| 0003741 | FreeCAD | Bug | public | 2018-12-18 20:57 | 2021-02-06 06:50 |
| Reporter | HardyW | Assigned To | |||
| Platform | iMac | OS | macOS | OS Version | Mojave |
| Summary | 0003741: [macOS] Wrong coordinate calculation / visualisation when using Retina display | ||||
| Description | The drawn elements are wrongly shown relative to a background image when tracing elements of the image. This error only occurs on Retina displays! | ||||
| Steps To Reproduce | Create a new document, switch to image mode and import an image. Switch to draft mode to trace the outlines of an image. | ||||
| Additional Information | Example screen print attached. | ||||
| Tags | HiDPI, macOS, retina | ||||
0003738:0012306 |
@blacey care to weigh in? |
There are a number of issues related to HiDPI monitors in FreeCAD regardless of the underlying OS. https://forum.freecad.org/search.php?st=0&sk=t&sd=d&sr=posts&keywords=HIDPI&start=20 Some improvements were implemented during the Qt4->Qt5 transition but several are not simple fixes because supporting frameworks, such as Coin 3D, do not natively support HiDPI resolutions. On macOS, the most effective work-around is to run FreeCAD in low-res support by using Finder->Get Info on /Applications/FreeCAD.app and enable the "Open in Low Resolution" option. |
This ticket has been migrated to GitHub as issue 5850. |
| 2018-12-18 20:57 | HardyW | New Issue | |
| 2018-12-18 20:57 | HardyW | File Added: Bildschirmfoto 2018-12-18 um 21.55.45.png | |
| 2018-12-19 09:33 | Kunda1 | Assigned To | => Kunda1 |
| 2018-12-19 09:33 | Kunda1 | Status | new => feedback |
| 2018-12-19 09:33 | Kunda1 | Note Added: 0012310 | |
| 2018-12-24 12:36 | Kunda1 | Relationship added | related to 0003738 |
| 2018-12-24 12:36 | Kunda1 | Relationship added | related to 0003739 |
| 2018-12-24 12:36 | Kunda1 | Assigned To | Kunda1 => |
| 2018-12-24 12:36 | Kunda1 | Tag Attached: MacOSX | |
| 2019-01-05 11:43 | Kunda1 | Note Added: 0012379 | |
| 2019-01-05 15:03 | blacey | File Added: LowResMode.jpg | |
| 2019-01-05 15:03 | blacey | Note Added: 0012392 | |
| 2019-01-05 15:03 | blacey | Note Edited: 0012392 | |
| 2019-02-10 16:07 | Kunda1 | Tag Attached: retina | |
| 2019-03-03 14:02 | Kunda1 | Tag Attached: HiDPI | |
