| 0002620 | Drawing | Bug | public | 2016-07-13 15:35 | 2018-09-16 11:53 |
| Reporter | burtbick | Assigned To | |||
| Platform | AMD 64 bit | OS | Linux Mint | OS Version | 17.1 |
| Summary | 0002620: Appears in both V0.16 and daily builds Drawing dxf export not working correctly | ||||
| Description | From the Drawing workbench create a new drawing and insert some views. Do a file export and select the File type for the *.svg, *.svgz, *.dxf and enter a .dxf file name. Observe that the resulting dxf file is not correct. In my case it contains just a single rectangle that is not oriented correctly. Exporting with a .svg file name creates a properly exported file with the title block and all the views that are in the Page. | ||||
| Steps To Reproduce | Start FreeCAD Create a part model using the Part Design Workbench. Switch to the Drawing Workbench Insert a new drawing object Make sure the created part is selected Insert some new views of the part. Do File->Export and select *.svg, *.svgz, *.dxf as the File Type from the drop down list Enter foobar.dxf for the file name. Save the file to complete the export. Load the DXF file foobar.dxf with a program that views DXFs. Observe that it is not correct. For a sanity test repeat the File->Export with the same File Type filter but this time export as foobar.svg Load foobar.svg into a suitable program, e.g. Inkscape Observe that the SVG exported properly. | ||||
| Additional Information | OS: Linux Mint 17.1 Rebecca Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.7957 (Git) Build type: None Branch: master Hash: 2ac560e7b027590e8d6b534b84020d4c1624ece5 Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 | ||||
| Tags | DXF | ||||
Is this bug mis-classified? Is dxf export part of the Path workbench? |
Forum thread: https://forum.freecadweb.org/viewtopic.php?f=10&t=20267 |
@wandererfan care to weigh in ? |
from forum discussion >>I only did a quick check with Part Features, but I noted that: - not all views in a page are in the dxf file - the dxf file is missing the EOF record so the last view will not be imported by LibreCad<< Is there a test file(s) available? EDIT: botched link to forum discussion |
@burtbick do you have a test file? |
DXF export exists in other Modules (Import, TechDraw, Draft(?). Use one of those modules. |
| 2016-07-13 15:35 | burtbick | New Issue | |
| 2016-10-16 01:18 | mlampert | Note Added: 0007383 | |
| 2016-10-22 20:19 | yorik | Project | Path => Drawing |
| 2017-01-27 03:23 | Kunda1 | Note Added: 0008015 | |
| 2017-01-27 03:23 | Kunda1 | Status | new => feedback |
| 2017-02-07 03:15 | Kunda1 | Tag Attached: DXF | |
| 2017-02-21 16:13 | Kunda1 | Relationship added | child of 0002882 |
| 2017-05-03 12:56 | Kunda1 | Relationship added | related to 0002536 |
| 2017-05-08 21:57 | Kunda1 | Relationship added | related to 0002621 |
| 2017-07-08 14:43 | Kunda1 | Note Added: 0009682 | |
| 2017-07-08 15:38 | wandererfan | Note Added: 0009685 | |
| 2017-07-08 15:40 | wandererfan | Note Edited: 0009685 | |
| 2017-07-08 15:56 | Kunda1 | Note Added: 0009687 | |
| 2017-10-10 02:31 | Kunda1 | Relationship added | related to 0002663 |
| 2017-11-25 01:27 | wandererfan | Relationship deleted | child of 0002882 |
| 2018-09-16 11:53 | wandererfan | Status | feedback => closed |
| 2018-09-16 11:53 | wandererfan | Resolution | open => won't fix |
| 2018-09-16 11:53 | wandererfan | Note Added: 0011756 |
