| 0002952 | FreeCAD | Bug | public | 2017-03-07 03:34 | 2017-03-27 17:25 |
| Reporter | blacey | Assigned To | |||
| Summary | 0002952: Save Image... results in all-black image file when FreeCAD is built with Qt 5 | ||||
| Description | The Save Image... feature creates a totally black image file when using Qt 5. This issue occurs on both Linux and macOS. | ||||
| Tags | Qt5 | ||||
This seems a regression of Qt5 compared to Qt4. It looks like pixel buffer support has been completely dropped (even for the deprecated QtOpenGL module and internally FBO is used). So, either add the key "DisablePBuffers" or "CoinOffscreenRenderer" and set it to true (under BaseApp/Preferences/Document). With the real pixel buffer under Qt4 we had the best results because anti-aliasing was supported and transparencies worked quite well, too. Now with Qt5 we can use FBO which also supports anti-aliasing but totally fails for transparencies or use the old built-in Coin offscreen renderer that supports transparencies but no anti-aliasing. |
FreeCAD: master 5bf326c1 2017-03-12 11:27:20 wmayer Details Diff |
Qt5OpenGL: fix creating thumbnals, pdf, print preview and snapshot |
Affected Issues 0002952, 0002986 |
| mod - src/Gui/Thumbnail.cpp | Diff File | ||
| mod - src/Gui/View3DInventor.cpp | Diff File | ||
| mod - src/Gui/View3DPy.cpp | Diff File | ||
FreeCAD: master c193dbe2 2017-03-21 16:36:53 wmayer Details Diff |
enable FREECAD_USE_QTOPENGL_WIDGET by default for Qt5, fixes 0002952, fixes 0001401 |
Affected Issues 0001401, 0002942, 0002952, 0002953, 0002986 |
| mod - CMakeLists.txt | Diff File | ||
| 2017-03-07 03:34 | blacey | New Issue | |
| 2017-03-07 12:34 | Kunda1 | Tag Attached: Qt5 | |
| 2017-03-08 11:44 | wmayer | Note Added: 0008574 | |
| 2017-03-21 19:44 | wmayer | Changeset attached | => FreeCAD master c193dbe2 |
| 2017-03-21 19:46 | wmayer | Changeset attached | => FreeCAD master 5bf326c1 |
| 2017-03-21 19:49 | wmayer | Status | new => closed |
| 2017-03-21 19:49 | wmayer | Resolution | open => fixed |
| 2017-03-21 19:49 | wmayer | Fixed in Version | => 0.17 |
| 2017-03-27 17:25 | Kunda1 | Relationship added | child of 0002986 |
