| 0001139 | FreeCAD | Bug | public | 2013-05-26 06:32 | 2014-05-20 17:48 |
| Reporter | pfirszt | Assigned To | jrheinlaender | ||
| Priority | normal | Severity | crash | Reproducibility | sometimes |
| Summary | 0001139: FreeCAD crashes when changing placement of sketch. | ||||
| Description | As above + the sketch is used to create pad. There are 4 holes int he pad created with LinearPattern. After the transformation linearpattern is no longer in the main pad area and that crashes FreeCad. Reproduce (not always): use placement to rotate Z to 0 on "Back Plate Sketch" in the attached file | ||||
| Additional Information | [Thread 0x7fff8e03a700 (LWP 5987) exited] Transformed shape does not intersect support Pocket: Removed Transformed shape does not intersect support Pocket: Removed Program received signal SIGSEGV, Segmentation fault. 0x00000037a16bb5c0 in App::DocumentObject::getNameInDocument() const () from /usr/lib64/freecad/lib/libFreeCADApp.so (gdb) bt #0 0x00000037a16bb5c0 in App::DocumentObject::getNameInDocument() const () from /usr/lib64/freecad/lib/libFreeCADApp.so #1 0x00007fff75a719cd in PartDesignGui::TaskDlgLinearPatternParameters::accept() () from /usr/lib64/freecad/Mod/PartDesign/PartDesignGui.so 0000002 0x00000037a21c8bf1 in Gui::TaskView::TaskView::accept() () from /usr/lib64/freecad/lib/libFreeCADGui.so 0000003 0x0000003f1538cd6f in QMetaObject::activate(QObject*, QMetaObject const*, int, void**) () from /lib64/libQtCore.so.4 0000004 0x0000003f1538cd6f in QMetaObject::activate(QObject*, QMetaObject const*, int, void**) () from /lib64/libQtCore.so.4 0000005 0x0000003f1602f062 in QAbstractButton::clicked(bool) () from /lib64/libQtGui.so.4 0000006 0x0000003f15d83c8e in QAbstractButtonPrivate::emitClicked() () from /lib64/libQtGui.so.4 0000007 0x0000003f15d84290 in QAbstractButtonPrivate::click() () from /lib64/libQtGui.so.4 0000008 0x0000003f15d844fc in QAbstractButton::mouseReleaseEvent(QMouseEvent*) () from /lib64/libQtGui.so.4 0000009 0x0000003f15a19f49 in QWidget::event(QEvent*) () from /lib64/libQtGui.so.4 0000010 0x0000003f159ca5cc in QApplicationPrivate::notify_helper(QObject*, QEvent*) () from /lib64/libQtGui.so.4 0000011 0x0000003f159cf2ab in QApplication::notify(QObject*, QEvent*) () from /lib64/libQtGui.so.4 0000012 0x00000037a204f05f in Gui::GUIApplication::notify(QObject*, QEvent*) () from /usr/lib64/freecad/lib/libFreeCADGui.so 0000013 0x0000003f1537793e in QCoreApplication::notifyInternal(QObject*, QEvent*) () from /lib64/libQtCore.so.4 0000014 0x0000003f159cb40b in QApplicationPrivate::sendMouseEvent(QWidget*, QMouseEvent*, QWidget*, QWidget*, QWidget**, QPointer<QWidget>&, bool) () from /lib64/libQtGui.so.4 0000015 0x0000003f15a45b74 in QETWidget::translateMouseEvent(_XEvent const*) () from /lib64/libQtGui.so.4 0000016 0x0000003f15a44901 in QApplication::x11ProcessEvent(_XEvent*) () from /lib64/libQtGui.so.4 0000017 0x0000003f15a6aa5c in x11EventSourceDispatch(_GSource*, int (*)(void*), void*) () from /lib64/libQtGui.so.4 0000018 0x0000003f00a47a55 in g_main_context_dispatch () from /lib64/libglib-2.0.so.0 0000019 0x0000003f00a47d88 in g_main_context_iterate.isra.24 () from /lib64/libglib-2.0.so.0 0000020 0x0000003f00a47e44 in g_main_context_iteration () from /lib64/libglib-2.0.so.0 0000021 0x0000003f153a5f86 in QEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) () from /lib64/libQtCore.so.4 0000022 0x0000003f15a6a73e in QGuiEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) () from /lib64/libQtGui.so.4 0000023 0x0000003f153765ef in QEventLoop::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) () from /lib64/libQtCore.so.4 0000024 0x0000003f15376878 in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) () from /lib64/libQtCore.so.4 0000025 0x0000003f1537b708 in QCoreApplication::exec() () from /lib64/libQtCore.so.4 0000026 0x00000037a204c483 in Gui::Application::runApplication() () from /usr/lib64/freecad/lib/libFreeCADGui.so 0000027 0x0000000000404253 in main () | ||||
