0003970PartDesignBugpublic2021-12-29 03:49
Reporterbzb.dev001 Assigned Tochennes
Status closedResolutionfixed
Product Version0.18
Target Version0.20Fixed in Version0.20
Summary0003970: crash when adding chamfer to an additive primitive
DescriptionAfter creating an additive primitive and adding a fillet to the top face of the primitive, adding a chamfer to the edges to the primitive causes freecad to crash
OS: Ubuntu 18.04.2 bionic
Freecad: FreeCAD_0.18-16110-Linux-Conda_Py3Qt5_glibc2.12-x86_64
Steps To ReproduceOS: Ubuntu 18.04.2 bionic
create new document
select 'part design workbench'
create body
click 'additive primitive' button
   adjust draft angle
   select 'neutral plane' for bottom face
   select 'pull direction'
select top face
click 'make fillet' button
select all 4 edges that connects the top face to the bottom
click 'chamfer' button
freecad crashes
Additional InformationI have included a simple test file containing the primitive in question. All you need to do is highlight the 4 edges connecting the top face to the bottom and click on the chamfer button and freecad would crash.
TagsChamfer, crash, fillet, OCC Bug, upstream
Relationships
duplicate of 0004543 closedchennes FreeCAD FreeCAD crashes when OCC fails with fillets and chamfers
bzb.dev001
2019-05-14 06:29
reporter
test.FCStd (14,993 bytes)
bzb.dev001
2019-05-14 06:32
reporter   ~0013108
OS: Ubuntu 18.04.2 LTS
Version: 0.18.16110 (Git) AppImage
Branch: (HEAD detached at 0.18.1)
Hash: f7dccfaa909e5b9da26bf50c4a22ccca9bb10c40
Python version: 3.6.7
Qt version: 5.6.2
Locale: English/Canada (en_CA)
2019-05-14 16:01
administrator   ~0013109
Thanks @bzb.dev001 for the report. In future please post bugs to the forum first. Many times there is no necessity to open a ticket because the devs solve the issue pretty swiftly. That is why we ask people in the large banner at the top of this page to do that. Nevertheless, can you recreate this issue on 0.19_pre version ? (it can live in parallel with 0.18 on the same machine)
bzb.dev001
2019-05-14 16:38
reporter   ~0013110
Issue persists in latest compile of freecad.
Freecad used is...
OS: Ubuntu 18.04.2 LTS (LXDE/Lubuntu)
Version: 0.19.16718 (Git) AppImage
Hash: cfd04ac6afa091f5c4f18e94756bd58fb6d66806
Python version: 3.7.1
Qt version: 5.6.2
2019-05-15 17:45
administrator   ~0013113
Started discussion thread at https://forum.freecad.org/viewtopic.php?f=8&t=36408
chennes
2021-02-04 05:14
administrator   ~0015257
In my testing, this is resolved by the fix discussed in 0004543.
2021-02-27 13:25
administrator   ~0015446
@chennes has created a downstream patch that fixes the crash. It is slowly being integrated in to downstream packages (ATM libpack is the only one but more will follow). This issue is therefore being marked as resolved. It will be closed one all packages are patched or when (if) upstream merges.
chennes
2021-12-29 03:49
administrator   ~0016142
This patch has been merged into OpenCASCADE 7.6, and the patch for earlier OCCT versions has been incorporated into all packages of FreeCAD 0.19.3 that I am aware of.
2019-05-14 06:29 bzb.dev001 New Issue
2019-05-14 06:29 bzb.dev001 File Added: test.FCStd
2019-05-14 06:32 bzb.dev001 Note Added: 0013108
2019-05-14 16:01 Kunda1 Status new => feedback
2019-05-14 16:01 Kunda1 Note Added: 0013109
2019-05-14 16:38 bzb.dev001 Note Added: 0013110
2019-05-14 16:38 bzb.dev001 Status feedback => new
2019-05-15 17:45 Kunda1 Note Added: 0013113
2020-10-11 11:59 Kunda1 Tag Attached: #pending-forum
2021-02-03 16:53 Kunda1 Tag Attached: fillet
2021-02-03 16:53 Kunda1 Tag Attached: crash
2021-02-03 16:53 Kunda1 Tag Attached: OCC Bug
2021-02-03 16:53 Kunda1 Tag Attached: upstream
2021-02-03 16:53 Kunda1 Tag Attached: Chamfer
2021-02-04 05:14 chennes Note Added: 0015257
2021-02-06 06:43 abdullah Target Version => 0.20
2021-02-27 13:24 Kunda1 Tag Detached: #pending-forum
2021-02-27 13:25 Kunda1 Assigned To => chennes
2021-02-27 13:25 Kunda1 Status new => resolved
2021-02-27 13:25 Kunda1 Resolution open => fixed
2021-02-27 13:25 Kunda1 Fixed in Version => 0.20
2021-02-27 13:25 Kunda1 Note Added: 0015446
2021-02-27 13:25 Kunda1 Relationship added duplicate of 0004543
2021-12-29 03:49 chennes Status resolved => closed
2021-12-29 03:49 chennes Note Added: 0016142
