| 0000812 | FreeCAD | Bug | public | 2012-08-04 05:00 | 2014-10-14 18:22 |
| Reporter | cepera-one | Assigned To | shoogen | ||
| Summary | 0000812: Does not import files with the national chars in the file name. | ||||
| Description | FreeCAD does not import files with the national chars in the file name. | ||||
| Additional Information | Bug tracker also gives an error when I try to attach these files. You can take the example file from the distribution Schenkel.stp and add to its name the characters in Russian :-) or any other national character set. When writing a plugin for my program I had to do copy such files to a temporary file and then import it into FreeCAD. | ||||
| parent of | 0001421 | closed | shoogen | STEP import failure due to non-ASCII chars path |
| parent of | 0001411 | closed | shoogen | Importing and Exporting fails on Windows due to filepath encoding |
| parent of | 0001763 | closed | shoogen | use UTF8 for filenames |
| has duplicate | 0000811 | closed | Does not import files with the national chars in the file name. |
2012-08-04 05:00
2012-08-04 05:07
This is a limitation of the CAD kernel OpenCascade. In its API to load STEP or IGES files it only supports path names in plain ASCII. |
Maybe we can write a check on file names if they contain non-ASCII chars and bail out more gracefully with user feedback.... |
to be tested on OCCT 6.8.0 |
| 2012-08-04 05:00 | cepera-one | New Issue | |
| 2012-08-04 05:00 | cepera-one | File Added: Schenkel.stp | |
| 2012-08-04 05:07 | cepera-one | File Added: FreeCAD_About.jpg | |
| 2012-08-06 05:53 | wmayer | Relationship added | has duplicate 0000811 |
| 2012-08-06 06:00 | wmayer | Note Added: 0002310 | |
| 2012-12-20 20:31 |
Note Added: 0002704 | |
| 2012-12-20 20:31 |
Status | new => confirmed |
| 2014-03-02 14:04 | wmayer | Relationship added | parent of 0001421 |
| 2014-03-11 01:44 | yorik | Relationship added | parent of 0001411 |
| 2014-09-24 11:35 | shoogen | Assigned To | => shoogen |
| 2014-09-24 11:35 | shoogen | Status | confirmed => assigned |
| 2014-09-24 11:43 | shoogen | Relationship added | parent of 0001763 |
| 2014-10-11 12:58 | shoogen | Note Added: 0005210 | |
| 2014-10-14 18:22 | shoogen | Status | assigned => closed |
| 2014-10-14 18:22 | shoogen | Resolution | open => fixed |
