| 0004518 | PartDesign | Bug | public | 2020-12-24 06:41 | 2021-12-29 03:50 |
| Reporter | akamenskiy | Assigned To | chennes | ||
| Priority | urgent | Severity | crash | Reproducibility | always |
| Summary | 0004518: Segfault in some models when making chamfer or fillet (on macos) | ||||
| Description | Attached is example of model where it crashes. It does crash 100% of the time. ALSO FFS get rid of Mantis, it is the worst bugtracker (has been the worst since I've worked with it in 2006). Even Github issues is way better than this. You can get Jira for open source projects for free. | ||||
| Steps To Reproduce | 1. Open attached model 2. Select an inner edge of cutout in top surface (last pocket operation with sharp edges) 3. Try to create fillet or chamfer on selected edge 4. Segfault | ||||
| Additional Information | There is a stacktrace from the segfault. But it is not showing up anymore after being dismissed first time. | ||||
| Tags | Chamfer, crash, fillet, OCC Bug, upstream | ||||
| FreeCAD Information | OS: macOS 10.15 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.19.23463 (Git) Build type: Release Branch: master Hash: adc6db8f32c17e9f67cb82aa7962d1e42ce061c6 Python version: 3.8.6 Qt version: 5.12.5 Coin version: 4.0.0 OCC version: 7.4.0 Locale: C/Default (C) | ||||
In my testing, this is resolved by the fix discussed in 0004543. |
@chennes has created a downstream patch that fixes the crash. It is slowly being integrated in to downstream packages (ATM libpack is the only one but more will follow). This issue is therefore being marked as resolved. It will be closed once all packages are patched or when (if) upstream merges. |
This patch has been merged into OpenCASCADE 7.6, and the patch for earlier OCCT versions has been incorporated into all packages of FreeCAD 0.19.3 that I am aware of. |
| 2020-12-24 06:41 | akamenskiy | New Issue | |
| 2020-12-24 06:41 | akamenskiy | File Added: 30 mm fan guard.FCStd | |
| 2021-02-03 16:57 | Kunda1 | Tag Attached: crash | |
| 2021-02-03 16:57 | Kunda1 | Tag Attached: fillet | |
| 2021-02-03 16:57 | Kunda1 | Tag Attached: Chamfer | |
| 2021-02-03 16:57 | Kunda1 | Tag Attached: OCC Bug | |
| 2021-02-03 16:57 | Kunda1 | Tag Attached: upstream | |
| 2021-02-04 05:26 | chennes | Note Added: 0015265 | |
| 2021-02-27 13:32 | Kunda1 | Assigned To | => chennes |
| 2021-02-27 13:32 | Kunda1 | Status | new => resolved |
| 2021-02-27 13:32 | Kunda1 | Resolution | open => fixed |
| 2021-02-27 13:32 | Kunda1 | Fixed in Version | => 0.20 |
| 2021-02-27 13:32 | Kunda1 | Note Added: 0015452 | |
| 2021-02-27 13:32 | Kunda1 | Relationship added | duplicate of 0004543 |
| 2021-12-29 03:50 | chennes | Status | resolved => closed |
| 2021-12-29 03:50 | chennes | Note Added: 0016148 |
