| related to | 0003052 | closed | berndhahnebach | FEM | FEM - List of important but empty wiki pages that need contents |
| related to | 0003053 | closed | Part | PART - List of important but empty wiki pages that need contents | |
| related to | 0003016 | closed | TechDraw | TechDraw - Wiki documentation | |
| parent of | 0003054 | closed | Sketcher | Sketcher - List of important but empty wiki pages that need contents | |
| parent of | 0002017 | closed | FreeCAD | List of important but empty wiki pages that need contents | |
| parent of | 0003331 | closed | normandc | PartDesign | PartDesign: update wiki pages to reference changes in 0.17 |
| parent of | 0003641 | closed | FreeCAD | DAGview documentation needed |
Removing following links from report, because these commands do not exist in FreeCAD. https://freecad.org/wiki/Constraint_Concentric https://freecad.org/wiki/Constraint_ExternalAngle https://freecad.org/wiki/Constraint_PointOnEnd https://freecad.org/wiki/Constraint_PointOnMidPoint https://freecad.org/wiki/Constraint_PointOnStart https://freecad.org/wiki/Constraint_PointToObject https://freecad.org/wiki/Constraint_TangentToEnd https://freecad.org/wiki/Constraint_TangentToStart |
Removed https://freecad.org/wiki/Drawing_Orthoviews Page was mostly completed. |
Deleted https://freecad.org/wiki/Sandbox:TestTranslation This page created in 2013 didn't seem to have any further use. https://freecad.org/wiki/Snadbox:Property_editor was a useless redirect left after page rename. Removed https://freecad.org/wiki/WikiPages from list, it comes up because it lists available templates, including "UnfinishedDocu". |
Deleted https://freecad.org/wiki/Sketcher_Arch3Point, it was a duplicate of https://freecad.org/wiki/Sketcher_Arc3Point Renamed https://freecad.org/wiki/Sketcher_Conic_Sections to Sketcher CompCreateConic and completed the page. Added Sketcher_CreateArcOfHyperbola and Sketcher_CreateArcOfParabola. |
Completed https://freecad.org/wiki/Std_Export |
Completed https://freecad.org/wiki/Std_WhatsThis |
Deleted https://freecad.org/wiki/Std_TipOfTheDay as the command no longer exists in the source code. Renamed https://freecad.org/wiki/Std_RotateLeft to Std_ViewRotateLeft and completed page. Renamed https://freecad.org/wiki/Std_RotateRight to Std_ViewRotateRight and completed page. |
Completed: https://freecad.org/wiki/Std_ViewCreate https://freecad.org/wiki/Std_FreeCADWebsite https://freecad.org/wiki/Std_OnlineHelp |
Completed https://freecad.org/wiki/Std_MeasureAngular https://freecad.org/wiki/Std_MeasureLinear |
https://freecad.org/wiki/Std_MeasureClearAll https://freecad.org/wiki/Std_MeasureToggle3D https://freecad.org/wiki/Std_MeasureToggleAll https://freecad.org/wiki/Std_MeasureToggleDelta renamed and completed: https://freecad.org/wiki/Part_Measure_Clear_All https://freecad.org/wiki/Part_Measure_Toggle_3d https://freecad.org/wiki/Part_Measure_Toggle_All https://freecad.org/wiki/Part_Measure_Toggle_Delta |
Deleted these pages https://freecad.org/wiki/Std_OnlineHelpWebsite (no longer in GUI) https://freecad.org/wiki/Std_ViewExamples (does not exist) https://freecad.org/wiki/Std_ViewXX (does not exist) https://freecad.org/wiki/Std_ViewZoom (does not exist) |
Why was https://freecad.org/wiki/Snadbox:Property_editor deleted? It was an attempt of mine to make a proposal for a new page for the property editor. |
@ulrich1a it was renamed because it was created with a typo. https://freecad.org/wiki/Sandbox:Property_editor s/Snadbox/Sandbox/ |
Add missing pages |
Actually this will require some thought, some of these tools were only removed in v0.18... Keeping them aside for now. https://freecad.org/wiki/Mesh_Cut https://freecad.org/wiki/Mesh_Demolding https://freecad.org/wiki/Mesh_ExMakeMesh https://freecad.org/wiki/Mesh_ExMakeTool https://freecad.org/wiki/Mesh_ExMakeUnion https://freecad.org/wiki/Mesh_MakeSegment https://freecad.org/wiki/Mesh_SelectMesh https://freecad.org/wiki/Mesh_SplitMesh https://freecad.org/wiki/Mesh_ToolMesh https://freecad.org/wiki/Mesh_Transform https://freecad.org/wiki/Mesh_TrimMesh |
