diff File
mod - src/Mod/Image/Gui/Command.cpp Diff File
mod - src/Mod/Import/App/AppImportPy.cpp Diff File
mod - src/Mod/Import/App/CMakeLists.txt Diff File
mod - src/Mod/Import/Gui/AppImportGuiPy.cpp Diff File
mod - src/Mod/JtReader/App/AppJtReaderPy.cpp Diff File
mod - src/Mod/Mesh/App/AppMeshPy.cpp Diff File
mod - src/Mod/Part/App/AppPartPy.cpp Diff File
mod - src/Mod/Part/App/CMakeLists.txt Diff File
mod - src/Mod/Part/App/ImportStep.cpp Diff File
mod - src/Mod/Part/App/TopoShape.cpp Diff File
mod - src/Mod/Part/App/TopoShapePyImp.cpp Diff File
add - src/Mod/Part/App/encodeFilename.h Diff File
mod - src/Mod/Points/App/AppPointsPy.cpp Diff File
mod - src/Mod/Raytracing/Gui/AppRaytracingGuiPy.cpp Diff File
mod - src/Mod/Sketcher/App/AppSketcherPy.cpp Diff File
mod - src/Mod/Sketcher/Gui/AppSketcherGuiPy.cpp Diff File
2013-02-25 09:39 shoogen New Issue
2013-04-23 22:05 yorik Relationship added parent of 0000995
2014-07-11 19:37 shoogen Note Added: 0004787
2014-09-04 15:46 shoogen Relationship added related to 0001731
2014-09-06 09:27 shoogen Note Added: 0005077
2014-09-08 07:50 shoogen Note Added: 0005079
2014-09-13 20:22 shoogen Relationship added parent of 0001744
2014-09-15 17:22 shoogen Tag Attached: unicode
2014-09-22 08:30 shoogen Relationship added related to 0001747
2014-09-22 09:48 shoogen Assigned To => shoogen
2014-09-22 09:48 shoogen Status new => assigned
2014-09-24 11:32 shoogen Relationship added related to 0001411
2014-09-24 11:41 shoogen Relationship added related to 0001763
2014-10-11 12:30 wmayer Changeset attached => FreeCAD Master master a53a239f
2014-10-11 12:43 shoogen Relationship deleted parent of 0000995
2014-10-11 12:44 shoogen Status assigned => closed
2014-10-11 12:44 shoogen Resolution open => fixed
2014-10-22 07:32 shoogen Relationship added related to 0001795
2014-12-16 13:34 shoogen Relationship added parent of 0001852
2014-12-16 13:35 shoogen Note Added: 0005392
2014-12-16 13:35 shoogen Status closed => feedback
2014-12-16 13:35 shoogen Resolution fixed => reopened
2015-01-24 13:18 shoogen Note Added: 0005704
2015-01-24 13:18 shoogen Status feedback => assigned
2015-01-24 22:46 shoogen Status assigned => closed
2015-01-24 22:46 shoogen Resolution reopened => fixed
2015-01-24 22:46 shoogen Fixed in Version => 0.15
