| 0002520 | Drawing | Bug | public | 2016-04-23 20:45 | 2018-02-10 09:54 |
| Reporter | berka | Assigned To | yorik | ||
| Platform | Intel x86-64 | OS | MacOSX | OS Version | 10.11.4 (15E65) |
| Target Version | 0.18 | Fixed in Version | 0.17 | ||
| Summary | 0002520: Dimension Arrows incorrectly scaled or placed in Export PDF (fixed in Qt5) | ||||
| Description | When I export PDF from a dimensioned drawing, the dimension arrows do not line up properly with the extension lines. (Arrows may also be the wrong size, I'm not sure.) | ||||
| Steps To Reproduce | Create a part Create Dimensions in Draft View Create a Drawing Page Add a part view to drawing Add a dimensions to drawing. Export PDF Open PDF and look at dimension arrows. | ||||
| Additional Information | OS: Mac OS X Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.16.6702 (Git) Build type: Release Branch: (detached from d2a08df) Hash: d2a08df5e2db1c9c1dfa39dd45f1a306b3955cdc Python version: 2.7.11 Qt version: 4.8.7 Coin version: 3.1.3 OCC version: 6.8.0.oce-0.17 | ||||
| Tags | Qt, Qt5, upstream | ||||
Apparently they are printed on the pdf doc with a thicker linewidth than on the svg sheet... I'm afraid this won't be very easy to fix becuase it's handled directly by QT. As a workaround, you can export to SVG, then open that SVG in inkscape and export as PDF. You'll have much better control over the output. |
@yorik Is this better in Qt5? |
I have not built FreeCAD with Qt5 yet...I'll assign this one to myself so I don't forget to look |
Another report wrongly attributed to PartDesign. This is about the Drawing workbench!!! |
@wandererfan do you mind weighing in? |
Linked 0002034 |
With Qt5 this issue will be fixed. |
Will be automatically fixed in v0.18 when we have moved to Qt5. |
| 2016-04-23 20:45 | berka | New Issue | |
| 2016-04-23 20:45 | berka | File Added: PDFExportDimArrow.FCStd | |
| 2016-04-23 20:46 | berka | File Added: PDFExportDimArrow.pdf | |
| 2016-04-26 22:43 | yorik | Note Added: 0007007 | |
| 2017-01-14 01:28 | Kunda1 | Tag Attached: Qt | |
| 2017-01-14 01:29 | Kunda1 | Note Added: 0007748 | |
| 2017-01-14 02:00 | yorik | Note Added: 0007749 | |
| 2017-01-14 02:01 | yorik | Assigned To | => yorik |
| 2017-01-14 02:01 | yorik | Status | new => assigned |
| 2017-01-30 20:07 | Kunda1 | Tag Attached: Qt5 | |
| 2017-02-02 11:46 | Kunda1 | File Added: PDFExportDimArrow.png | |
| 2017-05-01 23:13 | Kunda1 | Target Version | => 0.17 |
| 2017-05-01 23:47 | Kunda1 | Tag Attached: #lowhangingfruit | |
| 2017-06-17 21:32 | normandc | Note Added: 0009425 | |
| 2017-06-17 21:33 | normandc | Project | PartDesign => Drawing |
| 2017-06-21 11:03 | Kunda1 | Note Added: 0009480 | |
| 2017-06-21 11:04 | Kunda1 | Note Edited: 0009480 | |
| 2017-06-27 11:31 | Kunda1 | Relationship added | related to 0002034 |
| 2017-06-27 11:32 | Kunda1 | Note Added: 0009559 | |
| 2018-01-04 11:53 | wmayer | Status | assigned => resolved |
| 2018-01-04 11:53 | wmayer | Resolution | open => fixed |
| 2018-01-04 11:53 | wmayer | Fixed in Version | => 0.17 |
| 2018-01-04 11:53 | wmayer | Note Added: 0010699 | |
| 2018-01-05 21:57 | Kunda1 | Tag Attached: upstream | |
| 2018-01-05 21:57 | Kunda1 | Tag Detached: #lowhangingfruit | |
| 2018-01-23 19:02 | Kunda1 | Summary | Dimension Arrows incorrectly scaled or placed in Export PDF => Dimension Arrows incorrectly scaled or placed in Export PDF (fixed in Qt5) |
| 2018-02-10 09:54 | wmayer | Status | resolved => closed |
| 2018-02-10 09:54 | wmayer | Target Version | 0.17 => 0.18 |
| 2018-02-10 09:54 | wmayer | Note Added: 0010940 |
