| 0002536 | FreeCAD | Bug | public | 2016-04-30 10:03 | 2018-08-26 15:21 |
| Reporter | more11 | Assigned To | chrisb | ||
| Platform | Dell XPS | OS | Windows 7 | OS Version | x64 |
| Summary | 0002536: Unable to change axis on part made from dxf | ||||
| Description | I have used DraftSight to create dxf drawing of a cone driver. One drawing has the relief from the side. I have imported this drawing into Freecad and made a shell by rotating the drawing. This shell I can change axis on. The second drawing is by the back side of the driver. I have created solids from mounting holes and basket openings. After imporing into FreeCAD and having created the solids I could not change the axis, so I changed the axis of the shell instead. And then I did subtract from the shell. The resulting part "Korg" I cannot change axis on. | ||||
| Steps To Reproduce | Download zip file unpack Open the drawing. Try to change axis. | ||||
| Additional Information | OS: Windows 7 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.7447 (Git) Build type: Release Branch: master Hash: 898bd8bb4cbe2c9b26aa6c1f7362e48752a3e4de Python version: 2.7.8 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 | ||||
| Tags | DXF | ||||
I have now upgraded teighafileconverter to 1.39. The downloaded md file gave the proper installation path. The http://www.freecadweb.org/wiki/index.php?title=Dxf_Importer_Install tells you to open the macro library path, which I changed to my project. Same behaviour. I have tried to change axis on the parts imported from dxf without success. I have tried all the object types in the input, circle, arc, line, polyline. |
It was some time ago I made the first part, the rotated part. I believe that I copied the polyline in FreeCAD and used that polyline for rotation. |
Now I have made draft polylines from the imported dxf, and then extruded and subtracted. I cannot change axis on the resulting part either. The cad file is here : https://dl.dropboxusercontent.com/u/106944188/FreeCAD/axis/korg2.zip |
I uploaded the korg2 file in 0002536:0007038 to the ticket JIC the dropbox link breaks like it did in the ticket description. I've also added a forum thread: https://forum.freecadweb.org/viewtopic.php?f=10&t=20052 where this ticket should be discussed @more11 JFYI next time it's better to post to the forum before opening a ticket on the tracker |
@more11 any chance you can re-up the zip to Dropbox? |
@more11 please respond |
Requested files |
@more11 FYI it's recommended to use the latest 0.17 master and update to OCC 7.1 |
Well, this bug report is more than a year old. I am using daily builds on Ubuntu now. |
@NormandC can you reproduce? |
I can reproduce in: OS: Ubuntu 16.04.2 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.10993 (Git) Build type: None Branch: master Hash: bf5f3484f6f5506795b6e9b86288c75ab7357291 Python version: 2.7.12 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 7.1.0 |
I extracted the zip korg2-2.zip and renamed the file korg2.FCStd1 to korg2.FCStd. Then I tried to change the placement of the object Korg001. |
I don't understand the problem. Both .dwg's import for me on both 0.16/0.17 C++/legacy python importer. @more11 can you post Draft WB; Edit>Preferences...>Import-Export>DXF settings? |
Import is not the problem. Changing axis in placement is the problem. |
@sgrogan1 ping. OP replied ^ |
Maybe I'm thick, but I don't understand. Maybe the problem is a misunderstanding of the placement dialog? The "axis" define an axis that rotation acts upon. Changing the axis alone does nothing without a rotation. If this is the case it has nothing to do with imported dxf's, all objects behave this way. |
@more11 ping (please respond to sgrogan1 Perhaps you can also make a quick screencast? |
It should be possible to change orienation by changing axis in placement. |
@more11 so the question is: what you are observing doesn't only relate to DXF, correct? |
@more11 ping |
@more11 please reply |
Changing placement has no effect |
@more11 FYI @chrisb can't reproduce (as per https://forum.freecadweb.org/viewtopic.php?f=10&t=20052#p218155 )
| 2016-04-30 10:03 | more11 | New Issue | |
| 2016-04-30 10:30 | more11 | Note Added: 0007036 | |
| 2016-04-30 10:48 | more11 | Note Added: 0007037 | |
| 2016-04-30 11:22 | more11 | Note Added: 0007038 | |
| 2017-01-19 13:27 | Kunda1 | File Added: korg2.zip | |
| 2017-01-19 13:30 | Kunda1 | Note Added: 0007877 | |
| 2017-01-19 13:30 | Kunda1 | Tag Attached: #pending | |
| 2017-02-02 03:36 | Kunda1 | Tag Attached: DXF | |
| 2017-02-02 03:39 | Kunda1 | Steps to Reproduce Updated | |
| 2017-02-04 03:32 | Kunda1 | Status | new => feedback |
| 2017-05-03 12:56 | Kunda1 | Relationship added | related to 0002620 |
| 2017-05-03 12:57 | Kunda1 | Note Added: 0008880 | |
| 2017-05-13 12:22 | Kunda1 | Note Added: 0008980 | |
| 2017-05-13 18:48 | more11 | File Added: korg.zip | |
| 2017-05-13 18:48 | more11 | File Added: korg2-2.zip | |
| 2017-05-13 18:48 | more11 | Note Added: 0008994 | |
| 2017-05-13 18:48 | more11 | Status | feedback => new |
| 2017-05-14 14:38 | Kunda1 | Note Added: 0009007 | |
| 2017-05-14 14:59 | more11 | Note Added: 0009011 | |
| 2017-05-14 15:11 | Kunda1 | Note Added: 0009013 | |
| 2017-05-14 16:38 | more11 | Note Added: 0009014 | |
| 2017-05-14 16:41 | more11 | Note Added: 0009015 | |
| 2017-05-16 00:18 |
Note Added: 0009026 | |
| 2017-05-16 11:57 | Kunda1 | Status | new => feedback |
| 2017-05-16 16:25 | more11 | Note Added: 0009034 | |
| 2017-05-16 16:25 | more11 | Status | feedback => new |
| 2017-06-15 12:26 | Kunda1 | Note Added: 0009383 | |
| 2017-06-15 12:27 | Kunda1 | Tag Attached: #post-to-forum | |
| 2017-06-15 21:18 |
Note Added: 0009393 | |
| 2017-06-15 21:34 | Kunda1 | Status | new => feedback |
| 2017-07-03 21:19 | Kunda1 | Note Added: 0009660 | |
| 2017-07-04 08:10 | more11 | Note Added: 0009665 | |
| 2017-07-04 08:10 | more11 | Status | feedback => new |
| 2017-07-04 11:22 | Kunda1 | Note Added: 0009667 | |
| 2017-09-07 20:44 | Kunda1 | Tag Detached: #post-to-forum | |
| 2017-09-07 20:44 | Kunda1 | Note Added: 0010087 | |
| 2017-10-10 02:32 | Kunda1 | Relationship added | related to 0002663 |
| 2017-11-28 14:29 | Kunda1 | Note Added: 0010493 | |
| 2017-11-28 20:51 | more11 | File Added: 2017-11-28-214538_1920x1080_scrot.png | |
| 2017-11-28 20:51 | more11 | Note Added: 0010496 | |
| 2018-03-03 11:16 | Kunda1 | Note Added: 0010994 | |
| 2018-03-04 15:31 | chrisb | Assigned To | => chrisb |
| 2018-03-04 15:31 | chrisb | Status | new => closed |
| 2018-03-04 15:31 | chrisb | Resolution | open => unable to reproduce |
| 2018-08-26 15:21 | Kunda1 | Tag Detached: #pending |