https://freecad.org/wiki/Sketcher_CreateEllipseBy3Points done.. Just a note.. in the overview it´s named Ellipse by 3 Points.. FreeCad names the Tool Ellipse by peripasis, apoapsis, minor diamter .. I did not change the overview, but used the current naming inside . |
https://freecad.org/wiki/Sketcher_Move done and ready for review.. |
@harrygeier heads up, looks like you are staying uniform to the style of the wiki documentation pages. - Don't forget to add the <languages/> tag at the top of the page - Don't forget to encapsulate the whole wiki page with <translate></translate> tag - The headers you are using are smaller then the uniform pages (I think they should be H2 AKA '==Section==' Edit: I may be wrong about using H2. Need NormandC's input |
@NormandC what's the correct header number is it ==Section== or ====Section==== ? |
Normally I think it should be H2, or ==Section==. H4 are sub-sub-headers. If I recall correctly, the reason why we have so many old command pages with H4 headers is that, in the GuiCommand template, the TOC shows the H2 sections on the same level as the page name, which is listed as first item (I think it shouldn't, but here it is). Only with H4 headers are they nested on a sub-level to the page name. Even if this is an annoyance, I'm now of the mind that H2 is better, it's more clearly defined with the default MediaWiki theme. |
@harrygeier I made a few small changes. As per https://www.freecad.org/wiki/WikiPages#Graphics_content We should avoid thumbnails, with legend inside the image: this forces us to translate the image code itself. IMO we should place images between ending and starting translate tags so they are taken out of the translation. This is not possible if the image is a thumb and contains a legend. Of course, this is only if the image does not contain sentences in English. We should also avoid resizing images if the new size is very near the original size (500px vs. 523px) as the image becomes blurry. When I edit a command page, I've taken the habit of placing the GuiCommand template on multiple lines. It is in fact a MediaWiki table. This is in no way obligatory, but I believe that this way, it will be easier to understand and to edit by wiki translators. A pipe | symbol indicates the start of a row. So instead of
The translator will see
(There should not be a blank line between MenuLocation and SeeAlso - it does not appear in the Preview :-\ )Also, Sketcher tools were removed from the PartDesign workbench in v0.17. I removed its mention in the GuiCommand's Workbenches field. As for the ==Version== section found in many command pages: I wonder if we shouldn't add this as a field in the GuiCommand template itself. It would remove this section and make the page leaner... |
Done: https://freecad.org/wiki/Sketcher_BSplineDegree https://freecad.org/wiki/Sketcher_BSplinePolygon https://freecad.org/wiki/Sketcher_BSplineComb https://freecad.org/wiki/Sketcher_BSplineKnotMultiplicity https://freecad.org/wiki/Sketcher_ConvertToNURB https://freecad.org/wiki/Sketcher_BSplineIncreaseDegree https://freecad.org/wiki/Sketcher_BSplineIncreaseKnotMultiplicity https://freecad.org/wiki/Sketcher_BSplineDecreaseKnotMultiplicity https://freecad.org/wiki/Sketcher_SwitchVirtualSpace mostly done: https://freecad.org/wiki/Part_Offset |
Done: https://freecad.org/wiki/Doxygen Thanks @vocx |
Crossed out https://freecad.org/wiki/Sketcher_BSplinePolygon https://freecad.org/wiki/Sketcher_BSplineComb https://freecad.org/wiki/Sketcher_BSplineKnotMultiplicity https://freecad.org/wiki/Sketcher_ConvertToNURB https://freecad.org/wiki/Sketcher_BSplineIncreaseDegree https://freecad.org/wiki/Sketcher_BSplineIncreaseKnotMultiplicity https://freecad.org/wiki/Sketcher_BSplineDecreaseKnotMultiplicity https://freecad.org/wiki/Mesh_AddTriangle https://freecad.org/wiki/Mesh_CreateMeshSegment https://freecad.org/wiki/Mesh_CurvatureInfo https://freecad.org/wiki/Mesh_EvaluateCurvature https://freecad.org/wiki/Mesh_EvaluateSolid https://freecad.org/wiki/Mesh_Evaluation https://freecad.org/wiki/Mesh_PolyCut https://freecad.org/wiki/Mesh_TrimMeshWithPlane https://freecad.org/wiki/Mesh_VertexCurvature |
