| 0004028 | Path | Bug | public | 2019-06-19 08:32 | 2020-10-17 10:23 |
| Reporter | bzb.dev001 | Assigned To | dubstar_04 | ||
| Summary | 0004028: create tool in Path workbench, parameters not accepted | ||||
| Description | In Path Workbench. When create a new tool using Tool Manager, modifying parameter "Length Offset" causes the cursor to be placed at end of input box for each key pressed. I noticed that when creating a new tool, if I were to modify "Length Offset" parameter first, values entered for other parameter fields would not be accepted. https://forum.freecadweb.org/viewtopic.php?f=3&t=37116&p=315260#p315260 https://forum.freecadweb.org/viewtopic.php?f=3&t=37117 | ||||
| Additional Information | OS: Ubuntu 18.04.2 LTS (LXDE/Lubuntu) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.16966 (Git) AppImage Build type: Release Branch: master Hash: fbafd698aefeae2dbb5a711647346b9cac7794e9 Python version: 3.7.1 Qt version: 5.6.2 Coin version: 4.0.0a OCC version: 7.3.0 Locale: English/Canada (en_CA) | ||||
This should be fixed with: https://github.com/FreeCAD/FreeCAD/pull/2434 |
@mlampert please confirm fix @bzb.dev001 if you can install 0.19_pre you can confirm the fix as well. |
| 2019-06-19 08:32 | bzb.dev001 | New Issue | |
| 2019-08-21 14:37 | dubstar_04 | Note Added: 0013440 | |
| 2019-08-21 16:55 | dubstar_04 | Assigned To | => dubstar_04 |
| 2019-08-21 16:55 | dubstar_04 | Status | new => assigned |
| 2019-08-21 20:05 | Kunda1 | Changeset attached | => FreeCAD master 503ecc57 |
| 2019-08-21 20:06 | Kunda1 | Note Added: 0013445 | |
| 2020-04-23 14:22 | dubstar_04 | Status | assigned => resolved |
| 2020-10-17 10:23 | Kunda1 | Status | resolved => closed |
| 2020-10-17 10:23 | Kunda1 | Resolution | open => fixed |
| 2020-10-17 10:23 | Kunda1 | Fixed in Version | => 0.19 |
