| 0001682 | Drawing | Bug | public | 2014-08-12 22:10 | 2019-07-29 15:16 |
| Reporter | tinman | Assigned To | wmayer | ||
| OS | Windows | OS Version | 7 | ||
| Summary | 0001682: Crash after updating editable texts in drawing | ||||
| Description | After editing the texts in the "Editable Texts" data property of a drawing page FreeCAD crashes. | ||||
| Steps To Reproduce | 1) Start FreeCAD 2) Switch to Part workbench and place a cube 3) Switch to Drawing workbench and create new drawing based on A3 template "C:/Program Files/FreeCAD 0.14/data/Mod/Drawing/Templates/A3_Landscape.svg" 4) Select the new drawing page in the combo view 5) Switch to Data page in the properties view 6) Click on the "..." button to bring up the editor window for "Editable Texts" 7) Replace "AUTHOR NAME" with "TESTTEST" and click on "OK" 8) Press "Enter" to confirm change from "Editable Text" single line property editor | ||||
Happens inside FeaturePage::execute() and there in the second "while" loop. |
It doesn't crash for me... Any more info? It's strange, that stuff has been there for a while... |
The erroneous part is this: string::const_iterator begin, end; begin = outfragment.begin(); end = outfragment.end(); ... outfragment = boost::regex_replace(outfragment, e2, "$1>"+EditableTexts.getValues()[count]+"$3"); So, the crash is logical because the iterators "begin" and "end" become invalid when "outfragment" changes. Further down "begin" is set again but not "end". |
Argh stupid mistake :) thanks for fixing! Strange that it didn't cause a crash here |
FreeCAD: master 7939027c 2014-08-13 12:49:09 Details Diff |
+ fixes 0001682: Crash after updating editable texts in drawing |
Affected Issues 0001682 |
| mod - src/Mod/Drawing/App/FeaturePage.cpp | Diff File | ||
FreeCAD: releases 3ecaf877 2014-08-28 15:27:35 wmayer Details Diff |
- fix focus issue with InputField - on document load set camera setting of the MDI views - do not try to use framebuffer objects when it's not supported on the system 0001690: sketch.getPoint crashes FreeCAD if the point does not exist 0001630: IGES-Export in [mm] turns to [Inches] 0001684: Sweep ignores the list of subshapes 0001667: 'Save file' disabled when viewing a drawing 0001682: Crash after updating editable texts in drawing 0001659: 3dconnexion space navigator moves view even when FreeCAD is not the active application 0001696: Quantity.getValueAs('rad') touches the Property 0001638: Not possible to draw anything |
Affected Issues 0001630, 0001638, 0001659, 0001667, 0001682, 0001684, 0001690, 0001696 |
| mod - src/Base/QuantityPy.xml | Diff File | ||
| mod - src/Gui/Document.cpp | Diff File | ||
| mod - src/Gui/GuiApplicationNativeEventAware.cpp | Diff File | ||
| mod - src/Gui/InputField.cpp | Diff File | ||
| mod - src/Gui/MouseSelection.cpp | Diff File | ||
| mod - src/Mod/Drawing/Gui/DrawingView.cpp | Diff File | ||
| mod - src/Mod/Part/App/PartFeatures.cpp | Diff File | ||
| mod - src/Mod/Part/App/TopoShape.cpp | Diff File | ||
| mod - src/Mod/Sketcher/App/SketchObjectPyImp.cpp | Diff File | ||
| 2014-08-12 22:10 | tinman | New Issue | |
| 2014-08-12 23:12 | wmayer | Status | new => confirmed |
| 2014-08-12 23:30 | wmayer | Note Added: 0004940 | |
| 2014-08-13 03:40 | yorik | Note Added: 0004941 | |
| 2014-08-13 06:18 | wmayer | Note Added: 0004942 | |
| 2014-08-13 11:22 | wmayer | Changeset attached | => FreeCAD Master master 7939027c |
| 2014-08-13 11:22 | wmayer | Assigned To | => wmayer |
| 2014-08-13 11:22 | wmayer | Status | confirmed => closed |
| 2014-08-13 11:22 | wmayer | Resolution | open => fixed |
| 2014-08-13 14:15 | yorik | Note Added: 0004944 | |
| 2019-07-29 15:16 | Kunda1 | Changeset attached | => FreeCAD releases 3ecaf877 |