renamed ticket so it's release-generic ('next' release) |
Crossed out: https://freecad.org/wiki/Part_Offset https://freecad.org/wiki/Path_MillFace |
Crossed out https://freecad.org/wiki/FEM_ConstraintFlowVelocity https://freecad.org/wiki/FEM_MeshPrintInfo https://freecad.org/wiki/Plot_Axes https://freecad.org/wiki/Plot_Grid https://freecad.org/wiki/Plot_Labels https://freecad.org/wiki/Plot_Legend https://freecad.org/wiki/Plot_Series |
Crossed out https://freecad.org/wiki/Plot_Positions |
Closing as we can track this from https://freecad.org/wiki/Category:UnfinishedDocu thread: https://forum.freecad.org/viewtopic.php?f=8&t=65676 |
| 2018-10-06 00:33 | Kunda1 | New Issue | |
| 2018-10-06 00:36 | Kunda1 | Description Updated | |
| 2018-10-06 20:57 | normandc | Additional Information Updated | |
| 2018-10-06 20:57 | normandc | Note Added: 0011949 | |
| 2018-10-06 22:43 | normandc | Additional Information Updated | |
| 2018-10-06 22:43 | normandc | Note Added: 0011950 | |
| 2018-10-06 22:51 | normandc | Additional Information Updated | |
| 2018-10-06 22:51 | normandc | Note Added: 0011951 | |
| 2018-10-07 07:30 | normandc | Additional Information Updated | |
| 2018-10-07 07:30 | normandc | Note Added: 0011952 | |
| 2018-10-07 08:48 | normandc | Additional Information Updated | |
| 2018-10-07 08:48 | normandc | Note Added: 0011953 | |
| 2018-10-07 09:17 | normandc | Additional Information Updated | |
| 2018-10-07 09:17 | normandc | Note Added: 0011954 | |
| 2018-10-07 10:09 | normandc | Additional Information Updated | |
| 2018-10-07 10:09 | normandc | Note Added: 0011955 | |
| 2018-10-07 17:25 | normandc | Additional Information Updated | |
| 2018-10-07 17:25 | normandc | Note Added: 0011958 | |
| 2018-10-07 20:23 | normandc | Additional Information Updated | |
| 2018-10-07 20:23 | normandc | Note Added: 0011959 | |
| 2018-10-07 21:53 | normandc | Additional Information Updated | |
| 2018-10-07 21:53 | normandc | Note Added: 0011961 | |
| 2018-10-08 19:31 | normandc | Additional Information Updated | |
| 2018-10-08 19:31 | normandc | Note Added: 0011978 | |
| 2018-10-08 22:12 | ulrich1a | Note Added: 0011979 | |
| 2018-10-09 00:02 | Kunda1 | Note Added: 0011981 | |
| 2018-10-09 00:04 | Kunda1 | Note Edited: 0011981 | |
| 2018-10-09 05:33 | normandc | Additional Information Updated | |
| 2018-10-09 05:33 | normandc | Note Added: 0011983 | |
| 2018-10-09 05:34 | normandc | Additional Information Updated | |
| 2018-10-09 05:56 | normandc | Additional Information Updated | |
| 2018-10-09 05:56 | normandc | Note Added: 0011984 | |
| 2018-10-09 06:10 | normandc | Note Edited: 0011984 | |
| 2018-10-09 09:50 | harrygeier | Note Added: 0011985 | |
| 2018-10-09 12:05 | harrygeier | Note Added: 0011987 | |
| 2018-10-10 17:59 | Kunda1 | Relationship added | parent of 0003054 |
| 2018-10-10 18:00 | Kunda1 | Relationship added | parent of 0002017 |
| 2018-10-10 18:08 | Kunda1 | Note Added: 0011995 | |
| 2018-10-10 18:24 | Kunda1 | Relationship added | parent of 0003331 |
| 2018-10-10 18:28 | Kunda1 | Note Edited: 0011995 | |
| 2018-10-12 12:01 | Kunda1 | Additional Information Updated | |
| 2018-10-12 12:04 | Kunda1 | Note Added: 0012009 | |
| 2018-10-13 22:25 | normandc | Note Added: 0012022 | |
| 2018-10-13 22:44 | normandc | Note Added: 0012023 | |
| 2018-10-13 22:46 | normandc | Note Edited: 0012023 | |
| 2018-10-13 22:47 | normandc | Note Edited: 0012023 | |
| 2018-10-17 20:13 | Kunda1 | Relationship added | parent of 0003641 |
| 2019-01-17 05:32 | normandc | Additional Information Updated | |
| 2019-02-19 10:07 | harrygeier | Note Added: 0012683 | |
| 2019-09-20 11:22 | Kunda1 | Additional Information Updated | |
