| 0002663 | File formats | General | public | 2016-08-07 19:18 | 2018-01-12 15:42 |
| Reporter | ehb | Assigned To | yorik | ||
| Platform | FreeCAD 0.17 git8139 | OS | Ubuntu | OS Version | 16.04 |
| Summary | 0002663: DXF export wrong when sketch is rotated | ||||
| Description | The DXF/SVG export of a sketch is broken when the sketch is oriented any other way than on the XY-plane. Lines are affected differently than arcs. If the sketch is copied and reoriented to XY, export works fine. | ||||
| Steps To Reproduce | - Create a line and an arc or circle in a sketch on XZ-plane - Export to DXF or flattened SVG - Look at output | ||||
| Tags | DXF, export, rotate, SVG | ||||
Forum thread: http://forum.freecadweb.org/viewtopic.php?f=10&t=19906 |
OP can you still recreate this on latest trunk? Also please post your Help > About FreeCAD > Copy to clipboard (to both this ticket and the thread). Thank you. |
@ehb please retest |
Retested with git10035: Behaviour still present Attached file is a Sketch in XZ-plane made with FreeCAD-daily 0.17 (git10035) and the resulting DXF opened in LibreCAD. Exported as "Autodesk DXF". OS: Ubuntu Zesty Zapus (development branch) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.10035 (Git) Build type: None Branch: master Hash: 0598af8a081f762039fa43efaf90ece4ca0b5e6f Python version: 2.7.13 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 |
This problem is no longer happening in current dev version (annexed t.fcstd file contains 2 sketches, one in XZ plane and one in XY plane, t1.dxf is exported in XY plane direction, t2.dxf is exported in XZ direction) |
| 2016-08-07 19:18 | ehb | New Issue | |
| 2017-01-15 01:25 | Kunda1 | Tag Attached: DXF | |
| 2017-01-15 01:25 | Kunda1 | Tag Attached: rotate | |
| 2017-01-15 01:25 | Kunda1 | Tag Attached: SVG | |
| 2017-01-15 02:40 | Kunda1 | Note Added: 0007777 | |
| 2017-02-02 17:46 | Kunda1 | Note Added: 0008176 | |
| 2017-02-02 17:46 | Kunda1 | Status | new => feedback |
| 2017-03-02 19:03 | Kunda1 | Note Added: 0008520 | |
| 2017-03-02 19:25 | ehb | File Added: FreeCAD_Bug2663.png | |
| 2017-03-02 19:25 | ehb | Note Added: 0008524 | |
| 2017-03-02 19:25 | ehb | Status | feedback => new |
| 2017-03-02 19:51 | Kunda1 | Status | new => confirmed |
| 2017-10-10 02:31 | Kunda1 | Relationship added | related to 0002620 |
| 2017-10-10 02:32 | Kunda1 | Relationship added | related to 0002536 |
| 2017-10-10 12:29 | Kunda1 | Tag Attached: export | |
| 2017-10-27 19:36 | yorik | Assigned To | => yorik |
| 2017-10-27 19:36 | yorik | Status | confirmed => assigned |
| 2018-01-12 15:41 | yorik | File Added: t.fcstd | |
| 2018-01-12 15:41 | yorik | File Added: t1.dxf | |
| 2018-01-12 15:41 | yorik | File Added: t2.dxf | |
| 2018-01-12 15:41 | yorik | Note Added: 0010744 | |
| 2018-01-12 15:42 | yorik | Status | assigned => closed |
| 2018-01-12 15:42 | yorik | Resolution | open => fixed |
