0002716FreeCADBugpublic2017-03-10 20:36
Reporterhartl Assigned ToKunda1
PlatformIntel x86_64OSLinux openSUSEOS VersionTumbleweed
Product Version0.17
Summary0002716: Boolean operations on planar and circular objects fail if intersection has elliptic or hyperbolic shape
DescriptionIf an intersection between two objects results in a shape (at the intersecting plane) that has elliptic or hyperbolic parts, boolean operations like fusion, cut, intersect, chamfer, fillet will fail in various ways. It make no difference if the objects are primitives, extruded, chamfered, filleted or if they originate from "Part" or "PartDesign".
Just a wild guess: maybe some calculation produces two results (ellipse and hyperbola have two foci) where one result is expected and the wrong one is chosen.
This report might be a duplicate of 0002715 and 0002679.
Steps To Reproduce1. start FreeCAD, select "Part"
2. create a cone
3. create a cube
4. resize and move objects so that a surface of the cube intersects the cone
5. rotate one object so that the intersecting shape is not a circle
6a. select the cube and the cone, click on "fusion" -> Exception: MultiFusion failed
6b. select the cube and the cone, click on "cut" -> SIGSEGV signal raised: 11
---or---
2. create a wedge (default parameters will do)
3. select an edge which is not at 90° to other edges
4. fillet -> SIGSEGV signal raised: 11
Additional InformationOS: "openSUSE Tumbleweed"
Version: 0.17.8487 (Git) (Packman)
Hash: c457fc468cd57807586915ebfd288638f009281f
Python version: 2.7.12
Qt version: 4.8.7
OCC version: 6.9.1.oce-0.18-dev
Linux x6 4.7.2-2-default #1 SMP PREEMPT Mon Aug 29 23:57:41 UTC 2016 (8a962cf) x86_64 x86_64 x86_64 GNU/Linux
TagsOCC 7.0, OCC Bug, upstream
Relationships
related to 0002679 closed PartDesign Boolean operations in Part workbench give strange results
hartl
2016-09-30 12:00
reporter
cone-cube-ellipse.fcstd (Attachment missing)
hartl
2016-09-30 12:14
reporter   ~0007340
This bug might also be a reason why the current version sometimes crashes when loading files made with older versions. I just checked my designs from a year ago, the ones with design features as described above cannot be opened anymore.
hartl
2016-10-18 17:01
reporter   ~0007392
OCE from Packman repo seems to be broken or outdated. Compiling OCC 7.0.0 from opencascade.com and FreeCAD from GIT solved this issue.
Version: 0.17.8715 (Git)
Build type: Unknown
Hash: fbaf3a1bbc818153d966ca49e910c6942f2581aa
Qt version: 4.8.7
OCC version: 7.0.0
Linux x6 4.7.6-1-default #1 SMP PREEMPT Fri Sep 30 12:22:14 UTC 2016 (fb37fcc) x86_64 x86_64 x86_64 GNU/Linux
2017-01-30 14:03
administrator   ~0008105
Have the Packman folks been updated since?
Resolving.
Forum thread: https://forum.freecad.org/viewtopic.php?f=10&t=20366
2016-09-30 12:00 hartl New Issue
2016-09-30 12:00 hartl File Added: cone-cube-ellipse.fcstd
2016-09-30 12:14 hartl Note Added: 0007340
2016-09-30 13:07 hartl Note Edited: 0007340
2016-10-18 17:01 hartl Note Added: 0007392
2017-01-30 14:01 Kunda1 Description Updated
2017-01-30 14:01 Kunda1 Tag Attached: OCC 7.0
2017-01-30 14:01 Kunda1 Tag Attached: OCC Bug
2017-01-30 14:01 Kunda1 Tag Attached: upstream
2017-01-30 14:03 Kunda1 Note Added: 0008105
2017-01-30 14:03 Kunda1 Status new => resolved
2017-01-30 14:03 Kunda1 Resolution open => no change required
2017-01-30 14:03 Kunda1 Assigned To => Kunda1
2017-01-30 14:05 Kunda1 Note Edited: 0008105
2017-01-30 14:08 Kunda1 Relationship added related to 0002679
2017-03-10 20:36 kkremitzki Status resolved => closed
