| 0004022 | Path | Bug | public | 2019-06-15 22:09 | 2019-09-01 13:02 |
| Reporter | DeVries | Assigned To | dubstar_04 | ||
| Platform | ? | OS | Windows | OS Version | 10 |
| Summary | 0004022: Tool library "New Tool" | ||||
| Description | If you create ballmill in the Tool Library the diameter field is not saved Other fields are working | ||||
| Steps To Reproduce | In "Path" 1 Open tool Library 2 Choose "New Tool" 3 Give tool a name 4 Type BallEndMill -> screen changes.. 5 Length offset e.g. 10mm then Tab 6 Diameter 1.5 mm then Tab (button green on the right) 7 Nothing else and then "OK" on the bottom 8 Screen closes, new line with the new tool etc 9 Bug -> The diameter is stil 0.00 mm 10 Retry etc and OK -> Diameter stil 0.00 mm 11 All other fields work | ||||
| Additional Information | If you export to XML and change the field by hand Delete all records Import the changed XML The tool is useble | ||||
@DeVries Thank you for the report. It is incomplete though. Please follow the instructions in the large yellow banner at the top of the page. You will see what I mean by 'incomplete' |
Sorry you are right. I'm new here. Already Point 1. Point 2 don't understand.. Point 3 I did download and installed daily to check if error was already solved. Point 4.. Point 5. English is not my own language, but is is not Swahili. Description must be clear enough. Point 6 Upload file not so useful.. I'm a user of such a cheap 6040 Chinese CNC thing which needed change of spindle and other repairs before I could use it. That is why I started with 0.17 (no diameter error)and now (0.18) great improvement but with error. Try to find a set of software which I can use. I will comply to your rules. Maybe next weekend when there is some time left. Some forum stuff todo. Kind Regards. |
This is fixed with PR#2434 FreeCAD Pull Request 2434 |
@dubstar_04 thank you for the heads up. In the future you can automate this by reading https://freecadweb.org/wiki/tracker#GitHub_and_MantisBT I'll associate the commit to this ticket manually this time. Thanks. |
@sliptonic do you mind confirming the fix ? |
Closing. Thanks @dubstar_04! |
| 2019-06-15 22:09 | DeVries | New Issue | |
| 2019-06-16 14:26 | Kunda1 | Status | new => feedback |
| 2019-06-16 14:26 | Kunda1 | Note Added: 0013222 | |
| 2019-06-17 22:02 | DeVries | Note Added: 0013244 | |
| 2019-06-17 22:02 | DeVries | Status | feedback => new |
| 2019-08-21 16:50 | dubstar_04 | Assigned To | => dubstar_04 |
| 2019-08-21 16:50 | dubstar_04 | Status | new => assigned |
| 2019-08-21 16:53 | dubstar_04 | Status | assigned => resolved |
| 2019-08-21 16:53 | dubstar_04 | Resolution | open => fixed |
| 2019-08-21 16:53 | dubstar_04 | Fixed in Version | => 0.19 |
| 2019-08-21 16:53 | dubstar_04 | Note Added: 0013441 | |
| 2019-08-21 19:32 | Kunda1 | Note Added: 0013442 | |
| 2019-08-21 19:33 | Kunda1 | Changeset attached | => FreeCAD master 503ecc57 |
| 2019-08-21 19:33 | Kunda1 | Note Edited: 0013441 | |
| 2019-08-21 19:35 | Kunda1 | Note Edited: 0013441 | |
| 2019-08-22 15:30 | Kunda1 | Note Added: 0013449 | |
| 2019-09-01 13:02 | Kunda1 | Status | resolved => closed |
| 2019-09-01 13:02 | Kunda1 | Note Added: 0013505 | |
| 2019-09-01 13:02 | Kunda1 | Target Version | => 0.19 |
