| 0001411 | FreeCAD | Bug | public | 2014-02-13 15:54 | 2014-10-11 12:59 |
| Reporter | shoogen | Assigned To | shoogen | ||
| Priority | high | Severity | major | Reproducibility | have not tried |
| OS | MS Windows | ||||
| Summary | 0001411: Importing and Exporting fails on Windows due to filepath encoding | ||||
| Description | Exporting using the ImportGui module works. While exporting using the Part module does not work. http://forum.freecad.org/viewtopic.php?f=3&t=5673 | ||||
| Steps To Reproduce | >>> Part.export([App.ActiveDocument.Box],"C:/Users/SomeUser/Desktop/folderwithnonasciicharsäöü/filenamedoesntmatter.stp") >>> App.ActiveDocument.Box.Shape.exportBrep("C:/Users/SomeUser/Desktop/Ordnerä/dfdf.brep") Traceback (most recent call last): File "<input>", line 1, in <module> Exception: Writing of BREP failed | ||||
| related to | 0001027 | closed | shoogen | UTF-8 encoded PyString objects are used instead of unicode objects to pass unicode data to the python interpreter |
| parent of | 0001763 | closed | shoogen | use UTF8 for filenames |
| related to | 0001421 | closed | shoogen | STEP import failure due to non-ASCII chars path |
| child of | 0000812 | closed | shoogen | Does not import files with the national chars in the file name. |
http://stackoverflow.com/questions/821873/how-to-open-an-stdfstream-ofstream-or-ifstream-with-a-unicode-filename vs. https://github.com/tpaviot/oce/blob/master/src/BRepTools/BRepTools.cxx#L667 seems to be a upstream problem in OCCT |
For the BRep file format we can basically support file path with non-ASCII characters because there is an overloaded version using C++ iostreams. However, this only works if OCC/OCE and FreeCAD are built with exactly the same compiler version otherwise the application crashes. Unfortunately, this doesn't work for STEP or IGES because the API only accepts C-strings as argument. |
http://tracker.dev.opencascade.org/view.php?id=22125 http://tracker.dev.opencascade.org/view.php?id=22484 |
http://tracker.dev.opencascade.org/view.php?id=24716 |
the fix to http://tracker.dev.opencascade.org/view.php?id=22484 fill break backwards compatibility. Therefore it needs to be taken into consideration when adapting to a newer OCCT version. |
| 2014-02-13 15:54 | shoogen | New Issue | |
| 2014-02-13 16:05 | shoogen | Steps to Reproduce Updated | |
| 2014-02-13 16:09 | shoogen | Description Updated | |
| 2014-02-13 16:09 | shoogen | Steps to Reproduce Updated | |
| 2014-02-13 16:10 | shoogen | Summary | Opening and Saving fails due to filepath encoding on windows => Importing and Exporting fails on Windows due to filepath encoding |
| 2014-02-13 16:26 | shoogen | Note Added: 0004213 | |
| 2014-02-13 16:34 | shoogen | Target Version | 0.14 => |
| 2014-02-13 16:42 | wmayer | Note Added: 0004214 | |
| 2014-02-14 14:27 | wmayer | Note Added: 0004220 | |
| 2014-02-19 11:33 | shoogen | Relationship added | related to 0001421 |
| 2014-03-11 01:44 | yorik | Relationship added | child of 0000812 |
| 2014-03-12 17:07 | shoogen | Note Added: 0004439 | |
| 2014-07-12 16:00 | shoogen | Note Added: 0004788 | |
| 2014-07-12 16:00 | shoogen | Relationship added | related to 0001573 |
| 2014-07-23 11:39 | shoogen | Relationship deleted | related to 0001573 |
| 2014-09-24 11:32 | shoogen | Relationship added | related to 0001027 |
| 2014-09-24 11:35 | shoogen | Assigned To | => shoogen |
| 2014-09-24 11:35 | shoogen | Status | new => assigned |
| 2014-09-24 11:41 | shoogen | Relationship added | parent of 0001763 |
| 2014-10-11 12:41 | shoogen | Status | assigned => closed |
| 2014-10-11 12:41 | shoogen | Resolution | open => fixed |
| 2014-10-11 12:45 | shoogen | Status | closed => feedback |
| 2014-10-11 12:45 | shoogen | Resolution | fixed => reopened |
| 2014-10-11 12:59 | shoogen | Status | feedback => closed |
| 2014-10-11 12:59 | shoogen | Resolution | reopened => fixed |
