| 0003355 | File formats | Bug | public | 2018-02-27 12:24 | 2021-01-04 21:06 |
| Reporter | unfa | Assigned To | |||
| Summary | 0003355: SVG importer: regression from 0.16 to 0.17 | ||||
| Description | As reported in the forums: https://forum.freecad.org/viewtopic.php?f=3&t=27135&p=217420#p217420 | ||||
| Steps To Reproduce | 1. Create a new project 2. Import attached SVG as geometry | ||||
| Tags | import, SVG | ||||
I attach an example file (I pressed something and posted the issue prematurely - sorry). It imports fine in FreeCAD 0.16 (stable) but break in FreeCAD daily 0.17. |
@wmayer attend to this pre or post 0.17 ? |
When loading with v0.17 which may use occ7.0 then the following error occurs:
When loading with v0.16 which here uses occ6.8 no error occurs. |
I also experienced crash when importing .svg file. It was after an upgrade from Mint 18.3 to Mint 19 and I believe it is due to libexpat1 versions. From research I needed to downgrade the version, here what I did to fix it - downloaded from https://pkgs.org/download/libexpat1 Ubuntu 17.10 versions libexpat1_2.2.3-1_amd64.deb libexpat1_2.2.3-1_i386.deb then go to Download directory and install sudo dpkg -i libexpat1_2.2.3-1_i386.deb sudo dpkg -i libexpat1_2.2.3-1_amd64.deb Note had to install 386 version first Reboot & test - still crashes Try agin with Ubuntu 16.04 versions libexpat1_2.1.0-7ubuntu0.16.04.3_i386.deb libexpat1_2.1.0-7ubuntu0.16.04.3_amd64.deb This time I had to install amd64 version first Tested - it works!!! |
Looks like this is related or a duplicate of 0003307 In that ticket thread it's reported that:
I'm going to resolve this ticket since it's an upstream packaging issue. |
| 2018-02-27 12:24 | unfa | New Issue | |
| 2018-02-27 12:24 | unfa | Tag Attached: SVG | |
| 2018-02-27 12:26 | unfa | File Added: Gorzów prod 07.svg | |
| 2018-02-27 12:26 | unfa | Note Added: 0010985 | |
| 2018-03-03 10:11 | Kunda1 | Status | new => confirmed |
| 2018-03-03 10:11 | Kunda1 | Note Added: 0010986 | |
| 2018-03-03 10:11 | Kunda1 | Tag Attached: import | |
| 2018-03-03 10:35 | Kunda1 | Relationship added | related to 0002488 |
| 2018-03-04 10:00 | wmayer | Note Added: 0011000 | |
| 2018-07-24 09:31 | micksulley | Note Added: 0011543 | |
| 2018-07-24 09:34 | micksulley | Note Edited: 0011543 | |
| 2018-08-23 17:12 | Kunda1 | Relationship added | related to 0003307 |
| 2018-08-23 17:13 | Kunda1 | Note Added: 0011645 | |
| 2018-08-23 17:15 | Kunda1 | Note Edited: 0011645 | |
| 2018-08-31 08:00 | Kunda1 | Status | confirmed => resolved |
| 2018-08-31 08:00 | Kunda1 | Resolution | open => no change required |
| 2018-08-31 08:00 | Kunda1 | Note Added: 0011676 | |
| 2018-09-22 15:57 | wmayer | Status | resolved => closed |
| 2021-01-04 21:06 | StefanBruens | Relationship added | related to 0004528 |
