0003739DraftBugpublic2020-07-01 06:35
ReporterHardyW Assigned Tocarlopav
Status closedResolutionfixed
PlatformiMacOSmacOS
Product Version0.17
Summary0003739: [macOS] 2D objects (draft mode) cannot be edited by mouse on Retina display
DescriptionNone of the 2D objects in draft mode cannot be edited.
Steps To ReproduceStart FreeCAD on a Retina display and created a new document. Switch to draft mode and draw a line. In the tree double click on the line to start editing. The vertices are converted to boxes. Clicking the mouse on it and moving the mouse (not dragging!) does not do anything.
Additional InformationPS: The same operation works on a normal resolution display without problems!
PPS: Dragging the window from a Retina display to a normal resolution display makes editing work! Dragging it back and the object cannot be edited anymore.
Tagsdisplay, Draft, HiDPI, macOS, retina
Relationships
related to 0003738 closedpeterl94 FreeCAD [macOS] Wrong display of icons in toolbar
related to 0003741 feedback FreeCAD [macOS] Wrong coordinate calculation / visualisation when using Retina display
2018-12-19 09:19
administrator   ~0012307
Please follow the guidelines I posted for you in 0003738 (0003738:0012306)
2018-12-24 12:33
administrator   ~0012337
@blacey could you possibly reproduce this?
2019-01-04 18:41
administrator   ~0012366
punting to peterl94
2019-02-10 16:07
administrator   ~0012611
Discussion thread: https://forum.freecad.org/viewtopic.php?f=8&t=34126
2019-04-06 19:19
administrator   ~0013011
@HardyW Can you test this on the latest 0.19dev since some modifcations were added recently for HiDPI screens.
HardyW
2019-04-06 20:58
reporter   ~0013019
No change, still the same bug with version 0.19 16207
carlopav
2020-06-14 20:32
developer   ~0014545
@HardyW, can you check with a recent 0.19 build?
you can also try to tweak Preferences->Draft->Grid and snapping->Draft Edit Pick Radius.
iyd2019
2020-06-30 22:33
reporter   ~0014605
works fine here!
OS: macOS Mojave (10.14)
Version: 0.19.21718 (Git)
Hash: 002e25b5617f2c79f65968f1f82f7267899965c3
Python version: 3.8.2
Locale: C/Default (C)
carlopav
2020-07-01 06:35
developer   ~0014606
@iyd2019 Thanks for testing, to me it proves the refactoring of Draft Edit carried on during summer 2019 solved the issue.
I'm closing it :)
2018-12-18 20:42 HardyW New Issue
2018-12-18 20:42 HardyW Tag Attached: display
2018-12-18 20:42 HardyW Tag Attached: Draft
2018-12-18 20:42 HardyW Tag Attached: MacOSX
2018-12-19 09:19 Kunda1 Assigned To => Kunda1
2018-12-19 09:19 Kunda1 Status new => feedback
2018-12-19 09:19 Kunda1 Note Added: 0012307
2018-12-19 09:19 Kunda1 Note Edited: 0012307
2018-12-24 12:33 Kunda1 Note Added: 0012337
2018-12-24 12:33 Kunda1 Relationship added related to 0003738
2018-12-24 12:36 Kunda1 Relationship added related to 0003741
2019-01-04 18:41 Kunda1 Assigned To Kunda1 => peterl94
2019-01-04 18:41 Kunda1 Note Added: 0012366
2019-02-10 16:05 Kunda1 Tag Attached: retina
2019-02-10 16:07 Kunda1 Note Added: 0012611
2019-03-03 14:02 Kunda1 Tag Attached: HiDPI
2019-04-06 19:19 Kunda1 Note Added: 0013011
2019-04-06 20:58 HardyW Note Added: 0013019
2019-04-06 20:58 HardyW Status feedback => assigned
2019-05-01 04:37 normandc Project FreeCAD => Draft
2019-05-01 04:37 normandc Priority urgent => normal
2020-06-14 20:32 carlopav Note Added: 0014545
2020-06-30 22:33 iyd2019 Note Added: 0014605
2020-07-01 06:35 carlopav Assigned To peterl94 => carlopav
2020-07-01 06:35 carlopav Status assigned => closed
2020-07-01 06:35 carlopav Resolution open => fixed
2020-07-01 06:35 carlopav Fixed in Version => 0.19
2020-07-01 06:35 carlopav Note Added: 0014606
2020-11-13 14:08 Kunda1 Tag Renamed MacOSX => macOS
