| 0001630 | FreeCAD | Bug | public | 2014-07-23 04:36 | 2019-07-29 15:16 |
| Reporter | s11b01 | Assigned To | wmayer | ||
| Platform | 64 | OS | Windows | OS Version | 8.1 |
| Summary | 0001630: IGES-Export in [mm] turns to [Inches] | ||||
| Description | Every time I try to export a part as IGES, FreeCAD produces the file but changes the Dimension from [mm] to [Inches]. | ||||
How do you know this? Do you have an alternative CAD application to confirm that the unit is inches? |
Oh, when using CAD Exchanger I see that the output is different. |
Found the culprit: http://free-cad.svn.sourceforge.net/viewvc/free-cad/trunk/src/Mod/Part/App/TopoShape.cpp?r1=2080&r2=2079&pathrev=2080 |
FreeCAD: master 841b4fab 2014-07-23 13:49:16 Details Diff |
+ fixes 0001630: IGES-Export in [mm] turns to [Inches] |
Affected Issues 0001630 |
| mod - src/Mod/Part/App/TopoShape.cpp | Diff File | ||
FreeCAD: releases 3ecaf877 2014-08-28 15:27:35 wmayer Details Diff |
- fix focus issue with InputField - on document load set camera setting of the MDI views - do not try to use framebuffer objects when it's not supported on the system 0001690: sketch.getPoint crashes FreeCAD if the point does not exist 0001630: IGES-Export in [mm] turns to [Inches] 0001684: Sweep ignores the list of subshapes 0001667: 'Save file' disabled when viewing a drawing 0001682: Crash after updating editable texts in drawing 0001659: 3dconnexion space navigator moves view even when FreeCAD is not the active application 0001696: Quantity.getValueAs('rad') touches the Property 0001638: Not possible to draw anything |
Affected Issues 0001630, 0001638, 0001659, 0001667, 0001682, 0001684, 0001690, 0001696 |
| mod - src/Base/QuantityPy.xml | Diff File | ||
| mod - src/Gui/Document.cpp | Diff File | ||
| mod - src/Gui/GuiApplicationNativeEventAware.cpp | Diff File | ||
| mod - src/Gui/InputField.cpp | Diff File | ||
| mod - src/Gui/MouseSelection.cpp | Diff File | ||
| mod - src/Mod/Drawing/App/FeaturePage.cpp | Diff File | ||
| mod - src/Mod/Drawing/Gui/DrawingView.cpp | Diff File | ||
| mod - src/Mod/Part/App/PartFeatures.cpp | Diff File | ||
| mod - src/Mod/Sketcher/App/SketchObjectPyImp.cpp | Diff File | ||
| 2014-07-23 04:36 | s11b01 | New Issue | |
| 2014-07-23 10:10 | wmayer | Note Added: 0004832 | |
| 2014-07-23 10:18 | wmayer | Note Added: 0004833 | |
| 2014-07-23 11:51 | wmayer | Note Added: 0004835 | |
| 2014-07-23 12:22 | wmayer | Changeset attached | => FreeCAD Master master 841b4fab |
| 2014-07-23 12:22 | wmayer | Assigned To | => wmayer |
| 2014-07-23 12:22 | wmayer | Status | new => closed |
| 2014-07-23 12:22 | wmayer | Resolution | open => fixed |
| 2019-07-29 15:16 | Kunda1 | Changeset attached | => FreeCAD releases 3ecaf877 |