| 2019-09-20 11:23 | Kunda1 | Note Added: 0013657 | |
| 2019-09-20 11:32 | Kunda1 | Additional Information Updated | |
| 2019-09-20 11:36 | Kunda1 | Summary | Incomplete Wiki Pages to be completed before 0.18 release => Incomplete Wiki Pages to be completed before 0.18/0.19 release |
| 2019-09-20 19:32 | Kunda1 | Tag Attached: documentation | |
| 2019-09-20 19:32 | Kunda1 | Tag Attached: wiki | |
| 2020-01-09 12:30 | Kunda1 | Additional Information Updated | |
| 2020-01-09 12:32 | Kunda1 | Additional Information Updated | |
| 2020-01-09 12:33 | Kunda1 | Additional Information Updated | |
| 2020-01-09 12:38 | Kunda1 | Additional Information Updated | |
| 2020-01-09 12:43 | Kunda1 | Relationship added | related to 0003052 |
| 2020-01-09 12:43 | Kunda1 | Relationship added | related to 0003053 |
| 2020-01-09 12:43 | Kunda1 | Relationship added | related to 0003016 |
| 2020-01-09 17:08 | Kunda1 | Additional Information Updated | |
| 2020-06-06 14:35 | abdullah | Target Version | 0.18 => 0.19 |
| 2021-02-06 06:32 | abdullah | Target Version | => 0.20 |
| 2021-03-27 08:28 | Kunda1 | Additional Information Updated | |
| 2021-03-27 08:29 | Kunda1 | Note Added: 0015547 | |
| 2021-03-27 08:40 | Kunda1 | Additional Information Updated | |
| 2021-03-27 08:41 | Kunda1 | Additional Information Updated | |
| 2021-03-27 08:42 | Kunda1 | Note Edited: 0015547 | |
| 2021-03-27 09:09 | Kunda1 | Additional Information Updated | |
| 2021-03-27 09:17 | Kunda1 | Additional Information Updated | |
| 2021-03-27 09:18 | Kunda1 | Additional Information Updated | |
| 2021-03-27 09:22 | Kunda1 | Additional Information Updated | |
| 2021-03-27 09:23 | Kunda1 | Additional Information Updated | |
| 2021-03-27 09:27 | Kunda1 | Additional Information Updated | |
| 2021-03-27 09:50 | Kunda1 | Summary | Incomplete Wiki Pages to be completed before 0.18/0.19 release => Incomplete Wiki Pages to be completed before next release |
| 2021-03-27 09:50 | Kunda1 | Note Added: 0015548 | |
| 2021-03-28 10:27 | Kunda1 | Additional Information Updated | |
| 2021-03-29 19:59 | Kunda1 | Additional Information Updated | |
| 2021-04-01 17:16 | Kunda1 | Additional Information Updated | |
| 2021-04-01 17:19 | Kunda1 | Additional Information Updated | |
| 2021-04-01 17:20 | Kunda1 | Additional Information Updated | |
| 2021-04-01 17:25 | Kunda1 | Additional Information Updated | |
| 2021-04-01 17:27 | Kunda1 | Additional Information Updated | |
| 2021-04-01 17:31 | Kunda1 | Additional Information Updated | |
| 2021-04-01 17:33 | Kunda1 | Additional Information Updated | |
| 2021-04-02 04:42 | Kunda1 | Additional Information Updated | |
| 2021-04-02 04:43 | Kunda1 | Additional Information Updated | |
| 2021-07-28 18:33 | Kunda1 | Additional Information Updated | |
| 2021-07-28 18:33 | Kunda1 | Note Added: 0015763 | |
| 2021-08-22 12:41 | Kunda1 | Additional Information Updated | |
| 2021-08-22 12:41 | Kunda1 | Note Added: 0015849 | |
| 2021-08-22 12:49 | Kunda1 | Additional Information Updated | |
| 2021-08-22 12:50 | Kunda1 | Note Edited: 0015849 | |
| 2021-08-22 14:56 | Kunda1 | Additional Information Updated | |
| 2021-08-22 14:57 | Kunda1 | Note Edited: 0015849 | |
| 2021-09-07 16:00 | Kunda1 | Additional Information Updated | |
| 2021-09-07 16:00 | Kunda1 | Note Added: 0015909 | |
| 2022-01-25 19:20 | Kunda1 | Additional Information Updated | |
| 2022-01-25 19:25 | Kunda1 | Additional Information Updated | |
| 2022-01-25 19:25 | Kunda1 | FreeCAD Information | => Removed https://freecad.org/wiki/Std_CommandLine from list |
| 2022-01-25 19:32 | Kunda1 | Additional Information Updated | |
| 2022-01-25 19:34 | Kunda1 | Additional Information Updated | |
| 2022-01-25 19:37 | Kunda1 | Additional Information Updated | |
| 2022-01-25 19:40 | Kunda1 | Note Added: 0016309 | |
| 2022-01-25 19:41 | Kunda1 | Assigned To | => Kunda1 |
| 2022-01-25 19:41 | Kunda1 | Status | new => closed |
| 2022-01-25 19:41 | Kunda1 | Resolution | open => fixed |
| 2022-01-25 20:34 | Kunda1 | Note Edited: 0016309 |
