| 0003738 | FreeCAD | Bug | public | 2018-12-18 20:34 | 2021-02-11 18:31 |
| Reporter | HardyW | Assigned To | peterl94 | ||
| Platform | iMac | OS | macOS | OS Version | Mojave |
| Summary | 0003738: [macOS] Wrong display of icons in toolbar | ||||
| Description | I have two screen attached to my iMac: the built-in Retina display and a normal resolution screen. The Retina display is the main screen. FreeCAD is "started from the normal screen", e.g. FreeCAD's initial window appears on the normal resolution screen (the startup sequence can be seen on the Retina display). The output is like the attached screenshot. | ||||
| Additional Information | If FreeCAD is started from the Retina display the icon visualisation is OK. | ||||
| Tags | display, HiDPI, macOS | ||||
@Hardy as per the large banner at the top of the page, we're getting ready to release v0.18. Would you please test this on the 0.18dev https://github.com/FreeCAD/FreeCAD/releases/tag/0.18_pre ? Also please always post your Help > About FreeCAD > Copty to clipboard (again this is stated in the above yellow banner). And in future please also post first to the forum to prevent bugtracker spam. Thank you. |
@Kunda1 the problem is not solved. But the starting behaviour has changed. A couple of different scenarios a) main display is the retina display When FreeCAD is started, no matter whether you start from the normal or Retina display, the initial windows opens on the main display (in version 0.17 this was not the case). Moving the window from the Retina display to the normal display shows the too large icons again. b) main display is the normal display FreeCAD opens its first window always on the normal display. The icons are too large (astonishing but happens; though I did not reboot the computer) on the normal display but not on the Retina display. PS: "Main display" is the display where initially (after computer startup) the menu bar is located. OS: macOS 10.14 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.18.15310 (Git) Build type: Release Branch: (HEAD detached at c88a64e8e) Hash: c88a64e8e7a3bb66a23b965b655b5a5040dfa4d2 Python version: 2.7.15 Qt version: 5.11.2 Coin version: 4.0.0a OCC version: 7.2.0 Locale: English/Germany (en_DE) |
There may be a problem since the build you're using is still python2. Can you please open a forum thread in regards to this issue to discuss with the community ? |
punting to peterl94 |
I'm having the exact same issue. See screenshot (taken on the "normal" / non-retina display). OS: macOS 10.14 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.18.15525 (Git) Build type: Release Branch: master Hash: 1a7d3d9a37fe43468c8ac84590c1db53e2b2000a Python version: 3.6.7 Qt version: 5.6.2 Coin version: 4.0.0a OCC version: 7.3.0 Locale: English/UnitedStates (en_US) |
@HardyW and @ martijnthe Can you recreate this with latest 0.19 dev version ? https://github.com/FreeCAD/FreeCAD/releases/tag/0.19_pre |
NO change with version 0.19-16207 |
Behaviour is ok, icons appear in the right size, starting always on main screen is MacOS default behaviour. |
| 2018-12-18 20:34 | HardyW | New Issue | |
| 2018-12-18 20:34 | HardyW | Tag Attached: display | |
| 2018-12-18 20:34 | HardyW | File Added: Bildschirmfoto 2018-12-18 um 21.21.35.png | |
| 2018-12-19 09:17 | Kunda1 | Assigned To | => Kunda1 |
| 2018-12-19 09:17 | Kunda1 | Status | new => feedback |
| 2018-12-19 09:17 | Kunda1 | Note Added: 0012306 | |
| 2018-12-19 21:59 | HardyW | Note Added: 0012324 | |
| 2018-12-19 21:59 | HardyW | Status | feedback => assigned |
| 2018-12-20 13:33 | Kunda1 | Note Added: 0012330 | |
| 2018-12-20 13:33 | Kunda1 | Status | assigned => feedback |
| 2018-12-24 12:32 | Kunda1 | Tag Attached: MacOSX | |
| 2018-12-24 12:33 | Kunda1 | Relationship added | related to 0003739 |
| 2018-12-24 12:36 | Kunda1 | Relationship added | related to 0003741 |
| 2019-01-04 18:40 | Kunda1 | Assigned To | Kunda1 => peterl94 |
| 2019-01-04 18:41 | Kunda1 | Note Added: 0012365 | |
| 2019-01-11 08:54 | martijnthe | File Added: Schermafbeelding 2019-01-11 om 09.52.28.png | |
| 2019-01-11 08:54 | martijnthe | Note Added: 0012409 | |
| 2019-04-06 19:03 | Kunda1 | Note Added: 0013003 | |
| 2019-04-06 19:03 | Kunda1 | Target Version | => 0.19 |
| 2019-04-06 20:53 | HardyW | Note Added: 0013018 | |
| 2019-04-06 20:53 | HardyW | Status | feedback => assigned |
| 2020-12-03 00:19 | Kunda1 | Tag Attached: HiDPI | |
| 2021-02-11 18:31 | chrisb | Status | assigned => closed |
| 2021-02-11 18:31 | chrisb | Resolution | open => unable to reproduce |
| 2021-02-11 18:31 | chrisb | Note Added: 0015330 |