2013-05-26 06:32
Could you please detail "As above + the sketch is used to create pad". What is meant with "above"? "After the transformation linearpattern is no longer in the main pad area and that crashes FreeCad." I couldn't reproduce that. After changing the placement of the Back Plate Sketch the holes move along nicely staying in the correct relative position |
But I did notice that double-clicking on the LinearPatterns which are subordinate to the MultiTransform will crash FC after closing the edit dialog. IMHO the solution is to hide these subordinate LinearPatterns so that they are not visible for selection. |
Please give more information on how to reproduce the crash |
I wasn't precise enough. "As above" was about the name of the bug report. I'll try to reproduce the bug and provide detailed step-by-step instruction. |
This is a recording of a short gdb session: http://firszt.eu/FreeCAD/FreeCAD_crash.webm For some reason I couldn't upload it to sourceforge. Let m know if that's enough (it might not be clear when I use double-click) |
See my comment above: But I did notice that double-clicking on the LinearPatterns which are subordinate to the MultiTransform will crash FC after closing the edit dialog. IMHO the solution is to hide these subordinate LinearPatterns so that they are not visible for selection. You should modify the sub-features of a MultiTransform through the MultiTransform dialog, not directly. There is a discussion about hiding the subfeatures in the tree altogether, see http://forum.freecadweb.org/viewtopic.php?f=10&t=2951&p=34019#p34019 |
Look at the change sets. |
FreeCAD: master aaeba38e 2014-03-31 14:42:55 Details Diff |
+ Fix crash when editing the linear pattern feature, suppress some warnings in release mode |
Affected Issues 0001139 |
| mod - src/App/Document.cpp | Diff File | ||
| mod - src/Mod/PartDesign/App/FeatureTransformed.cpp | Diff File | ||
| mod - src/Mod/PartDesign/Gui/TaskLinearPatternParameters.cpp | Diff File | ||
FreeCAD: master e47b8599 2014-03-31 16:35:22 Details Diff |
+ fix possible crashes in mirror and polar pattern feature |
| mod - src/Mod/PartDesign/Gui/TaskMirroredParameters.cpp | Diff File | ||
| mod - src/Mod/PartDesign/Gui/TaskPolarPatternParameters.cpp | Diff File | ||
| 2013-05-26 06:32 | pfirszt | New Issue | |
| 2013-05-26 06:32 | pfirszt | File Added: s4-uchwyt.fcstd | |
| 2013-05-29 16:15 | wmayer | Status | new => assigned |
| 2013-05-29 16:15 | wmayer | Assigned To | => jrheinlaender |
| 2013-07-22 14:48 | jrheinlaender | Note Added: 0003421 | |
| 2013-07-22 14:50 | jrheinlaender | Note Added: 0003422 | |
| 2013-07-28 17:36 | jrheinlaender | Note Added: 0003432 | |
| 2013-07-28 17:36 | jrheinlaender | Status | assigned => feedback |
| 2013-07-31 19:46 | pfirszt | Note Added: 0003435 | |
| 2013-07-31 20:05 | pfirszt | Note Added: 0003436 | |
| 2013-08-01 04:19 | jrheinlaender | Note Added: 0003437 | |
| 2014-05-20 17:46 | wmayer | Changeset attached | => FreeCAD Master master aaeba38e |
| 2014-05-20 17:48 | wmayer | Changeset attached | => FreeCAD Master master e47b8599 |
| 2014-05-20 17:48 | wmayer | Note Added: 0004709 | |
| 2014-05-20 17:48 | wmayer | Status | feedback => closed |
| 2014-05-20 17:48 | wmayer | Resolution | open => fixed |
| 2014-05-20 17:48 | wmayer | Fixed in Version | => 0.14 |
