| 0001763 | FreeCAD | Feature | public | 2014-09-24 11:39 | 2014-10-23 10:56 |
| Reporter | shoogen | Assigned To | shoogen | ||
| Summary | 0001763: use UTF8 for filenames | ||||
| Description | http://tracker.dev.opencascade.org/view.php?id=22484 http://git.dev.opencascade.org/gitweb/?p=occt.git;a=shortlog;h=refs/heads/CR22484 | ||||
| parent of | 0001795 | closed | yorik | Arch | adapt IFC exporters to accept unicode filenames |
| related to | 0001027 | closed | shoogen | FreeCAD | UTF-8 encoded PyString objects are used instead of unicode objects to pass unicode data to the python interpreter |
| child of | 0001573 | closed | shoogen | FreeCAD | migration to OCCT 6.8.0 |
| child of | 0001411 | closed | shoogen | FreeCAD | Importing and Exporting fails on Windows due to filepath encoding |
| child of | 0001421 | closed | shoogen | FreeCAD | STEP import failure due to non-ASCII chars path |
| child of | 0000812 | closed | shoogen | FreeCAD | Does not import files with the national chars in the file name. |
if the change to python unicode objects would be rejected and support of occt 6.8.0 would be dropped at once, a simple git revert 040c19b1c1618043631e45c74ddd30536cf09252 would implement this feature |
if OCC does not fix the problem after the beta the workaround needs to be reenabled at some places |
| 2014-09-24 11:39 | shoogen | New Issue | |
| 2014-09-24 11:39 | shoogen | Status | new => assigned |
| 2014-09-24 11:39 | shoogen | Assigned To | => shoogen |
| 2014-09-24 11:39 | shoogen | Relationship added | child of 0001573 |
| 2014-09-24 11:41 | shoogen | Relationship added | child of 0001411 |
| 2014-09-24 11:41 | shoogen | Relationship added | related to 0001027 |
| 2014-09-24 11:42 | shoogen | Relationship added | child of 0001421 |
| 2014-09-24 11:43 | shoogen | Relationship added | child of 0000812 |
| 2014-09-24 12:38 | shoogen | Summary | use TCollection_ExtendedString for filenames => use UTF8 for filenames |
| 2014-09-24 13:28 | shoogen | Note Added: 0005152 | |
| 2014-10-11 12:38 | shoogen | Status | assigned => closed |
| 2014-10-11 12:38 | shoogen | Resolution | open => fixed |
| 2014-10-11 12:38 | shoogen | Fixed in Version | => 0.15 |
| 2014-10-13 20:59 | shoogen | Note Added: 0005216 | |
| 2014-10-13 20:59 | shoogen | Status | closed => feedback |
| 2014-10-13 20:59 | shoogen | Resolution | fixed => reopened |
| 2014-10-13 20:59 | shoogen | Status | feedback => assigned |
| 2014-10-14 18:21 | shoogen | Status | assigned => closed |
| 2014-10-14 18:21 | shoogen | Resolution | reopened => fixed |
| 2014-10-22 07:31 | shoogen | Relationship added | parent of 0001795 |
